Seat Belt
supposedly depending on the way the modification is done. If it's done in a way that there's an open circuit, yes it'll detect.
Motor Bike Restrictions
+1 on your post and on above, you got to be kidding
Seat Belt
good advise and small correction, key should be in ON position instead of ACC. Further, But I've came across a more smarter way someone had done this, that was to couple a timer relay to the air bag light so even if someone keep the key in ON position still the air bag would go off but I heard a click sound every time it goes off and that's where it got caught.
What Things To Check When Buying Corolla Ce110
YOM 97 means a 13 years old vehicle, therefore running a comprehensive testing procedure will always be beneficial. Check all around the body for accident repairs and corrosions. I meant by accident repairs aren't small scratches, but large dents repaired with inferior quality work, excessive use of fillers, imbalances in the body shell as a whole. Pay more attention for the integrity of body than engine as engine can be even replaced with less hassle than trying to sort out issues related to body. as for engine, check whether seller had recently washed the engine bay, if so start your inspection with bit of a suspicion. Check for marks of possible oil leaks whether there are any oil fumes like haze marks underneath the bell housing and underside of the engine. If found any and if they're from tappet cover packing and sump packing it can be a minor repair. But if there are any marks found elsewhere (from gasket, bell housing, t-belt cover it might demand a bit of lengthy repair). Check engine mounts specially coz it's a diesel and prone to vibrate more than a petrol. Make sure to go on an early morning to inspect the car and gauge whether the engine had started and therefore hot when you open the hood/bonnet. If so I would suspect for under compression/possible starting issues and that's why the seller had started it early in the morning. If it's cold and seems like not started in the morning, you can try to crank the engine, before glow light goes off (not recommended for daily usage, only for this test) Then gauge how well engine came into life. Whether it puffs any blue smoke and you can sniff and smell of unburned diesel. Possible signs of under compression as 2C/3C engines are popular for the fact that they can be started even in the morning without pre-heating, provided that engine compression is good. Soon after the start check whether engine hesitates or vibrates excessively, if so possible signs of weak injector pump idle circuit/injector nozzles/under compression. someone mentioned the breather hose checking and further take the dipstick out while engine is running and try to gauge the level of smoke, oil particles comes out from that. If it's small amount of fumes, that can be accepted but if it blows excessive amount of fumes together with oil particles then it's nearing an overhaul. Give it a trial run to gauge the suspension system, may require some amount of experience to gauge suspension issues from a trial run, so take an experienced friend rather than taking a baas fellow, who will take some bucks from the seller and recommend the vehicle to you. more importantly check whether interior is deteriorated and cracked. door panels and dash board material of this model are known to fade. Check whether they're faded and cracked and peeled off. Simply it's very hard to restore the originality of some interior components like dash board. hope this helps and if I remember anything further, will edit this post.
As you correctly said import is not restricted provided that you get some special permission and show the purpose of importing. This doesn't include the ones being brought down as bits and pieces and re-assembled somewhere in north-western I heard that some cops/cop sheds have this device which can stuck to the exhaust and it'll indicate approximate engine capacity. Never seen this and yet hard to believe our guys are that sophisticated.
Import Tax Slashed By 50%
there's one main reason as to why second hand market doesn't crash and second hand vehicles have a demand unlike other countries. That is government policy creation still favouring second hand/used/old vehicles. If the policies are such that to demotivate a person from buying a vehicle older than 5 years, say by having higher revenue licenses for old vehicles, introducing strict fitness tests and tag as classics and remove from day today use when the vehicle is 10~15 years old, yes then there's a possibility to divert the demand from second hand market to brand new/un reg market. As of now it's the cascade/chain impact what you have mentioned. Lower the price tag of the used vehicle or in another words higher the price difference from brand new prices vs the price of used vehicle, then there will be minimal or no impact on the respective second hand vehicle prices. one of main reasons for auction prices to jack up is the YOM limit our country has, that is 3 years plus not every model is popular here, it's only a handful of models people would choose to import even from infamous Toyota brand. So it creates a niche market for said makes/models.
we never know it'll crash in the next few months to come don't we ? so better wait and see. Further, it's going against the theory , you know it's a weird market end of the day where depreciating vehicle is an investment tool.
Cannot Slow Down The Idle Speed !
Adiós, yeah simple things first. This can be tested by checking the tension of the cable, if the cable is tensioned when the pedal is in idle position, yes that's a possibility.
any other economist to explain as to why prices hadn't dropped and market hasn't crashed yet.
I think he mentioned this idle up bolt is set to the lowest and still the speed is higher.
Bmw Owners Clubs In Sri Lanka ?
In-tank solutions will not result a sudden emit of carbon particles unlike when the engine is running on the cleaner. Have you seen how smokey is the exhaust when running from a cleaner? it removes certain amount of carbon deposits inside the chamber and on the valves as well. These particles will healthy for the honey comb of the cat.
