FreakSL
Everything posted by FreakSL
  1. FreakSL replied to FreakSL's topic in General
    thanks for the help guys , anyone knows clutch plate kit part number for proton savvy, company refusing to give the part number to outside , i can bring it down for cheap than here.
  2. FreakSL posted a topic in OTHERS
    Hey guys does anyone know the part number for Proton Savvy clutch kit, I contacted the company they said they do not give the part number to outside , wtf ? i have friend who can bring down spare parts but he needs a part number , does anyone know where to find it ?
  3. FreakSL replied to FreakSL's topic in General
    yea will do that, thanks dude
  4. FreakSL replied to Biker boy's topic in General
    yea rims been changed ,will do like that see , thanks
  5. FreakSL replied to FreakSL's topic in General
    Yea the squeaking noise can be hear , even though the engine is off, it's like squeaking noise when you press the pedal and when it come up back sounds like a noise from a horror movie door opening
  6. FreakSL replied to FreakSL's topic in General
    i thought may be some bushes worn off , yea will go to a mechanic this week end everyone was busy because of the night races
  7. FreakSL replied to Biker boy's topic in General
    yea there is a sticker saying the tyre pressure and all but the problem is thats for 15" RIMS. but i have 13 rims
  8. FreakSL replied to Biker boy's topic in General
    Proton Savvy
  9. FreakSL replied to Biker boy's topic in General
    Proton Savvy
  10. FreakSL posted a topic in General
    hey Guys I have a squeaking clutch pedal, first it was ok when the engine is cold and started the squeaking noise when the engine become warm. i showed it to a mechanic and he suggested WD 40, after applying WD 40 to the enf og clutch pedal and etc.. it was ok for a couple of days , and started again, now the squeaking noise come when the engine cold also, when going through horrible after work traffic clutch pedal become little bit stiff as well, ps : gear changing is not hard , engage properly can it be bushes worn off or something like that anyone experienced this kind of a problem before
  11. is there anyway that I stop this or any solution for the , lets say i drive slowly during the weekdays to office and back, due to traffic but weekedns if drive bit fast sometime it starts jerking on low speeds , anything I can do to stop this problem ? or do I have to completely reset the ECU
  12. FreakSL replied to Biker boy's topic in General
    hey anyone can tell me whats the best tire pressure for 165/70/13 any ideas ??
  13. hey I want to know too, heard that only WTC infront tickets are avialble, you need tickets for 17th ?
  14. Thanks so much for the advise guys , yes Im going to service the motor thats anyways good , i was wonder why the jerking thing is , you know while i was going through proton forums I found out there is a way of soft rest the ECU, step by step is like this may be the proton savvy users can use this , 1. put the key into the switch and out it to the on position 2.press accelarator pedal to the floor and stay for 10 seconds 3. put the key to the off postition, while you ar epressing the accelarator pedal to the floor 5. after you put the key into off postion keep the leg out of the pedal and start the car after i did above the jerking stoped any Idea ?
  15. Hey Guys yesterday Evening i tried leaving the office and started the car and it doesn't made any noise , nothing happened , i put the gear into 4th and gave a little push and tried starting and it worked , then i switched off and on for couple of time and it worked , but again today in the morning i tried to start the car but the same thing happened , no crank no star, i asked one of the mechanics to look at it while i was at work. he told me wire from the starter motor was loose so he fixed it , i was wondering if it is a loose connection, is there a permanent way that I can fix this or do I need to service the motor ? Also i felt some jerking on 2nd and 3rd gear low speed while driving yesterday , i have a proton Savvy manual
  16. FreakSL posted a topic in OTHERS
    Hey Guys Anyone knows about Saturn cars ? I need to know are there spare parts for those here. May be some other brands parts are compatible ?
  17. Hey guys , I recently found out that Peugeot spare parts are compatible with Proton cars, if you can give me a number of one of these experts i could get some more information, thanks
  18. Hey guys , anyone knows a good place to tune up my Proton Savvy ? its vey slow on puck up and i think there is a small miss aswell . if you guys know exact person I should contact do appreciate and also it will be much convenient for me if he is around Kohuwela / Nugegoda that area. thanks
  19. found the guy who is bringing down proton parts , T - Belt + adjuster + oil seals everything will be LKR 16500/- but have to wait for 3 weeks. now only one problem
  20. yea in that case best option is to buy the T belt only from the company and adjust the tensioner and other right ? No it doesnt give any sudden reves or anything , its just it has 83,000 KMs on the clock, and thought its the time to change the T belt
  21. Guys I checked from the company, if you need the belt only its RS. 17,800 something , if you need the full set belt + tensioner (adjuster) you won't beleive its gonna cost you LKR 55,000 odd. and you might get a 15% discount for the belt if you ask them to fix it for you, and this is the best part if you need the 2 oil seal and fitting charges everything gonna cost you nearly LKR 75,000 wtf ? i think I have no choice other than taking a sample to a shop and get one..
  22. thanks for the information guys, i checked with couple of guys in Panchikawatte , they told me to bring the sample timing belt and they can find one for it. you thinks its a good idea ? because my savvy has 86 in the clock and I'm little worried about that
  23. hey guys need help, I have a Proton Savvy , need to know whats the best mileage to change the timing belt and where to buy, (other than the company - Swedish Trading ) they are pretty expensive in this case, if you guys can help me where to buy a timing belt set it will be much appreciated thanks
  24. FreakSL replied to voltran's topic in OTHERS
    Hey I also own a Proton Savy, need some information regarding the timing belt change, whats the best mileage i should change the belt and any one have an Idea where I can get one. Swedish trading is quite expensive in this case if you guys can help really appreciate
