harshansenadhir
  1. LTTE was developing and upgrading their "Air Force", probably they had plans to upgrade the zlins as it can carry a bomb weigh 2tons. However at the same time troops have discovered some 'Missiles' and claimed LTTE had (have?) their own art of missile technology. They probably had plans to launch these as missiles? it was revealed by Indian government itself that LTTE has about 5 light weight air crafts. SLAF/SLA successfully destroyed 3 of them or at least 2 of them with proof. Although we have virtually minimized the threat (by eliminating most of air strips and destroying frequently used slins) I don't think it has been completely destroyed. However one thing we have to keep in mind is these light weight crafts need not to have sophisticated runway in order to airborne. some 600 to 800 meters of gravel road is suffice. What I don't know is how to they manage to airborne on a rough surface carrying a massive payload of explosives only for Kamikaze type of missions I guess.
  2. it's not only about # of bhp and the torque, it should be a combination of handling and control.. that's where X is far ahead with all torque distribution and other stability programs out of which most of them are electronically aid. I'm not an expert to say X is better over evo boy's car, it's just my gut feeling that X will handle the corners better than a 800 bhp beast.
  3. got it .. really appreciate it bro. it will contribute some way to save another classic in SL
  4. nope, I was referring to a garage known to me in Seeduwa area.
  5. would you mind forwarding the same for the beneficial of others if not objected by the admins
  6. bought from a famous photographer ? or from a place in Seeduwa area?
  7. exactly same happened to one of my uncles.. parked his Hiace and went searching for a hub/rim center cap, found one and came back to where it parked and found out one more is missing.. Thne a thuggery looking fellow approached him and asked 'Mahaththaya center cup eka oneda" he apparently paid some 200 bucks and "purchased" it.
  8. Somewhere i saw 4DR6 is 2.8. need to clarify though
  9. 4DR6 is the turbo version i guess..
  10. some of them directly controlled by the thermostat, but there are much complex ones. However in the systems I know of, it's not the car computer, it's the fan control unit. EFI Fuel calculator, or Engine Control Unit aka car computer mainly looks after the fuel and the ignition part of it. Difference between the fan control unit and ordinary relay is that Fan control unit operate fans depend on multiple parameters such as water temp, external temp, A/C gas temp etc..
  11. fan could be too loud to due to improper fixing of the fan or due to worn out motor itself.
  12. pretty easy to my knowledge and cheap too ..
  13. in a more scientific view there are more issues can be triggered due to this, so when the same problem happened in my Lancer CX, this is what I've done to correct it. DIY stuff 1. checked the thermostat with a 5W bulb attached to it and noticed at a certain temperature it lits up. so thermostat sends the signal ( you can further check the thermostat by removing it and place it in a water jug and heat the water using a heater and a temp gauge. then you can notice at which temperature it sends the signal and is up to the manufacturer standard.) 2. Sourced the relay for the fan and checked with the same bulb whether the relay coil supply gets the signal. check Passed. 3. Checked the relay. failed 4. Further short circuited the (+) to the fan and from battery(+) pins of the relay socket (pin no 30 and 87 to be exact). Fan started cut in. check passed. Replaced the relay and now runs on intervals and temp gauge stays right at the middle. Drawbacks of running it constantly are not only the wear 'n tear of the fan 1. not reaching the working temperature or taking so long to reach it, fuel efficiency + high wear 'n tare. 2. high draw out of the battery current than usual 3. Point 2. will result in additional power lose of the engine, based on the references it may be as high as 10bhp depending on the amperage of the fan (of the 406 when both fans engage in high speed mode I clearly feel a load on the engine, and in night there's a slight sudden flicker of the head lights. I don't' think the system can afford to run them continuously)
  14. my point behind brake bind was if there's a single wheel with binding problem due to mis aligned brake pads or caliper piston issues.. you can check that on a gravel road.. which wheel starts to stop and drag over the other.. or jack up and rotate each wheel
  15. Normal, however there are some systems where the A/C condenser fan & Radiator fan has multiple speeds. Depend on the parameters such as A/C gas temp, A/C gas pressure, Coolant temp and pressure they can cut into a high speed mode ... and some UAE versions even has another 3rd speed to reduce the pressure in A/C system.
  16. Few questions, 1. What will happen if you remove your foot from the accelerator pedal, when cruising at an average speed with a bit of pulling power used from engine? does the car slightly turns to left hand side? if so most probably the culprit would be lower arm bushes of front left suspension.. 2. Any brake bindings on the front right wheel? lift up each wheel at a time and check how they rotate 3. if suspension bushing and alignment is alright and no brake bindings then I might look for any anomalies or different wear tear of the CVs .. have you done anything to CV joints recently? what's the condition of the CV joints? my advise is to check them if all of above sounds right
  17. well not me honestly, but one of my uncles.. yet he wanted me to monitor the job and do random checking on the progress.. maan that guy didn't leave anything for me to check.. and very hardly I've corrected any mistakes.. Worth the price you pay. I still can remember how his car looked after the initial spray. I felt that I'm looking at a bare body shell taken off from the assembly line.. pretty neat!
  18. how have you found a good place for the restoration? by looking at the background one garage came to my mind. by any chance is this place between Pannipitiya & Arawwala ?
  19. needless to say that.... however since he was very sure about the plugs and distributor and all electrics related to igniting the plug, I had to think of other possibilities...
  20. my gut feeling is one of the pistons does not fire properly if it is shaky all the time. It could be due to 1. Problem in the electric current passes to the plug 2. problem in the plug itself. since you're very sure about the electronic side of it, get a compression test done on all pistons. Not to disappoint you, but it could be little worst as it may due to malfunctioning/burnt valve of one of the pistons. I may be wrong here but that's the last I can think of if everything else is checked and sound.
  21. accept my deepest sympathy Miniace
  22. thts a good one Peri, however migrating is no more an option as they're laying off heavily in other countries.. if not for this global economic crisis, you would've formed hundreds of Handball teams...
  23. captured this while on the way to office this morning... I found it hilarious that how this people sneak out from the law and this number plate was done in a way that someone would confuse thinking it's JI - XXXX .... Daewoo wasn't even designing this model when 31 Sri 0XXX series runs in Sri Lanka. Mind you the number is 31 Sri Zero series.
  24. can't be 2.3 for sure, it should be 2.7. I was under the impression that early Rosa and Canter both were on the same platform..
  25. a blue bird ? is it Nissan at least?
