Everything posted by maheshw
Water Dropping From Silencer
Nothing to worry.your carburator or EFI system is working fine. thats a one indicate of that.
B11 Vs Hb 11 Diffrence
there are two major models in B11. Long buffer model & short buffer model.highest grade is Long buffer 1500cc one which is 5 fwd.
Nissan Fb14 Clutch Plate Issue
yes. returned the aisian things & luckily got 100% refund on that. anw got to known from a friend that most of the toyotas are coming with aisian brand clutch plates & nissans are with exicidy. oppsites changes might give troubles. dont know the truth......
- Radiator Coolant Mixing With Water
At last able to sort out the issue with new excidy clutch & pressure plate. issue was in the cluch plate. thanks everyone.
Ek3 Reducing Water In Rediator
May be it due to a leak in gasket as Stig state. But before enter to that check any leaks in water lines, jackets.Radiator cap. Fill the water to proper levels & run. when the car reaches to average temp open the bonnet & ask someone to accelerator for around 2-3K.check whether there is any leaks. some leaks can be small as needles.(becarefull when doing this) Did you notice any smoke than before while accelerating? My 2cents.
Also, doing 1000 - 2000 km with this vibration will cause your engine and gearbox mounts to give up so I suggest you do not try such a long trial run since this vibration is severe. The car should be smooth from the point where the repair was done if everything was done properly. Yes i too agreed with your comment. i have meet another mechanic & he also state need to re check this A-Z. if theirs nothing wrong with flywheel or mounts i have replace with original nissan clutch plated which will cost me another 10-15k. previous plates were excedy & replaced with aisian japanese one. anw i am planing to check this again on tomorow of dayafter. will keep post. Thanks for the help & have a great day.
NIssan Sunny Fb 14 Manual Gear. ODO 187000 Dear friends, Few days back suddenly my clutch start to slip.when i am accelerating car didn't move very much as earlier & there was a very bad (kara ganda) smell from gear box area. so i showed it to my mechanic & as his guides replace the clutch plate pressure plate & the razor with new 90 gear oil two days back. Now the issue is after this repair when am releasing the clutch it starts to vibrate the car & move. if i accelerate bit high it moves as normal. this feels very high on reverse gear vibrating the car bit high.also i feel the same smell again after open the bonnet. so i meet the mechanic again & showed the issue. he informed me that may be the pressure plate has not fixed properly to the fly wheel & need to replace to another new pressure plate or drive with this situation it might be ok after 1000-2000 kms. am bit confused on this as this is the first time i have faced to such situation. hence please help to sort out the issue. Thank You.
Happy Birthday Harshan Senadhira!!!!
Happy Birthday Bro. have a blast
What Is The Comfortable Car, Ae100 Or Mazda Butterfly?
For me Its Ae100.we used a Ae100 selimited gold badge one. Superb interior comfartable seats touch a/c all the things were there. but it was bit bad on fuel.
My Car Makes A Clicking Noise But Won't Start (Starter Motor Not Working)
+1 if the battery terminals are ok ( this is a DIY job) check your battery energy. you can get help for this from the nearest battery shop or electrician. if battery is ok then check the alternator whether it's functioning well & check any faults in your stater motor as well. may be some brushes are worned. better if you can check these things with a auto electrician.
Help On Nissan Sunny Fb14
yes from 3rd to 2nd the it's not there. once i show it to a mechanic he informed me to do an EFI tune up. anyway am going garage this week & let you know. Thanks.
my bad today clutch start to slipping suddnly. feel i need to replace the plates. update you guys by thursday after meet my mechanic. thanks & have a great week a head.
Chevrolet Cruze Touch A/c
when you turn the key to ac on possition is your blower fan working? or nothing ?
Seeking Advices To Select A Car
Well come to the Auto lanka Forum !! As per your post i have undestand that your looking for a car with fuel efficient,comfartable for around 2.2m. with in your list i can say you can easily go for a Nissan FB15 new shell model. if you search you could find a super saloon one with early K no. N16 also a good selection but when considering about kmpl Fb15 is head on these. search for a well maintained car & better if you can go with some one who experts in this area. Good luck.
- Need To Buy Remorte Key Security System For My Car -Guys Please Advice
Toyota Corolla 110Details
Yes it's one of the very best product of toyota as i can see. as other's state yes it's a toyota one & nothing to worry. parts are freely available.average fuel will be around 14+. as nano31 state search for a XE saloon limited or SE saloon limited or higher grade one. when 1987 Ke72 is worth now more than 600K after 15yrs & Ae100 which is yom 1992 worth now more than 1.3m after 20years dont worry about the reselling prices. Search in forum for more details. Good luck.....
Vehicle Nissan FB14 ODO 187000 Transmition Manual Hi all, Need some asistant to sort our a problem which start from today onwards on the above mentioned vehicle. when i change the gear from 1st to 2nd it starts to knocking the car for 3-5 seconds.this is happening only on 1st to 2nd gear & 3rd 4th & 5th gears are changing smoothly.no any jercks at all.if i accelerate like i need to go for race this is not happening. is this indicates about a EFI tune up or some kind of service\replacement in distributor. since i recently buy this no idea about the prevoius serive records. please shade some lights. Thank You.
- Bodykit Designer In Kandy......
Diesel Car Around 1.7-1.8 Million
well with closer to your budget it reminds me CE110 LX verstion one.i have seen some cars with 65- #. CE108 & SB14 also with in your budget. these will cover your first priorities but your need be very carefull when purchasing one. serach for a well maintained one. Good Luck.
Fb14 Shifting Problem
Do you feel any Knock while on D?
GayanR !! Hope you have solved your Car Bogs Down At High Speed problem? when was your last auto gear oil chnage? i mean the KM ? & when was the last EFI tune up?
- Corolla Se Saloon Antena
Where Can Buy Small Monitors
check @ tech zone
- Does Cherry Qq Have Fuel Consumption Around 11Kml ?
