So I replace my rear brake shoe’s 4 months ago. After few weeks of driving the rear left side started brake binding. I took the car immediately to the mechanic who put it together and he told to use the car a bit more for the new pads to get ‘seat’?
The problem became worse so again I took it the mechanic after 2 days. He then sanded the brake shoes and fixed them up again and the problem was solved temporally. But the binding kept happening and all he did was sanding the liners. in the meantime i did take the car to two other so called reputed places but none of them found of the problem either.
Last month after month of frustration I again took it to my usual mechanic again and he checked everything, pistons was okay, springs, bushes, hoses everything was okay and nothing was wrong with the master pump either,but he couldn't find a reason for the brake binding.
Today morning I took the car to the same mechanic and asked him to check the shoes/liners and voila, there were cracks and bits of pieces missing from the liners.
When I inquired from everyone 4 months back (mechanic and 2 of my friends who was working/learning in German tech) all of them suggested FBK and since I have used FBK for all our other cars before I didn't hesitate, although I usually buy these stuff from Toyota Lanka, I know how much they will rip me off for this thing. So when I checked in few spare parts shop and they told me there are 2 quality grades of FBK shoes. Good and normal quality. i bought the good one and turned out the guy has fooled me. So I ended up buying two good re-condition original shoes (which now I realize I should have done from the beginning since i couldn't afford from TL)
Just put up this thread as an awareness when buying aftermarket brands.
Mind you i have only driven around 350 - 400 km after putting the new liners.
Even the best branded brake shoes will bind and grip if they are not aligned properly.Judging by the pictures that seems to be your problem.I use the cheapest available shoes for the lorries and the Trooper.Apart having a high wear levels compared to expensive ones they run fine.I get 10-20 thousand kms.
i have (well the mechanics) remove the pads couple of time and put them back on so evertime it cannot be a alingment issue right?
and i have seen the mechanics alinging adjusting the shoes before putting the drum back on.
lets see how the re condition shoes cope with it, ill keep the thread updated later.
When you say alignment it includes drum and liner curvature matching (in fact the brake shoes do not have a fixed mounting except for the two pivoted anchor points at the bottom thus allowing self-alignment). I do not see our mechanics do that (at least just a visual check) before replacing the pads. A case like yours could be due to this. I believe the damage shown in pics above is on the leading shoe top edge.
i didnt notice about anything like that, probably just did a visual check only.
Visual check is enough but the mechanic should know what to look for. The general rule is that when you place a new pad inside the drum (I mean before you install it), the liner contour (curvature) should be slightly smaller than that of the drum. In fact most of the liners are eccentrically ground to create this effect so that when brake is applied the middle part of the liner engage with the drum first. Of course after sometime the liner would get worn off according to the drum contour. However, if the new liner happens to engage with the drum at the edges (ie liner contour bigger than that of the drum) first it may get overheated, tend to lock wheels and eventually fail before it gets sufficiently worn off to align itself with the drum surface.
Edited by Rumesh88
  • Like 6
ohoooo i understand and i can see that from the worn out pads i removed
but what i don't understand is how did 2-3 mechanics got it wrong over like 5 tries since all the springs and pistons, adjusters etc was okay.
