Everything posted by CAR_MADNESS
Daihatsu Terios Or Toyota Rush
yes you are rigth. Dihatsu Teriose also requires octane 95 or Euro (93) octane. Dihatsu Manual says 93 octane or Higher. I used only 95 octane. But local agent says 90 octane is also fine.
Hi....I have used a Dihatsu Teriose 2008 model. The vehicle is ok. But it is just a basic vehicle with p/Shutter, P/Mirros and central Locking though it was a fully loaded when compared with a JDM model when compared to Rush . Rush has Winkler mirrors, TV navi , Climate control A/C, Leg break (not hand break) while teriose has normal hand break I used it for 35,000km did not give big trouble though there was a leak in the ATF Sump when I took it to Agnets they found that the packing was not fit properly. Safety on teriose id good.I can see 2 ari bags on dash board tought it says 8-Airbags. May be there are. ABS..HAC, DAC ,(VSC, LSD - are avilable only on teriose - not on Rush) Teriose is 4WD and Rush is 2WD. Bego is the JDM of Teriose 4WD. about the Steering issue with Rush yes I have to accept that it is true B'coz there were many Toyota Rush @soft_logic for steering repair when i enquired they said that some Rubber seal is going out of order in them...no clear information tough. Terouse was not very comfy on normal road, Steering was a bit rough. the A/C is not as cool as on JDM vehicle. Now of course as I heard that new teriose has the same as JDM rush A/C. Finally I can't support Teriose when it comes to the fuel consumption of about 7-8km/l with 1500cc engine. this is unforgivable. But as I heard that Rush has much softer suspension and EPS which makes the vehicle much much more comfy with an added resale value. Just GoogleCross over’s and SUV'S. Dihatsu teriose is a cross over while the Rush is a SUV. Bt plz remember Cross over’s and SUV are two different categories where Cross over focuses on heavy duty rough roads and SUV is of similar to new version of Station wagon comfy and to be used on good road conditions what we mostly will be using a vehical for.
Autolanka Funniest Moments
he he ..may be u missed the No entrance Sign at the entrance
Ignition Knock
Hi, I hope during the tune up they changed your Petrol Filter if not Vehicle may knock due to this also. Try using 95 octane form (I_O_C) and just see it may solve yr problem. Try not to mix both 90 octane and 95 as the chemical content is different compared with the 95. you may refer to http://www.lankaioc....ec/Petrol95.pdf. Just let us get this straight Does the Knok occur when you press the O/D button and it light is ON the bash board or when you press the O/D and OD button is OFF on the dash board. How do you know that your gear has changed to over drive? or may be vice versa ? - (please do not consider it as a dumm question)
Noise When Steering
NZer let's say you are correct for hydrolic system. I agree with you that a sound will be there. But as I think Axio and vitz they do have almost the same type steering. That means EPS. and EPS is not assied with hydoric. So what you say may be not relevnt to EPS.
Noise When Steering
Dude gud one ...though when it is lock you even can't turn it. I guess he ment when he is keeps vehical still
Corolla 121 Fuel Problem
As I understand in your vehical you have a RPM meter. SO you can check this. on a vvti engine optimal gear changing RPM is 2500 rev/min (this is ideal but @least aroung will be fine) so you can check when the vehical is about 60km/h RPM it should be around 1000 rev/min to 1500rev/min if your gear box has no any problem. please do the needful to your vehical . An engine oil change every 6 monts or 5000km which ever occurs first with genuine T*y*ta oil and oil filter. There is no big price difference compared with the other brands.
yes Bro.... for a 121 with 1.5 l engine is abit low. It does about 11-12km/l in city
Noise When Steering
Hi Shan, I had a similar problem with Axio. I took it to car c(a)re Babalapitya. The same way when driving no issues but when the vehicle is still and if you turn the steering a strange noise comes. Just they lubricated the horn bracket with a heat resistance grease (the pink color one ). Maybe you have the same problem.
Please provide with the following details as well. 1- What is the Engine capacity ? (1300cc, 1500cc or 1800cc) as 121 has all these three types of engies though 1500cc is the most common 2- is it a domestic model (imported recon. )? or purchased via local agent brand new ? http://web-cache.stream.ne.jp/www09/toyota-catalog/pdf/corolla-3/corolla-3_200008.pdf Check out this ....
Check Engine Light Blinking
Yes I have to agree with razordj , by this time 1995 AT 192 should have done above 200k usually on a toyota oil starts to burn about 250k. Just you may ckeck with the fume color. If it is blue or similar that means the Engine oil is leaking past your piston rings and getting into the engine cylinder and mixing with your fuel and during the combustion it gives blue smoke. Then I have tell you my friend its time to change the rings set. if it is not the case then most probably you will need a engine tune up. But I think best is to show the vehical to the Agents and get thire opinion.
Vitz Vibration After Loose Battery Terminals
Hi, I am not expert but usually you should remove the (-) negative cable before removing the positive cable and when re-connecting first you should connect positive and then finally negative in order to prevent any possible damage caused to electronic and electrical Items. Check you RPM it should be around 750 rev/min when idling. Try starting the vehicle without switching ON the A/C and check whether this exists or not? If the check engine button is not displayed probably there should be nothing wrong with the ECU
