Y3K
Everything posted by Y3K
  1. Y3K replied to Y3K's topic in MITSUBISHI
    Hi Guys, Any suggestions? Thanks,
  2. Y3K replied to Y3K's topic in MITSUBISHI
    Nope, it was reduced/ gone down after I tried the ECU training, which was posted from a pinin manual. So am going to try that out again n see..
  3. Y3K replied to Y3K's topic in MITSUBISHI
    Hi Don, Got a reply from them, it states that the part numbers are not available
  4. Y3K replied to Y3K's topic in MITSUBISHI
    Hi Don, Have already tried them, they took my order as an inquiry and thats it. It says inquiry accepted. Any idea on how to purchase from this site? Thanks
  5. Y3K replied to Y3K's topic in MITSUBISHI
    Hi Don, I tried Singapore as well, but the result was same
  6. Y3K posted a topic in MITSUBISHI
    Hi Guys, Need some help on locating a store to buy the following parts for a 4G93 GDI Turbo (Pajero IO GDI Turbo) Md971921 quantity 1 (Piston ring set) Md978156 quantity 1 (Gasket) I tried Panchikawatta (actually one of my friends did it), United mortors. They all are out of stocks it seems. If you guys know any other places, please be kind enough to pass me the info. Thanks, Yasindu.
  7. Car: Paj IO Engine: GDI Fuel: Petrol No.Of.Gears: 4 Acceleration concerned: A sudden kick donw (The down shift/kick down happens very well, it's the shift to the next gear i'm concerned with)
  8. Hi, What should be the engine rev for an automatic gear box to shift gear? Ahould it go up to 4k rpm to shift? Thanks,
  9. Thanks The Don, Rumesh88 for the information. Will certainly do this check before doing any replacements.
  10. Hi Rumesh88, with AC off and vehicle parked: Idle arround 900-1000 with AC on and vehicle parked: Idle arround 800
  11. jdnet, The Don: Guyz the values adjusted by unimo is as follows, TPS: 527mV APS: 1050mV Rumesh88: Yes, but only when the engine is idling when stuck in traffic. Yes you are correct. I'll perform the test you have mentioned and will get back to you soon. Thanks guys.
  12. Y3K replied to tombo's topic in General Automotive
    Watchman, The Don, MasterDon, Sylvi Thank you all.
  13. Y3K replied to tombo's topic in General Automotive
    Hi, couple of questions, 1. Doesn't applying the undercoating guarantee anti corrotion? 2. Once an undercoating is applied, is it bad to use high preasure when cleaning undercarriage? A more general question, Is Koswatta LA*GHS undercoating is good? They say they use 3M products, guarantees for 5 years and costs 13/- roughly Plus they ask for a whole day to clean the undercarriage, wait till it dry n apply the coating! Thanks,
  14. Hi Jdnet, Small misunderstanding, Initialy there was an issue, where at idle, the engine starts to rattle. The fix for that by unimo mechanics was to change the values as you mentioned. It wokred fine for two weeks, and after the two weeks, when idling at traffic, the engine starts to rattle. (Of course my guess is that the change of the values keep the engine rev on 950!) PS: rattle - the engin rev goes really down more than 500, but within seconds (sometimes take more than 5 secs) the rev comes back up again!) Will get exact details from unimo tomorrow on what they did, and thanks, for allocating your time to have a detailed checkup on the vehicle. Appreciate it a lot! Thanks mate!
  15. Thicker oil? The thickes in valvoline site is 20W - 50. Is there a thicker oil than that?
  16. Well mechanic says it normal, nope it's not related to A/C idle. Should I take it to a unimo service adviser???
  17. Thanks XBeat, will try it out.
  18. There's a place near thorana Jumction, between the starting point of the flyover bridge & the "Pirivena" when you travel towards peliyagoda from thorana junction. Easy to spot it (unfortunately can't remember the name but they seems to have most)
  19. Hmm.. this link says of an IAC, but is there any links that point to the location of IAC on throttle body and directions on cleaning it?
  20. Yes its cleaned and is working fine.
  21. Hi, The Don " idle control valve" = IAC right? My mechanic tells me that Pajero IO GDI does not have a seperate IAC, and throttle body does the functionality of an IAC valve. Yes, EGR valve was cleaned and I'm positive it was the EGR. Fixzit Yes I took the EGR blocking plate off, it has no change. EGR valve is cleaned, and will have a go at MAF sensor as well. Guys, is there any way to make certain wheather my throttle body works or not??? To tell you the truth I'm having nightmares with my dream drive, but with the effort I have spent 'n the knowledge I've gained, I'm reluctant to give this vehicle away , Always hoping for a better tomorrow. Please advice guys, Thanks.
  22. Hi Guys, Any special ways of tuning a Pajero GDI? I went for my usual mechanic, whose from uni mo, and for the tune up all he did was cleared the injectors, replaced the plugs, cleaned the throttle body. That's it. Shouldn't here be a process of adjusting the engine rev? When I inquired he said something about acceleration works electronically related to a magnet, but as far as I know there is a voltage sensor/or some acceleration equipment which captures a voltage signal and informs the throttlebody and other related components which supports to keep the rev, shouldn't that component be checked for the correctness of it's default value? (Which comes into play when engine is at IDLE) Please advice. Thanks.
