harshansenadhir
  1. On contrary, requirements are stringent on diesels simply, the tendency of a diesel failing the test is high than an EFI petrol goes through the test like a charm.
  2. I thought this was there already. Some friends got the revenue license for old cars and few J44's without any issues soon after the new emission standards were enforced.
  3. more than potty, I see cataloy layer in the entire panel and it's visible as tinkering work (heated area by the torch) revealed the metal. Better if you can get rid of cataloy coz chances are high that old cataloy might pop out bubbles when you spray the new paint or afterwards. If your tinker guy is extremely capable, then ask him to make a panel/fender. I've done this when I was restoring one of my 504s.
  4. the generic ATF oil and Power steering oil are the same.
  5. Durians would've got crushed if one of those other drivers decided to change directions all of a sudden.
  6. impressive to see the work in progress. Few points I would like to draw your attention at. 1. Finished quality of the wheel arch could've improved further and I see some body filler (cataloy?) in the fender. If possible take them off and try to get the body lines on the fender without using filler as much as possible and use very little amount of filler. 2. Assume you've re-fit the panel for accuracy specially to see how head light surroundings lines up with the fender as one side of the head light surrounding is the front part of the fender. If not, re-fit for accuracy and do apply fillers with the panel fitted to the body. minimizes re-work always. 3. saw a crack on the inner line of the wheel arch (last picture towards right side of the wheel arch). Try to solder it using lead or just heat and bond both ends of the crack using a oxy-acetylene welding gun. judging all this by looking at pictures, so chances are high that I'm wrong in my assumptions but point to ponder is in restoration, always look for minor details. That will definitely pay off the efforts better one day.
  7. Belated b'day wishes DD, wishing you a year ahead with spree of winnings.
  8. as usual on the mobile and it's hell to upload, may be we'll wait if terrabyte has something to put up
  9. yeah, that's the model I meant, wasn't exactly sure whether it was Brava or Bravo . Now where's the poster?
  10. Fiat Bravo ?
  11. not quite sure on that, the sealed ones I've come across were filled with gel. Further I'm personally not happy with them and moved back to the old school method. Liquid type with regular maintenance, that is
  12. flushing of power steering fluid would be recommended if the fluid is blackened and it has lot of metal substances (dust like small pieces when you closely observe). Otherwise you can mix it with any ATF/Power Steering fluid for topping up. However, best is to avoid cheap brands mushrooming around but it's completely my opinion and how I choose ATF/power steering fluid. It's more important to see why the level got dropped. Since you're new to the car, top it up and observe the system, garage floor for leaks and check the rate of dropping. By doing this you can determine if it's a considerable leak or a minor one. If it's a considerable leak you have to get the complete system checked or if you can find the leak, get that sorted out. If it's suppose to be a small leak, negligible, still try to find out from where it leaks, sometimes the oil seals in the both sides of the rack causes small oil leaks. This is something you can decide whether to live with it for sometime (if the leak/loosing of fluid is negligible) coz there's hardly a lasting cure for this issue than replacing the rack.
  13. sealed types are generally comes with a gel instead of liquid, so they goes as maintenance free as you don't have to top up/maintain the fluid level. I don't think it can be topped up.
  14. the later version of K11 known as cup holder model has EPS and some are converted back to hydraulic rack 'n pump system, rather the conventional power steering. with all due respect to what all have pointed out, try to relate or isolate this scenario, like when this happens, is it totally illogical and irrational or you can relate any other symptom or incident to it for an example the engine shudders at the same time or it happens when you apply brakes or something. Then the chances for a better diagnosis is high. I personally believe this could be as simple as loosen battery terminal or as someone said a loose connector in the EPS system, or it could be the worn out brushes of the EPS motor, a general/common failure point of motors.
  15. Short trips explains why it will not get charged properly. Get the voltage readings of your battery on following scenarios and post here. 1. Idle running with all accessories switched off 2. Race the engine to 2000 rpm with all accessories switched off 3. Idle running with A/C, Lights (high beams) on with blower fan in highest possible speed. 4. Race the engine to 2000 rpm with the accessories on in step no 03. by reading the voltages the guy at battery dealer himself would be able to tell you whether your charging system is faulty or not. This will be another factor in identifying the reasons for shortened battery life as you feel.
  16. +1 and to add to the list the A/C working full time and most of the time engine is idle and stuck in traffic jam. The best life I ever got from a battery is 2 years and couple of months more that's it. Usually all others gave up just after warranty is over, say 14 months sometimes.
  17. if it only comes when you step on the brake pedal then it can be something very simple like burnt out brake/park light in the rear light cluster (in some models) or it can be worn out brake pads and it's metal part barely touching/rubbing against the disk.
  18. Happy Birthday Master Don. Wish you a happy year ahead of motoring and what not!
  19. harshansenadhir replied to kumaras's topic in MAZDA
    thought hydraulic system will get more softer when the master or slave pump is about to go. Simply due to the fact that it requires to travel more to achieve pressure to activate/push the pressure plate so it extra travel make it more lighter, at least that's what from the experience I had. Whenever clutch feels softer (in hydraulic) it gave me goosebumps as I knew (and was always) it's the washer/piston time.
  20. harshansenadhir replied to kumaras's topic in MAZDA
    it's due to either the clutch cable has worn out and grips against the outer heavily or the pressure plate is old and splines have become toughen to depress. First take the cable out and oil it and see whether it improves or replace it. The easiest first.
  21. usually what holds an auto from going backward in a slope is brake bands if the pressure in the torque converter is not sufficient to keep it pulled.
  22. how did you try to engage the gear first of all? on a stand still or while moving the vehicle in a slow speed ? did you try to engage it with a clutch engage disengage jerk ? It worked with me with a slight jerk and it was never an easy task. Between H2 and H4 it was easy and you're suppose to change it while going at an average speed but L2 and L4 is something you have to try in a stand still or while jerking with clutch on and off.
  23. nothing wrong with the ATF. Your brake bands are worn out. Get an expert to repair the gearbox and replace brake bands.
  24. oh, crap. I'm sorry to hear that JD. Hope you'll get the things sorted out soon
  25. harshansenadhir replied to Willy's topic in General
    did you check the interior of this? go around and take a good look at the interior of few vehicles, you'll give up the idea. Plastics are crappy and it tends to crack very very easily like egg shells. I don't know whether I'm wrong here to generalize but the I had close inspection of two specimen's and both had the same issue and it was quite evident. Only thing I noticed was A/C was blowing ice cold in my friend's car I've been. No hands on experience about the mechanics and electronic related stuff though.
