nish1
Everything posted by nish1
  1. Thanks. Did not know such a diagnosis mechanism. will do a try
  2. Thanks for replying! Yes for other pules, this pulley do not have groves and the other side of the belt touches this? This cant be happen due to the new compressor ryte? Yesterday I put the new belt and today I saw this. Even the compressor is not perfectly aligned to other pules.. this case cant be happen isn't it? coz I saw smale alignment issue with the bottom pulley with the compressor..
  3. Hi Experts, Engine Belt not rotate in perfectly middle in the freely rotating pulley.as you see you can see the engine pullies and the the way belt going around those. I have enlarged the free pulley ,its not connected to any unit but helps to the belt I guess, The problem is the belt not going perfectly middle of the pulley and I cant imagine why was resiliently I had a situation my belt damaged cant find the problem. And when replacing the new belt I saw a small play on this pulley too. recently I replace my compressor and do not no whether is that the problem.
  4. Can anybody give me a diagram of timing belt pattern it should place in the car- I have already added it but im not sure of that "bass" has put it correctly...google a lot to find for my car but could not find..so if anyone knows it please put it in here..many thanks
  5. where can i buy in kolpit or bamba?
  6. What are the good brands for timing belt - 4pk1790?
  7. Hey I did not get you pal..I'm not that knowledgeable about what you say..
  8. Hey guys I see a small twist of the engine when it accelerate..is it normal or it try to rotate to the pulling direction buy the belt..
  9. HI Experts, I have an issue with my car its a vits scp10 modle. when I turn the AC on and accelerate slowly it generate loud like drrrrr.....it I push the accelerate immediately harder it I wont get much..when while I'm driving... Its not acctually the belt slipping but something else..What I earlier did was when this comes..I tight up the belt a little and it reduced a bit..but now thats not working. Is the AC off its not giving that louder.. Can't imagine what the problem is..Plz help
  10. Good One...I have never experienced the red indication but all the time I get the green when ignition on..So that's mean I'm safe..Ha Ha Ha.. Thanks Buddy..
  11. its start at every start and couple of minutes its disappears..bad writing
  12. its start at every start and couple of minutes its disappears..
  13. Every morning when I start my car it show me this high coolant tem warning..? why is it?
  14. Thanks Experts. For your suggestions and opinions So finally I have few question to be clarify.. 1.In my case will it be an electrical shortage or leak or something. Because of that I’m getting head/Dim giving low light? If so how I get it know. Checking voltage at head light by a multimeater will be the method? 2.So finally suggest me what bulb should I fix to my VITS –SCP10 head and dim with the configurations of the bulbs?
  15. Hi guys in my car its a vitz SCP10 model one. It has a new battery but it not very bright(no good light) at night when on head lamp/dim...I can't imagine what is the problem..can drive at night but only can visible 10-15 meters in front..
  16. Fuel? Comfort? handling? parts? Current market Price?
  17. As I know there are 3 modes in the wiper movement..the first mode not working in my car..what to check please help..? 1.move--delay1-delay2-move 2.move--delay1--move 3.move-move-move 1 one is not working others working fine..so eventhough there small rain had to stick with other modes..
  18. Guys..DO you know no anybody except Toyota lanka who bring those Item to SL/Colombo ...??
  19. Thanks Machang..I dont have idea about the agents.? what do you mean..you mean the Toyota agents in SL..My car is a Vitz ..So I believe you talking about the Toyota lanka ryte?
  20. Yeah.I know that place machan ..thing is it's just a piece in a role of beading..you know..what i mean..
  21. Thanks mate!! But problem will be able to get the originals..not just a beading for door..??
  22. Yes man..The drivers door outer beading badly damaged...I love to remove those and replace with originals or good quality beading with good finishing..(like originals)..I'm not pretty sure that will I be able to find them somewhere in colombo?? I know places where place these beading but those are not specifically suite for this..those like common beadings for any vehicles..
  23. Hi..guys I need to replace my car front door window beading out side and inside both..mainly the bottom edge beading..where the glass go up and down.. My car is a Toyata vits SCP10 catagory. I'm wondering whether can I buy the originals from somewhere or replace some general beading normally using for vehicles.? Please help me to find them? or good place to go me to get this done. Image attached! Thanks .
