harshansenadhir
  1. Never compare brake pad changing intervals of a prius and a montero. Prius has regenrative brakes which reduces the strain on brake pads. Montero sport is fairly a heavy vehicle and has quite lot of torque and power. If someone's thrashing out it and unleashing that power, simillar effort is required to bring it to a complete stop. I don't deny a possibility of these vehicles getting (may be a driver is involved) inferior quality parts. May be agents fix the originals and someone changes back to inferior quality ones and sell the good ones off. you never know. But as an owner of vehicles i'm happy with a set of good quality brake pads, even if it wears faster compare to substandard brake pads which don't wear but make the disk to wear off faster.
  2. its between the firewall and where the right side / driver side top mount (of the mcperson strut) is fixed. it should be engraved to the panel between this metal plate and the top mount
  3. the same happened in a known 406 diesel (not the HDI version) and what caused the t-belt to worn out was a crack in the crank pulley. This crack tends to bit the teething of the t-belt which cause it to give up prematurely. best thing to do is closely examine all the teething geared pulleys involved in t-belt mechanism and if possible, get it tested by some reputed place where they can detect cracks (either using x-ray or uv) in cyclinder blocks. also check for possible worn out / damaged rollers in the mechanism.
  4. try the usual method of finding whether the primary fuel pump is faulty. When you're expecting the car to have this starting delay (when the engine is hot etc) switch on the ignition, wait for about 10 seconds, switch off and repeat this process for about another 3-4 times and crank the engine. If it starts without any delay most likely the fuel pump and/or pressure regulator is faulty. the other possiblity most likely is the ignition coil pack/packs.
  5. fuel consumption may be increased as smaller tire needs to rotate more and hence high RPM of the engine to cruise at a certain speed. this is other way around machang as increased profile means higher circumference of the tire. Therefore it’ll rotate higher distance than the smaller one in one rotation. Speedo meter only knows the number of rotations of the wheel (in ABS models) / final drive (non ABS models) ; therefore your car will be traveling at a higher speed than what it shows in the meter. very well said ..
  6. engrave the number through RMV approval at government workshop
  7. it should be engraved to the chassis itself, may not necessarily around engine bay area. For instance, Peugeot 206 has it engraved on the floor/on a plate as you open the tail gate. following link would help http://vin-numbers-location.weebly.com/hyundai-atoz.html
  8. agree with Don. it may be mis-aligned or there's a problem such as pistons not returning properly which might be causing the unusual wear and brake binding
  9. if you haven't changed transmission oil in 100K , then there's a high possiblity of this getting resolved once you do a transmission oil change. A manual tranny wouldn't require more than 2 liters in general and costs a dime compared to an oil change of an auto. so without wasting more time on obtaining online opinion, get an oil change done and see the difference.
  10. another way to find out is, when you do long cruising in a constant speech without much load on the engine, the temp gauge falls down unusually. all in all, if the thermostat is in, then temp gauge should rise up to middle mark very quickly and stay steady there regardless of the exterior conditions.
  11. when did you last checked/changed spark plugs?
  12. any possibility of finding a similar working temp sensor ? if so do this test. remove the socket from existing temp sensor fix it to the test temp sensor give a (-) supply to the body of the test sensor. if this activates the relay and stops the fan, your existing sensor is faulty. if this test proves that there's nothing wrong with the existing sensor, you can proceed with finding the issues in the wiring loom.
  13. too early to give a complete judgment of them as the reputation they earned in the past was not quite good and that was one of reason for us, Peugeot owners to stay away from the place. However, having some positive hopes about the new guy who is in-charge at the workshop and the recommendation i received about the fellow was the main reason for me to try agents after so long of owning Peugeots. one word of advice, ask from them whether all the parts required for the repair are available and get an exact word from them how long they need for the repair. In my case, they had all the parts in stock and they completed on time.
  14. if you search with the name of the agent in question, there would be about 10 relevant topics. to highlight a few.. http://forum.autolanka.com/topic/14873-carmart-servicing-poor-quality-of-service/?view=findpost&p=233398&hl=%2Bcar+%2Bmart http://forum.autolanka.com/topic/14924-paintless-dent-repair/?view=findpost&p=252834&hl=%2Bcar+%2Bmart my actual experience was given in the first topic, as crosswind said it was completely upto my satisfaction, quite contrary to the popular believe and also to my perception about them prior to the repair.
  15. nomally closed and open by the temp signal is usually the mechanism i've seen in euro models but most of the japanese fan mechanism i've seen otherway around. Don't know exactly how it works in 110 though.
  16. Rumesh, as i understood the issue is the fan works continously and that means the live supply towards the relay is there and it's given to the fan by bridging the relay mechanism. The coil of the fan relay magnatizes when it gets live supply (ignition on) and ground supply (from the temp sensor). Since the wires from temp sensor were removed, there's no way relay can be activated though the live supply through the fuse box is available at the relay socket. correct me if i'm wrong.
  17. brand new? in SL ? most likely not and even if available (through agents) it'll cost a fortune. Turbo charged 2.5L (4D56T) came along with Pajero V35 (as known as computer body in SL market) so you should be able to find a used one imported from elsewhere.
  18. take it to a spin with A/C switched off (engine would run hotter this way than when the A/C is on and auxiliary fans are working all the time) and see whether you can hear the sound. If you hear it, shut off the engine and see whether sound disappears all of a sudden or gradually gets reduced. If it disappears suddenly, it's a vaccum leak somewhere, brake booster vaccum line and other vaccum lines and IDC valve in the throttle body to be looked at. however, if the sound faints as time passes from the point of engine shut off, that's a sound of a pressure leak in the engine cooling system.
  19. What will happen if you pull out the relay. Check whether there is a bridging wire on the socket of the relay, you will see this if you pull out the fan relay. My suspicion is, someone had removed the wire from temp sensor so it won't send any signal to the relay and to make the fan working all the time either from the relay socket (easiest place to bridge and supply 12V live supply all time when ignition is switched on ) or elsewhere some bridging has been done.
  20. matching one with better performance would be 4M40T as it can go into L200 with minor modifications. Intercooled turbo charged with 2.8l, hence better performance than 4D56 (N/A 2.5l). However, 4D56 is a better engine than 4M40T in terms of reliability and wear and tear. Therefore, you can consider 4D56T (turbo charged, 2.5l) as well.
  21. true.. and pricing information I gave might be useful for someone who reads this thread.. agreed crosswind.. in fact I reported it too.
  22. hmm.. makes sense but would he be so obvious then? with that name openly? anyways no harm in replying with what I know
  23. Brand new prices would be insane.. when I checked back in 2006, agent quoted 140k only for the ECU. Price of the BSI usually floats around 70-75K. In this case you're at the mercy of used spare parts dealers who bring down these bits and pieces from UK. Did you search around usual Peugeot spare parts joints around Panchikawatta? There are quite a few places which stocks used Peugeot spare parts. If you can't settle with the prices panchikawatta guys quoting, then best is to weekend newspapers, there are many individuals who brought down parts of a single car or few spare parts from UK