Give Me A Real Answer By Experience
Search around this forum to see what are the responses given for fuel consumption related threads. Fuel consumption is something we can't generalize by the model, it's more of a vehicle + driver combination plus various other factors. I for once never get good fuel mileage off from the most fuel efficient car, flooring, redlining, thrashing if you ask why . Since this model (should be orion engine) is equipped with a carburettor based engine, fuel consumption may vary based on the carburettor ratios (air : fuel) depending on the condition, ware and tare of the jets inside the carb. I used a tube light version in 1999-2000, which had a 1400 Orion engine with a screwed up carb and GAS converted. Only squeezed out 12 kmpl from petrol in city and 9 or 10 from gas. Out stations it did fairly well, somewhere close to 14kmpl. However, this may not be the best example to compare your figures with. Try to find out exactly how much it does and get a good mechanic to see whether tuning is optimum. A well experienced guy will sniff how exhaust smells like and would predict what's wrong with the ratio.
Hyundai Repairs
Yes, just about 50 meters passing Papiliyana junction towards Boralesgamuwa on to the right hand side of the road, very hard to miss that one.
too early for that, he still got another 14 calender days for that...
This is a killer for a cat IMHO. It emits lots of carbon particles and excessive amount of chemicals in one go. This amount can be equivalent to the emission gases goes through the cat in few years or so. One time blow up of excessive carbon particles would result in block the cat and reducing the effective reacting area of the cat. Further, it'll put all dirt/build up on injector lines inside to the combustion chamber at once, don't know the impact what it might cause.
Peugeot 406 D 2002 Prices
withstanding corrosion and heat (interior materials) doesn't necessarily mean that they're of high quality. Sometimes it could be a plastic dashboard (which doesn't crack) instead of padded dashboard found in JDM version Compare interior of a brand new 121 brought through agents and a JDM, you would know what I meant. Further, I learnt during an engagement with one of agents that, export versions to countries like us are built on a plant outside Japan and material/component used are of quality category B.
Things To Do When Buying A New Car
search around this forum to see answers given for similar questions. What sifan says is valid as it all depends on the mileage and the condition of the vehicle. If the mileage is genuine and is less than 20k then don't worry about an atf change at this moment as it might contain original fluid which can be used for little longer. Also check air pressure of tires as once we got down a townace and we ran around few days before realising they had 70psi rear and 45 on front. Way too much for our roads. Are you buying it as recon or as it is? If it's as it is and had been on the ship deck for long, suggest a through body cleaning and a cut and polish job.
Radiator Fan Directly Coupled To The Supply
it's the first spare part shop can be seen to your left hand side as you proceed from maradana junction towards panchikawatta. Right opposite the color lights.
it's slightly different from the jdm story as export models of most of japanese brands are with lesser build quality than the jdm and built in a different plant. Yes, executive version offered to tropical countries without sun roof.
what he said is partially true as there are differences between 406s brought through agents and uk used ones. Suspension system (not shocks) is rigid and suits rough terrains with higher ground clearance and a thick metal sump guard of the ones brought through agents. Further there are executives brought down through agents but for some reason those are minus the run roof. Its not only glx model came down with tropicalised and rough terrain suspension.
Catalytic Converter
foul results could be due to the chemical burning with fuel. Therefore better to ask someone to run the vehicle till that chemical mixed tank full finishes and then to run with a fresh tank of petrol and go for another test before panic and proceed further with diagnosis.
i'm not quite sure what you meant by 'D' is it diesel or D9? This is one of late model 406s known as 'com' model in the market. If this is a diesel (can't be 2000cc though) this price tag seems worth. But for a petrol its way too much. Having said that if it's maintained to that level and has low mileage as you mentioned worth going for it with a further bargain of couple of hundred thousands.
good to hear that you found the relay and further that maka baas hadn't tampered the original wiring. Before you attempt to restore originality of the engine heat exchange circuit, check whether radiator top tank related damage is fully sorted out. If not, it'll prone to leak or burst again when fans operating based on the sensor input. Because it'll create more pressure in the system than when fans are engaged on full time basis. Check the sensor whether it sends the signal at manufacturer recommended temperature, 95~98 degrees in most cases. Asiri motors would have the required parts
What A Funny People We Have
you're repeating the same thing what i said and suggest reading the posts again. I didn't say it'll spoil as much as a spoiler. But shape change due to roof scoop will certainly increase the drag coefficient, there's no two words about it. Well said about rice buckets. Thumbs up for that
it's good for a vehicle which has a curved shape body where it can tend to air borne at extremely high speeds where M800 can't achieve and I said it already indicating it's additional drag is a burden on the 3 pot plant it has. Again it's up for personal preferences, his car his money.
