A/c Not Cooling Efficiently
well, it's all depend how the A/C technician trouble shoots. Entire system to be pressurized to around 250 ~ 280 psi and kept for sometime until pressure stabilizes. Check for visible drop in pressure. If notice a pressure drop then need to find out where exactly the leak is. First check for obvious leaks from gas charging valves and some flexible joints which they do using some sort of soap bubble solution (washing powder? ). If there are no visible leaks, next is to check for leaks on condenser and cooler matrix by isolating. If condenser, cooler and compressor is good and no leaks found, then again replace all back in place with new washers and re-pressurize. If it drops pressure any further, it must be tubing. Take tubing out to find out where exactly the leak is and replace that tube / or replace entire tubing is up to the owner of the car I guess. Why use nitrogen, can pressurize, can buy cheaper, doesn't contain moisture and doesn't condense like atmosphere air.
Negative, if at all it could be an issue in the relay which triggers the condenser fan. Also if the condenser fan runs continuously it should contribute towards getting better cool off from the A/C system.
Usually there is a pressure switch which gauges the pressure on the system and cuts off the compressor if pressure is lower than a certain threshold. This is to prevent compressor being damaged running without refrigerant which also works as lubricant for the compressor. May be yours 1. still have some gas left and hadn't reach this threshold to cut off the compressor 2. someone removed pressure switch or bypassed it you can judge whether the compressor runs fulltime by close inspection on the A/C compressor pulley. 2 years is considerably a long period and a leak could've occurred due to some reason, so better get it checked for leaks, I mean the entire system including tubing should pressurized with nitrogen and check for leaks, not only the cooler matrix.
you're running low on refrigerant AKA GAS in your A/C system. Hence evaporator doesn't reach the expected temperature (+ 50 C degrees) and does not cut off compressor supply. Compressor and A/C condenser cooling fan (not radiator cooling fan) driven by same supply means, when compressor is running the said cooling fan will also be running. This is the reason why it doesn't run intermittently. I'm sure if you check at cold nights, it will cut off intermittently. Get your system checked by a good A/C repair guy for possible leaks by keep it pressurized using nitrogen over night before refilling refrigerant.
Market Value Of Toyota Sprinter Ae100
Well I think reasonably did elaborate, yes Ripper we're alarmed and assessing the risks but more or less safely decided second hand market below 2 mill will not be highly affected.
you cannot predict the second hand car market below 2.0 mil mark like that, have to wait and see where it settles down. Simply because there will hardly be a brandnew sedan (except for Maruti's) in that range for a buyer to afford without stretching at least another 1 mil. Remember, second hand market shooted upward despite rumors of taxes coming down.
Tata Magic Iris
Found about this TATA concept while searching further on nano. A diesel van sort of concept targeting overloaded trishaws and bikes. Seems TATA makes a progress in simple, economical yet marketable products. http://www.automotorblog.com/tata-magic-iris-11-hp-car/ Tata Magic Iris, 11 HP Car January 7, 2010 by Rikk Filed under: Tata Tata Motors introduced a new low cost model, this is Magic Iris, equipped with a diesel engine of 11 hp and has the capacity to carry five people. Ratan Tata, chairman of Tata Motors, continues the campaign in India launched by Nano model with the future Magic Iris. The model have five seats and is equipped with a diesel engine of 611 cc, water cooled, which delivers 11 hp. Tata Magic Iris goal is to eliminate motorcycles with sidecars and overloaded motorcycles on the roads in India and to introduce a cheap car on the market for young families who need a means of transport. Ratan Tata think that Indian people haven’t to travel on overloaded motorcycles, which is why he developed Nano model. Unlike the Nano, Tata Magic Iris is exclusively for the Indian market. Among its advantages, we can mention the added safety offered against a motorcycle with three wheels, and also the additional load capacity.
