varunatech
Everything posted by varunatech
  1. MINIACE, I have no intention of misleading any member. Please note that in a automatic transmission, shifting between 2nd, 3rd and 4th while driving is safe and that is how it is designed. Please note my explanation here applied to Hydraulic Automatic transmission and do explain use 4 speed gear boxes. The OD ON/OFF button will make sure you cannot shift beyond the 3rd gear and you can apply it when running on 4th gear. The system will shift you down to three. Also if you put OD to on, while you rev faster (reaching the limits of 3rd gear) the system will automatically shift you to 4th gear. Apart from OD button you can move to 2nd and D position depending on the driving condition (the amount of engine break you need or torque you need). The above driving is practiced and also stated in owners manual. Only thing is you cannot or should not shift to first or R gear. That is why you have an interlock tied with the button and the foot break. You should never do that. The Auto transmission shifts is initiated by electrically driven actuators and those are actuated by a set of electrical pulses. Though we have a lever in the car, we actually depress a set of switches. And the system is designed to shift between these gears and also the system can put it to first gear in case of a higher torque requirement. You definitely would have have seen steering mounted gear switches in sports models. They are meant to switch across gears. Those switches also actuates. The system also actuate the valves, we also do the same by shifting the lever. It is correct and doable to shift between 2, 3 and 4. And also for CVT gear steps. Mind you not for the 1st and R. Please correct me if I have done any mistake, and do reiterate has no intention of misleading anyone. Thanks..............
  2. What you say is available in some new models of Euro and US cars to save gas. They are fitted with different engines and starter motors to start the engine quickly. Other normal ones cannot cut off fuel as the that will stall the engine
  3. +1, thank your Hiran for bringing it up.GDI is different animal altogether. So be careful everyone and do your research or follow the what the manufacturer says.
  4. I am more very specific when doing technical stuff, shiver hmmmm, might not be the correct word, rather disgusted to see someone treating the injectors like that........ "not what you did, disgusted on this.................then using two wires he attached to the connectors on the injector earlier he gave it power using a normal car battery and repeated the process several times..................."
  5. Shifting from D to N or D to 2 (or vice versa) will not do any harm to the transmission. BUT, letting a car roll on neutral can be very tricky as there is no engine breaking available. Specially if you are going downhill. When going downhill without the engine break you will melt the breaks and finally loosing it all. In some countries there are laws against coasting (driving in neutral). Finally better not on flat land. Never in downhill. (By the way in some transmissions, if you shift from D to 2 at a very high speed where the 2nd gear cannot operate, the electronics will not downshift until you come to a tolerable speed for the 2nd gear)
  6. Need to differ, the injector outer is rugged, but still well protected. The interior of the injector is very sensitive to particles in air and also for any contamination. It is a delicate device, treating it with respect can be useful...............that is my two cents..................
  7. Guys, the injectors are very sensitive devices. The best practice is handling them in a dust free environment and holding with tweezers. All parts has to be handled professionally. Then the best cleaning is by using Ultrasonic cleaning bath. Then followed by the flow pattern test..................... The above method and man handling the injectors shivers me. WoW.............
  8. Yes few times, I have, I did identify a slight carbon build up and a resulting Pre ignition knock. A very slight one which only a car enthusiast will hear. I did use BG44K, added it to a 60L capacity tank, while I am at the Petrol station. Then filled the tank drove off. When the tank is 2/3 empty I did refill again. Say after 250km of driving the Pre ignition knock went low and later disappeared. For a heavily carbonized engine of a friend, I did use the "BG Air Intake System Cleaner" and BG44K and the problem got resolved. After that I do throw a BG44K once in a while in my current vehicle as a preventive measure. Usually that is what service agents in US do usually. Other products may work, like 3M, Valvoline, SEAFOAM, WURTH, Abro to name a few and to be impartial.
