Everything posted by Amila G
Top Gear/fifth Gear/jeremy Clarkson Videos!
Top gear s21 episode 1 full enjoy before youtube take it down Looks like they review the P1 and go to Chernobyl this searies... I've been waiting forever for them to go to Chernobyl http://www.youtube.com/watch?v=3i_WRRWamm4
Headlights On At Daytime
It's definitely a good move as it would increase the visibility of the motorcyclist. I once failed to notice an oncoming black sportage while I was doing a tight manure -( I only noticed it only when it was close although I could see the road). I've read somewhere that black cars has a high probability of facing an accident compared to lighter colored ones - so I think even the DRL s are a good thing even for out country. On the subject of not turning on the lights in the dark, I think they think they are a sort of a "pora" to drive without the lights. Once our office driver did 110 on the Galle road 12 at night pouring rain without turning on the wipers and he was like - I can see the road why use wipers! . I turn on the lights if it makes even a little bit of difference to visibility. My xtreme visions have a very low life span even the manufacturer recommends to keep an extra pair, but I don't worry about it. Seeing the road is more important
Good Tyre Brand....!
Could you share the place you got the tires from and the size ? My bg turanza ar12 s are also on the way out (40k +) i am looking for 185/70 14 ones.
Leaky Radiator Tank Help
hm I guess you've already checked the thermostat valve ?
But that's not good. If the engine is running cool it reduces the efficiency and increases wear.
ah ok, went to radiator house to ask about copper. They said they don't do copper but a brass tank can be fitted by using some kind of adhesive as aluminium can't be soldered on. But they also said that it might start leaking again after sometime I'll go to the guy you mentioned possibly on Monday.
Thanks all for your comments. Will check about the copper ones as it seems as the best solution at the moment. @Magnum, yes there's a difference between auto/manual radiators, I only got to know because @Japan lanka they asked if the car is a manual or auto saying that the radiators are different.
Thanks VVTI, I think you are referring to a copper tank - not the whole radiator. But won't a copper tank with aluminium core create an issue ?
Hi Guys, The radiator top tank of my car (corolla 110 diesel) has developed a leak that happens only when the engine is hot and revved. There's a 2 inch long patch under the top hose that looks like it's rusted (although it's plastic) and tiny water droplets appear on it when the engine is hot. (As if the radiator is sweating). I took the car to Radiator house and they quoted 7500 to replace the top tank with another plastic one. But the issue is their replacement tank is made in china and are not giving a warranty for that. But the guy assured that they are as good as originals. Also that tank looked like it is made from a different kind of plastic that flexes a lot more than the original. A used radiator costs 25000 at Japan lanka, which is a lot considering it too will be 18 years old. I don't put so much as a chinese bolt in the car so I'm hesitant to use the replacement tank. Another mech suggested to repair the crack with epifix (and epoxy glue) or super glue mixed with powder ! So if any of you replaced / repaired a radiator could you share your experience of how it was done and how it is holding up ?
- Post Whoring - Part 2
2Nd Hand Market Of The Hybrid Vehicles
Well said, that's exactly why I'm drooling for a luxel, hoping the petrol car market will crash and one will become to the affordable range
Rip Paul Walker
Thanks JB for the nice wording... no other film star passing away won't make me this sad... I can't remember how many times I've watched the car chases in 2 Fast 2 Furious.. His driving style in the green evo is what made me to learn to shift a manual so fast. RIP Paul Walker...
- Research On Buying Intention Of Hybrid Vehicles
Apart from all of the above I found the survey a bit tedious/boring to answer. If you need real answers you need to make it a bit more interesting. Otherwise the respondents will just dropout halfway through. @watchman, I see you call those questions "free text", are you in the market research industry by any chance ?
Doctors Car Pass
That's funny - how are they going to check that. no sane cop in this country would even think about stopping a vehicle with V*P stickers May be they'll walk up to a parked car and asked the driver really really politely if the sticker is real
Sudden Temperature Hike
Thanks MkX, But I don't think that the overheating and the water level going down is related, The whole overheating drama lasted only about 10 - 15 mins and it went away by itself. I tried several time by revving up the engine without the ac after returning home but the fans worked fine and the temp never went up. I checked the water level (in the radiator itself) after that (when the engine was cool enough to open the cap). Now there is no coolant near the seal however I could see a bit of coolant coming around the seal if water of poured on to the hot radiator (like when washing the car). It was there from a long time but my mech said it;s not a big deal as there was no major coolant loss at that time. I'm not sure even if the engine actually over heated as the gauge went up so fast and it was over by itself I guess the radiator is some sort of plastic (at least the top tank). is it possible to repair the seal properly ?
Thanks guys. I replaced the radiator cap as there was a bit of rust in the inside. Now the radiator is not loosing any water. But the temperature increase did not happen again, so if I take the car to a mech I dont think he'll be able to find anything wrong. Or else can a good electrician can find a bad relay or something when it's not failed yet ? and can you suggest a guy near Nugegoda area.
Hi guys, I have a diesel corolla 110 manual one. This evening when returning home I stopped at a gas station and when pulling to the road I noticed that the temp gauge had suddenly moved above the 3/4 mark. It was fine (in the 1/2 mark) about 2 mins before. I thought the needle was acting up but pulled over turned off the engine and turned the key back to ON, then the needle came to the 1/2 mark, but when started, it moved from 1/2 to 3/4 within about 20 seconds !. I drove again for few seconds and the gauge kept rising so I stopped and checked the fans. AC was off and both the fans were off although the temp was high. When the engine is off and the key is in ON the needle sits around the half mark and it went up only when the engine is started, Then I turned on the AC and then the temp slowly became normal. Then I started driving again but the temp kept rising when the AC cuts out. But the whole drama was over in another 10 mins and everything is back to normal now. Now the temp is normal and the fans come on usual way. After that I noticed the radiator top tank was almost empty although the plastic tank has coolant in it (but the temp was fine although the radiator was missing close to 1L of coolant). When the temp was high I noticed a bit of coolant where the top tank meets the radiator core and there was a bit of smoke coming from the tube that goes into the plastic tank from the radiator - is it normal ? So my questions are could this be due to a bad gauge or an issue with the fans. - I mean will the temp go up that fast (1/2 to 3/4) in 20 seconds if the fans are not running ? My trusty old electrician is gone so I'm kinda hesitant to show this to an unknown guy as the issue is gone now. Could you recommend a good place around Nugegoda area ? Lastly any other symptoms of overheating engines if you don't / can't trust the temp guage ?
Are Cars Sold As Brand New In Lk Of Lower Quality?
yes ! the same guy
Is this the same Siribaddana who ran the JAVA course / scam if that's so, take this story as a grain of salt. Just google his name and see what comes up
