Strikeee
Everything posted by Strikeee
  1. Any recommendation for a good gym around nugegoda???
  2. I too facing the same issue from Sunday. car doesnt start at 1st time... this normally happens when starting after a quite long break( like 3hrs +) only occurs during the 1st attempt. Today, I check plugs, battery and air filter... and found out that there are some kind of a liquid inside the throttle body. Is this normal?? if not what can be the issue??? Il try to upload images of my throttle body Engine is D15Z4 ,EK3 exi
  3. Any idea where you can only get a front lip for EK3?? my front lip got crushed week ago, i tried many places but many said, if buy need to buy both front and rear... and some were expensive, like 18k for the front lip.
  4. Saw a Jaguar F-type today... with wpCAB plates in red color...
  5. not, this is not an electronic one, Its a unit which has a railings and there is a needle(or a connector) which can be moved along the railings where the switch's(in the dashboard that allow you to move it from cold to warm) cable connects. ( i couldn't remove it or take a good look at it, because its there right under the center console of the dashboard.)
  6. Any idea how to repair a damaged temperature control unit(not the electronic one) of an EK3 or any place where you can get a replacement??? Tried several auto A/C spots, but none gave me a satisfactory answer
  7. I have seen this type of a thing in one of Will Smith's movies call "iRobot" Btw, heard that a car got caught on fire today on Baseline road... cant it be one of these prius??
  8. Guys, Why it is not a good practice to changing engine oil brand?? Say for and example, you have used Caltex(10W -40) engine oil in ur previous service and this time due to some reason you thought of putting Mobil(10W -40) Is it because though the oil manufacturers have given specs, they are not identically same to one anther or is there any other reason???
  9. Strikeee replied to Watchman's topic in General
    Indicator on our premio once only showed me a figure like 21.5kmpl in southern highway and rest of the time, it ended around 16 - 17.5kmpl. Like VVTi said, there can be calculation errors Check this Top Gear video ( ) you can see a BMW M3 does better in fuel economy than a Prius when u driven then as fast(above 120kmph)
  10. I heard Aqua is not as economical as its big brother Prius... I as i can remember Honda recalls their Fit & Vezel not because those models didnt come with hill assistance but because of a problem caused by their Dual Clutch Transmission.(read more)
  11. As per my knowledge, if auction grade is "R" it says that the vehicle has been professionally repaired adhering to manufacturer's standards. So getting an R grade car wouldn't be a problem, unless that feeling you get of buying a car knowingly it has gone through an accident.
  12. This car is there in that particular car sale for almost a year... and this particular car sale has another green Jag, (i think same) under restoration. Check and see... He was asking 1.2 back in May '13
  13. I had the same issue with my dickey lid... tried almost everything... if the paint has faded slightly I think you can recover it... else you need to do a paint... and u dont need to do a full paint. You can just paint only that panel. Normal price range for panel would vary from 3500 - 7500. If you are lucky you can get it done even for lower price than that.
  14. I have done a full A/C service and some repairs near jubilee post, nugegoda. It cost me 6500 for service + for treat the gas leak it cost me 3000
  15. As per my knowledge, there is a normal key coming with every smart-key. Where in case if your smart key not functioning (ex: like when there are radio interference) So u have to use ur normal key to unlock the door. If it has a security system then u can un-armed it by using ur smart key once you are inside the car or there may be a kill switch hidden in the car. I might be wrong, wait and see for other experts replies.
  16. I will be in the marketing side... who come up with advertising concepts. Is SPAACs good?? or do u have any other suggestions?
  17. Hi all, I am really in to branding and advertising... So thought of following a course. I found out 3 but with the time constrain I can only follow one, which is offered by an institute call Sri Lanka Professional Advert*s*ng & Creat*v*ty Sch**l. So if any one knows a better place to get formal education on this field please let me know... Cheers
  18. Any idea about what type of Spark plugs should I use for a Honda Civic EK D15Z4 engine??? is it NGK ZFR5FGP or any recommendations
  19. I say, Vitz is a boring car... and if you are buy it assuming that it will do good on fuel... then u are wasting your money on a car which is totally worthless. And what are the proves you(or seller) have to say this car is accident free?? Do a research...you can find some threads in the forum also.
  20. You cant say they are cheap. If you want to get a good job, it will cost you a pretty decent amount.
  21. Two is a default number. Sometimes, car comes with one, these are for imports from Japan(used)
  22. I edited it again.. :-) Thanks bro
  23. Hi all, I thought of sharing what I have found(not something new) but, I think most Civic EK owners dont know(I might be wrong, but people I talked didnt know about it) So this all begins with me experiencing that my EK3's clusters were barely visible at night, stock back-lights only light up the numbers of all dials and not having glow needles make it hard to read where the needles are pointing at night, specially, the temp needle. At 1st I thought of fitting a glow gauges, but it didnt feel right, so thought of upgrading the stock bulbs with LEDs and followed the instructions of this youtube to remove the cluster panel.Cluster panel was back-lit using 2 - T10s and 3 - T5s, so all you have to do is replace them with relevant LEDs. (If you are buying LEDs, go for SMD 5050 insted of SMD 3528 which has high intensity of light) and during this process, I found out that, my civic's cluster panel has a front lit system, which allows light coming from front of the cluster panels, and enables to read all clusters. It has 2 T3 bulbs (I marked the place by arrows in the pic in below link) Pic one So this is how it looks like at night,(pic is not clear, but, its really clear for naked eye) Pic two Pic three And I learned it in the hard way, because, my T10 LEDs were SMD 5050 while T3s were SMD 3528, thats why you can see there is a difference between the brightness. So, by changing these 2 bulbs will increase the visibility of you clusters and you dont need to spend like 6k to go for glow gauges. Cheers And sorry if this is something which is a well known fact.
  24. and sira, if you are replacing, replace with one type, either whole set be genuine or vice-versa.