  9. Hi Carbon, Thanks for your thought and indeed a very good point. First let me explain that as I mentioned both tyres should be in good condition, but the rear tyres should be relatively new (in case you have two different wear on the two sets). The grip or in Physics the "F" is equal to the product of R and u (friction coefficient). When a vehicle apply break and when take turns two kinds of friction applies which is kinetic friction and rolling friction. However all above mentioned is dependent of the exerted force or "R" or in other words the weight of the vehicle as well. As you mentioned the weight of the vehicle shifts forward when braking and the front tyres get extra dose of "R". The rear wheels lose some amount of "R". Higher R means higher grip and yes the front wheels will stick, but the poor rear wheels with less R and less tread will loose grip altogether. The vehicle rear may lift a bit, manageable as long as the suspension absorbs the energy. But in case of a simple lateral movement, the front wheels will act as a pivot and the rear end will move sideways freely, which is highly undesirable. Also note that the front wheels should have ABS, so the excessive grip might not convert to a slip. All in all every one should have good tyres. By any chance if the wear is different, it is advantageous to use them in the rear. Also please note many parameters come into play and using new tyres in back adds a bit to the formula, Why we do not see these things in much effect is............in our roads the average driving speeds are slow. Hence these things has minimum effect. At high speeds I have seen these come into play, but the victims or the onlookers does not identify and say road is slippery or just bad luck.
  10. Hiran, the reputed additives are used by vehicle manufacturers at their service points. I did research about these products in detail before using any. I found that in US, EU and Aus.....service stations do add additives and use cleaners even without notifying the customer. I did this fact finding many moons back, if I find the links I will post. As my memory serves BMW, VW, Mercs, Toyota, Ford all uses them. I am not marketing, but my favorite is BG products. Hope this helps you...........
  11. Looks the two legged dog problem is much worse than the four legged ones......these two legged dogs carry anti society mind set.....sad
  12. Soltron is a fuel additive, which claims it has a catalytic effect on the fuel combustion, generating higher energy and minimizing emissions. The following two links shows the explanations and some tests carried out by a Japanese institute and University of Moratuwa. http://www.soltronlanka.com/test.htm http://www.soltronlanka.com/products.htm I have not conducted and kmp/l tests using Soltron, but did use once or twice on a ageing 275,000km car. By the way I have some other information.......my wife works for a manufacturing company where they use a boiler in the factory which runs on furnace oil. They have started using Soltron (the furnace oil version) and following are two observations were made. 1. They had an increase in efficiency, leading to less consumption of furnace oil. 2. In Friday they shut down the boiler and start on Monday. Usually they have difficulty of firing the boiler on Mondays as it has cooled down. After using soltron it has become a much lesser problem and boiler has fired more easily. Overall there has been a saving as my wife analyzes the savings too. Please note I have no intention on Promoting soltron, I have not conducted any tests or I have no personal observations. But the above mentioned are true as my wife is also tech savvy and vehicle/engine fan and was responsible for the efficient running of the factory with minimum cost.
  13. In the first place why does people in Sri Lanka does not follow manufacturer recommendations. In the WURTH can it is mentioned in simple English. Do not buy what the seller says, do they know how the internal combustion works, or how the closed circuit fuel system of your car works, does he know the content of the wurth can..... Fill up the gas tank ASAP. And if your gas tank has less than 50L capacity (I think so for the FB14), yu can do simple math and add the respective amount of the additive. Thanks to wurth, it has a nice cap which fastens nicely. You are lucky, the BG product for fuel tank addition is far aggressive, and the usual way is once added you pump fuel on top of it for better mixing. Also please note that all these additives are extremely flammable, should not be inhaled, consumed, contact with eyes or skin.
  14. My friend, first you need to do a proper diagnosis from an expert. I have a feeling your friend engineer might be correct as the car stops and chokes when you hard accelerate. A engine scanner, a fuel pressure meter and lot of experience will help here. It does not sound like a simple case of carbon deposits or looks pretty straight forward. Taking to the agents or to an engineering company (not a replace this replace that company) will help. By the way ECUs are available with agents as well as in Delkanda.
  15. Hi, I have done fuel tank additives, fuel line direct feed and also ultra sonic cleaning of injectors. Ultrasonic injector cleaning is the best for the cleaning of the injector it self, and also the fuel spray tests they perform gives you a good idea of the state of the injectors. However the above technique does not clean the entire fuel system from the tank, lines, intake valves, and throttle body and all. There are few good products (BG, 3M, WURTH to name a few) you can use with professional assistance and apparatus. Out of the above three, I have my personal preference but feel that I should not mention in the forum. If you send me a mail I can help you with my experience. Usually the tank additives clean the tank to injectors, but good if you have a relatively a cleaner system and you use it as a house keeping. Direct fuel line feds are good. Air intake feeders actually does not clean injectors, but will help to clean your throttle body, intake manifold and vales. Which are essential components in the total equation. Hope this helps.
