anonymous
Everything posted by anonymous
  1. generally ˈdʒɛn(ə)rəli/ adverb adverb: generally in most cases; usually. "the term of a lease is generally 99 years" synonyms: normally, in general, as a (general) rule, in the general run of things, by and large, more often than not, almost always, in the main, mainly, mostly, for the most part, in most cases, most of the time, predominantly, on the whole; More usually, habitually, customarily, standardly, routinely, regularly, typically, ordinarily, commonly, conventionally, traditionally, historically "the summers were generally fairly good" antonyms: occasionally
  2. Dude, Its not what you drive that causes accidents, its how you drive. If a person buys a Cherry Q or Maruti and try to drive it like a BMW,AUDI,ACURA,TOYOTA,LEXUS,MB in wet, then its his fault. BTW you are the same person who went on to blame the government when some guy fixed an extra diy petrol tank to a van and it caught fire?
  3. I think we all know what you are gonna choose from 12-14 year old jap and Aqua.
  4. Kandy + Honda = Priyantha @ Mawilmada (Honda Priyantha). I dont own a Honda but i have been at his place for day-to-day repairs. Good fellow.
  5. i use Sport Lemon (http://www.frombar.com/) and its pertty ok... only issue is sometimes the channel gets banned and you have to find another channel within sport lemon. Quite annoying if it happened 10 seconds to start
  6. All he needed was just one reply (from Sampathd) to clear out all KIA SUVs that there are no technical issues... WOW
  7. Damaged inner/outer weatherstrip Blocked drain hole at the bottom of door Damaged waterproof film between door and door trim
  8. Thanks guys. MkX pls update me when you get the info from the person.
  9. Guys, Did anyone got down a mobile phone thru eBay? Do i have to go collect it from colombo or will i be able to collect it outside colombo, lets say, kandy?? Coz 1 item i orderd from ebay (not a phone) got held at kandy post office n i was able to collect it from there. For mobiles you have to get approval from TRC and i donno whethere a TRC branch is available at kandy Thanks.
  10. Assuming its 800 ml of air per min: A 1.5L 4-stroke engine idling at 600rpm uses 450L of air per minute. So additional 800ml per min cant do that much of a difference right??
  11. If you have the service manual with you it will say what type of a battery should be used. Required amperes Cold Cranking Amperes (CCA). Select a battery equal or greater than the mentioned CCA. (I'm not sure how imporant the CCA is in SL but better to be safe than sorry I used a Exide for almost 3 years and now using a GS
  12. Best overtaking move of the race IMO - http://www.youtube.com/watch?v=lJ-Dfbowv0c (Kimi vs Schumi)
  13. According to the site anything between -2.5% to +2.5% is OK. Since you are going from 185mm to 215mm maybe you should check if the tyre isn't rubbing against car when taking a full turn.
  14. Errr.. correct me if im wrong. stiffer shocks = feel every bump on the road isnt it???