Our New Baby, Fiat Grande Punto
triptronic/sportronic/steptronic and clutchless manual AKA semi-automatic are two different technologies. http://en.wikipedia.org/wiki/Semi-automatic_transmission
Post Whoring - Part 2
Well, it's not pity when you don't know how to write properly with added punctuation, specially when you boast about experience in forums. You've clearly mentioned that you have this service and I've quoted that part from your post as well ( read it again ). Although you said it's unsatisfactory, you first mentionned that you have this service available, therefore tend to agree with Dilesh that is, your motive being around here is to have a cheap mode of advertising, rather than helping fellow members. We all have seen it from the day one you got to know that there's a forum like this. Further, I will not reply to you firstly I've pointed out what you're doing is wrong and secondly I'm going OT.
Import Tax Slashed By 50%
it all depends on who had stocks on and who didn't get this news unofficially. One spokesperson from A*W said that they didn't have any stocks . Most of agents might've got lucky in this scenario except H*nd*i Lanka, coz they said they had some stocks on hand. Car sales and agents will bring the prices down aiming more volumes and this is something they wanted from Govt. due to the same reason.
lol, was replying to a question asked about the new price of an Alto, so "agent" literaly meant A*W. Not so fortunate to afford a BN Pug right now. Was looking for a reasonable 406 executive or GTX or a 307SW, and search continues.
have to wait till monday. Rang the agents yesterday and they were not ready to disclose any new price tags and said to call back on monday.
when the unreg can be bought by stretching 0.5 mil more than the reged specimen. Having said that, most of the transactions takes place below the 3.0 mil mark. What's available to buy unreg by stretching 0.5 mil more that is at 3.5 mil range is the question.
Diesel Mixes Up With Engine Oil
feel bit bad about not updating this after finding the real issue. It was a cracked diesel pump housing which kept on mixing diesel into engine oil.
in contrary, vehicle market shoot up amidst all claims of a tax reduction is around the corner and that boom was artificial/created. Similarly it wouldn't make a significant impact although prices would suppose to come down of vehicles which haven't really reached the shores yet. Second hand market will impact one day if a buyer can say, i'd rather buy an unreg or brand new paying few more lacks. Not few more millions.
Odometer Display Problem
me no expert in japanese stuff. By judging the way this LCD fits I get this bad feeling that you might have to replace the entire cluster. Yet again if you lucky enough to find the LCD from a broken speedometer cluster and a capable guy who can solder(?) fix it into your speedo cluster I think it might work. Why don't you just ring around to see this part (LCD display) is available for buy. Try Toy*ta L*nka and M* O*gani*ation.
Breaking News
present tax is 384% or something.. does this means tax will be half the present rate or 50% removed from 384% which means it'll stay on 334% ?
Battery Alarm
not battery wires, wires/connections to the alternator. There must be 3 wires. Check all three
Battery Alarm
loose connection is what came to my mind. This happened once or twice due to same reason. Usually there are two additional wires can be found connecting to alternator than the main (thick) wire in simple terms. Check for loose connections of these two wires. Failing to identify any issues, broken or loosen wires then check alternator for worn out brushes or worst case you're expecting a re-winding or replacing the alternator.
Battery Alarm
- Unwanted Writing By A Member Of The Forun.
lol, was he Nihal Wijesinghe by any chance?- Unwanted Writing By A Member Of The Forun.
lol, good you didn't see this before leaving from office. Me still hanging around just to see what's coming up.- Window Tints-what's The Deal???
well, till you get caught driving around them up I would say. It'll avoid you being copped and wouldn't make it legitimate.- Unwanted Writing By A Member Of The Forun.
spot on about forum activity.. and ehem, it can bring silent members back into track too ..- Unwanted Writing By A Member Of The Forun.
indeed it's a PM by looking at some standard lines. Also for me it looks like a reply to a PM. Probably he had asked for it Don't you'll think he's trying to stir things up? - Unwanted Writing By A Member Of The Forun.
