varunatech
Everything posted by varunatech
  1. I had one some time back. Well maintained, pumps Octane 95. recommended tyre pressure. Did measure for a long period of time. City travel in traffic is 11.5 and over. Outstations usually 15.
  2. You can continue to pump Octane 90 and many Sri Lankans do. But keep in mind the engine is not designed for that and after some time your engine deposits will be higher than normal for the same amount of mileage. You will run into preignition knocks due to that. And I would like yourself explaining on what basis that RON90 is ok for an engine designed for RON91 and above. And mind you in JP, MY Sing and many other countries where the 1NZ-FE engine is used, those pumps do not carry Octane 90.
  3. One of my friend did use well water in his Maruti 800, despite I was insisting on using Coolant to prevent rusting. He did not heed, ended up with a rusted engine block and badly blocked radiator in his van. Now he has changed to coolant in all his vehicles. By the way always follow what the manufacturer say. And Sylvi is very correct, these days the engines are designed with low tolerences to save cost, minimize weight etc...
  4. Well said and very true. Also Sri Lankan sit in front seat with the seat belt, but keep his kid on lap. If the Air Bag comes the kid will have a serious injury or the worst, else the kid will fly out from the windscreen when you hit a stationary object or during a head on collision. Also they allow the kids to jump from seat to seat while driving at high speed. The kid may fall on you, or you may brake, and the kid will break something...........
  5. The VIOS Carry the 1NZ-FE engine. You should use a mineral oil and change in 5K or within months which ever comes first. Change the oil filter at 5K Air Filter every 20K r as per the condition Spark plugs 25K should be fine, if you use genuine. ATF should be less than 40K, around 35K. Because we always stay in traffic. Coolant, at minimum 40K (Best practice, even looks good) Brake oil 40K minimum (Best practice, even looks good) Steering oil 40K minimum (Best practice, even looks good) Use RON 95 Petrol, engine designed for RON91 or above Has leather seats, if you use a leather conditioner at least once in two weeks, the seats will look fresh and nice even for years above just comes to my mind. It is a simple, efficient and practical car for daily commuting. All other best practices will make it last for a good time in good condition.
  6. I think he is looking for high fuel efficiency........... else Cefiro is good to burn fuel.........
  7. There is, but I have no personal experience.............all good brands carry
  8. Keep us posted, I have first hand experience and happy.............go for a long drive with high RPM, E01.
  9. Nope, I have not gone there yet. This was done at their usual place.
  10. Cannot remember, because I did change Air Filter plus plugs from them and added to the bill. Run a call and see, their number is on web.
  11. D*MO.....they are friendly and let me be part of the entire thing.....full cooperation.........by the way there can be other places, just search the forum.
  12. The best method to clean injectors is using an Ultrasonic machine. Those machines are available in leading auto shops. They take out the injectors and place in a special liquid bath and ally Ultasonic waves. These waves clean the injectors. Then they will run a flow pattern test, which will give an indication on flow rates and fuel injection patterns. Secondly you can use a injector cleaner fluid through the injectors using a special gadget. This is effective and most places in SL offer this service too. I have used BG products and other like 3M, WURTH are effective too. Finally you can add an additive to the tank and run the car. This will slowly clean the entire fuel system. From above three, the first one is the most effective, but only clean the injectors but does it very well. Second will help to clean the engine chambers a bit too. Final one will clean the entire fuel system, but may be not effective on highly clogged injectors. Hope this helps, and there are lot more information if you search the forum...........
  13. I have seen them in Lau**g** shops, one was near Orugodawatta. Also has seen in auto places in Da*** in, Supermarkets etc.. There are very cheap ones to stuff like 3*. This leather is ok, there are also othet fabric stuff which are good quality. Everything works and clean and good quality stuff are good.
  14. Rev = Revolution Revolutions per Minute = RPM ............ simply do not rev the engine and go very fast or just rev the engine in neutral as some people do.....when the engine is cold this is really bad, even rev a warmed engine in neutral is damaging to the engine. Jack Rabbit is the guys who speeds up very fast and breaks so quick between signal light to signal light or with on short distance.......also Jack rabbit just slam the gas peddle to the metal to get the kick out of it. By the way some people enjoy this and know the impact, but they love to do that for the fun. That is ok as they like to do that. But the day to day user doing that specially on a cold engine will ruin the engine. Warm engines will drink gas like monsters when you do Jack rabbit.........
  15. Yes, perfectly it is possible..........
  16. Good detailed post, I believe will help others a lot...................
  17. IOC Euro III just mention the letters 93, they never use the word Octane For their 95, they publicly use the word Octane. and I have never seen that they mention in any public article that Eur III is which Octane version. Can someone with more info shed some light on this.
  18. Spot on........
  19. Go to D**O showroom opposite Jethavanaramaya temple.....I always buy from the, lowest price for BOSCH. Call them before you go, just to make sure the correct length is in stocks.
  20. Can you be more elaborate on the 'sound' you here. The way you have described provides no clue. You have only mentioned a sound, is it a bang, thud, creek, hum does it continue, does it go away when you lower the speed..........
  21. Japan is an Island, surrounded by sea..........your vehicle you get from Japan may have been parked outside by a house close to sea. It is corroded. The Jap family decided to go on a fishing vacation (you know Japs love fish), they parked the your valuable JDM close to the beach, was there for two days. The naughty kids were humping up and down with their salty feet........even they did throw few fish all around covered with salt.......... They were hit by a teeny weeny Tsunami as well (which they did enjoy, you know in Japan they fins Tsunami's every other corner). Now your vehicle is well treated with salt........... :) And Japan has bad winters in the highlands.......they may be salting the roads too. Winter affects the entire northern hemisphere, parts of Australia and Newzealand.....all those vehicles are rusted up because of salt in road............ Just noted to show you a point...........and also note the Winter in UK/EU does not last for a long time. Also note that humidity is a great factor for corrosion........in that case UK or EU has less humidity than here. And vehicles in Winter countries they apply anti rust coatings........a two year used vehicle in UK/EU may have been expose to maximum two winters..... Misconceptions and rumors has wings, facts have tortoise feet...........
  22. Terabyte is right............ 1NZ-FE does this to get the engine working temp up quickly. Also it conducts a series of tests and calibration, but it does not mean you need to keep it like that every other day, You can drive away, but keep in mind it is a best practice not to rev our engine and do jack rabbit until the engine achieves the working temp.
  23. My friend, my worry so far not about the usual car owner. Please do mind that there are so many bike, three wheel owners. Bike owners are school teachers, clerks, farmers, shop to shop sellers. These folks were paying for the diesel. And the CEB was guzzling Diesel to generate power, because CEB plus the previous politicians had no vision for the energy requirements or they just did ignore as they could make few bucks by getting rented electricity. Railway was sent in drain, making the lorry transport industry thriving and making all Mudalali's happy. All these diesel was payed by the poor biker, and people whom afforded a car with great difficulty. I am sorry my answer was not showing the high level picture.............. In summary our system is a mess, correcting the entire system create chaos........as a country we need to correct the energy crisis, we need to reestablish the rail transportation and also widen the network.....etc...etc.... Please note my comments are not politically biased, I simply like my country and never whines on what it has to offer for myself.......
  24. I think Terabyte had no political biased motive in making this statement.He simply did mention what happened from a reality sense .