  16. In buses majority of weight go for the rear, by default they have enough grip, this is considering they are loaded. If not loaded these heavy vehicles also loose grip in rear wheels very easily. What I have mentioned will come into effect, when someone try to take a turn on a rainy day. The higher grip front tyres will hold the road and will act as a pivot, while the rear skids side ways. By the way this does not men that you can put extremely worn tyres in front and the good ones in back. Actually no one should ride on worn tyres.......
  17. Hi, you need to have same tyre pattern on all wheels, as different patterns has different grip and will lead you to uncontrollable situation. By the way need to differ with what Carbon B4 said. Your good tyers has to be in the back wheels. Because back wheels are the wheels which loose grip first and gives you over steer. Over steer is far more difficult to cope than under steer. Hence the recommendation is for the good tyres to go back. Anyway in a given axle, the tread patterns and the worn off must be the same.
  18. Hi, few of my friends has IST One guy bought it because he has two small kids and he can keep lot of kids needs in the boot.....and the boot is accessible from the cabin. Suits his purpose. The IST 2002/2003 carry a 1.3L VVTi engine. It does around 10+ kmp/l in city with moderate aggression. For that budget, if your concern is fuel economy the best vehicle will be Vios. 11kmp/l is realistic in 100% city driving. Once you buy the one, probably you may need to tune the engine (in case the previous owner has screwed it). Few more things the IST has Fabric seats, feels good but kids may soil it easily. Vios has leather seats, very hot in SUN, if you do not treat them with leather conditioner the seats may look dull. But a spilled ice cream or a chocolate can be easily removed. Once I did maintain leather seats for 3+ years (every weak applying the conditioner), when I returned the car, the seats had no cracks and frankly the interior was adorable. There were many buyers jumping around to grab the vehicle just because of the nice leather interior (the engine was also maintained with maximum care)............
  19. Hi, please read the following article from Popular Mechanics....... Many fuel saving devices are being tested and test results are published. Hope this solved all your and doubts. http://www.popularmechanics.com/cars/alternative-fuel/gas-mileage/1802932 Looking For A Miracle: We Test Automotive 'Fuel Savers' Can copper tubing, cheap magnets and wacky gimmicks really boost your mileage by as much as 300 percent? PM's Mike Allen puts the latest MPG gadgets to the test. Please step back from the truck. Read more: Looking For A Miracle: We Test Automotive 'Fuel Savers' - Popular Mechanics http://www.popularmechanics.com/cars/alternative-fuel/gas-mileage/1802932
  20. By the way, if you drive without always thrashing the gas peddle......you get over 11kmp/l in colombo city. For this I have solid data, after multiple tests. If anyone interested I can post the test conditions.
  21. Please specify the patterns first. What RPM levels the knock arises, and the type of fuel you use (Octane value). Can be many reasons, 1. Knock sensor issues. 2. Timing issues and this has relationship to many things. 3. Preignition knock due to combustion chamber carbon deposits. First thing, if you need help in a forum, please mention how it behaves. Exact behavior of the issue as much as possible in simple sentences. I had resolved few ignition issues of friends. Will try to help based on what I have learnt.
  22. Magnum is correct, it uses the same engine as Allion 1.8L. I have no personnel experience with 1.8L engine. But one of my friend had 1.5L Premio and I have helped him many occasions. The 1.5L does 10km/pl in city driving. Considering the better power to weight ratio (and the VVTi engine knows how to optimally use it), the 1.8L may do a better figure. Also note that the km per liter also depend on driving style, tyre pressure etc.... On maintenance costs, I have no solid source of information. What I have heard as the 1.8L engine is not that available in SL, some parts are bit expensive compared to 1.5L engines. Hope this helps.................
  23. Ha ha, like your quote......"90%" of Sri Lankan vehicle tyres are under inflated".............so true, and they do not know the out come in long continuous drive. The tyre temp rises and it may burst............
  24. Must thank the repair crew, hmmmm some people enter E01 even without wheel brace. Next time someone will run out of gas in the middle of nowhere and will call emergency and ask for gas. Then if not available will call Sir*s* and say that emergency crew did not supply gas.......and the E01 is a failure..... In some countries, if you run out of gas, highway or in city you will be fined heavily.
  25. Hi Carbon, you and others can enjoy driving for many years to come if people follow simple guidelines. Please educate people as much as possible, word of mouth is very powerful. This is no noble work, just trying to do something rather than doing nothing.
