mjayanath Posted February 6, 2009 Posted February 6, 2009 I find it difficult to accelerate the engine (Maruti 800, Carb) as soon as I start the engine in the morning. But if I let it idle for few minutes (5 minutes or more), gradually it becomes ok. Is this normal ? Quote
0 Ripper Posted February 6, 2009 Posted February 6, 2009 I find it difficult to accelerate the engine (Maruti 800, Carb) as soon as I start the engine in the morning. But if I let it idle for few minutes (5 minutes or more), gradually it becomes ok. Is this normal ? nope it's not normal... i would assume when you say "difficult to accelerate" the motor is "missing" or not firing well.... most probably your sparkplugs are bad... after some use, plugs tend to not fire too well when it's cold but catches up once they are heated up Quote
0 RACERSEDGE Posted February 6, 2009 Posted February 6, 2009 (edited) check plugs, check yo carb n cleen it n put the packing set if needed n check yo petrol filter n stuff.basic stuff as its not efi wnt b a big issue.how long hav u been using n wht's the eng milage Edited February 6, 2009 by RACERSEDGE Quote
0 JadeyBlitzen Posted February 6, 2009 Posted February 6, 2009 well maruti's dont accelerate that well anyways . no offence but i have to nitpick. just how many problems about your maruti's have u discussed in the forum lately? Quote
0 Silver Posted February 7, 2009 Posted February 7, 2009 well maruti's dont accelerate that well anyways . no offence but i have to nitpick. just how many problems about your maruti's have u discussed in the forum lately? Tsk. Tsk. Thats not nice or useful (Nor is this post ) Quote
0 JadeyBlitzen Posted February 7, 2009 Posted February 7, 2009 Tsk. Tsk. Thats not nice or useful (Nor is this post ) i'm just kidding Quote
0 mjayanath Posted February 10, 2009 Author Posted February 10, 2009 I bought the car in August 2007. Carb cleaned, contact point & Piston rings replaced in November 2007, (After 3 months). Complete tune up done & carburator cleaned again at A*W in January 2008. Mileage 142000 Quote
0 rman2000 Posted February 10, 2009 Posted February 10, 2009 machan Jayanath if you had done 142k on that Maruti these things are to be expected as Marutis are flimsy cars (no offence intended just my observation),what is the YOM of ur car? Best bet is to get rid of it and buy a better car,even an older Jap car like the 13-14 Sri Lancer GLX (C11/C12) is a much better car! I bought the car in August 2007. Carb cleaned, contact point & Piston rings replaced in November 2007, (After 3 months). Complete tune up done & carburator cleaned again at A*W in January 2008. Mileage 142000 Quote
0 Devinda_Z Posted February 10, 2009 Posted February 10, 2009 I bought the car in August 2007. Carb cleaned, contact point & Piston rings replaced in November 2007, (After 3 months). Complete tune up done & carburator cleaned again at A*W in January 2008. Mileage 142000 thats a lot of Km's in just a year & a half! Quote
0 mjayanath Posted February 10, 2009 Author Posted February 10, 2009 thats a lot of Km's in just a year & a half! Sorry! Only 3500 Km only for the past one & half years. Quote
0 mazdaspeed Posted February 10, 2009 Posted February 10, 2009 Sorry! Only 3500 Km only for the past one & half years. Looks like youβve done everything in terms of the engine tuning & plugs β Pulling issue- is with AC on or off? Whatβs the year of manufacture? Not to put u in a bad feeling but 142 is quite a high figure. What did A*W say @ the recent service β after all itβs their baby ??? Quote
0 charitha19 Posted February 11, 2009 Posted February 11, 2009 i suspect a vaccum leak too.. if everything is checked as u say.. even the tiniest one can cause this as the engine is only 800.. better check for those as well.. Quote
0 Ripper Posted February 11, 2009 Posted February 11, 2009 Sorry! Only 3500 Km only for the past one & half years. hmm...that seems to be very little running... If you full tuneup included plugs also... i too would assume there is a possibility of a vacuum leak! Quote
0 mjayanath Posted February 11, 2009 Author Posted February 11, 2009 Year of Manufacture is 1996 Pulling isuue is with A/C off. If I switch on A/C, condition is worst. Does this problem related to considerable engine shake in the morning & unbearable shake in the afternoon after a run in the morning. Sorry for troubling you all. :unsure: Quote
0 harshansenadhir Posted February 11, 2009 Posted February 11, 2009 my gut feeling is one of the pistons does not fire properly if it is shaky all the time. It could be due to 1. Problem in the electric current passes to the plug 2. problem in the plug itself. since you're very sure about the electronic side of it, get a compression test done on all pistons. Not to disappoint you, but it could be little worst as it may due to malfunctioning/burnt valve of one of the pistons. I may be wrong here but that's the last I can think of if everything else is checked and sound. Quote
0 GihanFX Posted February 11, 2009 Posted February 11, 2009 well maruti's dont accelerate that well anyways . no offence but i have to nitpick. just how many problems about your maruti's have u discussed in the forum lately? "Maruti 800 produces a power of 37 bhp at 5000 rpm" cant that be the case ? Quote
0 Ripper Posted February 11, 2009 Posted February 11, 2009 my gut feeling is one of the pistons does not fire properly if it is shaky all the time. It could be due to 1. Problem in the electric current passes to the plug 2. problem in the plug itself. since you're very sure about the electronic side of it, get a compression test done on all pistons. Not to disappoint you, but it could be little worst as it may due to malfunctioning/burnt valve of one of the pistons. I may be wrong here but that's the last I can think of if everything else is checked and sound. good point but if the pistons are bad...or even valves for that matter...shouldn't the condition of plugs be a dead give away? Quote
0 pradfred Posted February 11, 2009 Posted February 11, 2009 good point but if the pistons are bad...or even valves for that matter...shouldn't the condition of plugs be a dead give away? Agree. Having had these cars in my College days ( long time ago in India lol) I suggest a simple remedy. Change the plugs, wires etc. Take it out for a good De carbonising run. Thrash the bugger a bit. 3500 kms in 1.5 years = lack of use. She needs loosening up,..just like a woman. No use = tight . use = loose = good performance LOL. Quote
0 Ripper Posted February 11, 2009 Posted February 11, 2009 Agree. Having had these cars in my College days ( long time ago in India lol) I suggest a simple remedy. Change the plugs, wires etc. Take it out for a good De carbonising run. Thrash the bugger a bit. 3500 kms in 1.5 years = lack of use. She needs loosening up,..just like a woman. No use = tight . use = loose = good performance LOL. my my,,,aren't we in a mood today agree with the first part of the post... latter part is HIGHLY debatable... and in this case, i beg to differ especially on the last statement Quote
0 Devinda_Z Posted February 11, 2009 Posted February 11, 2009 She needs loosening up,..just like a woman. No use = tight . use = loose = good performance LOL. my my,,,aren't we in a mood today agree with the first part of the post... latter part is HIGHLY debatable... and in this case, i beg to differ especially on the last statement ...i normally enjoy making odd remarks about things that everyone says , but i don't know where to begin with this! ..come to think of it, i don't really know what to say to this! something tells me its better to just take a back seat on this one and just have good laugh! Quote
0 Ripper Posted February 12, 2009 Posted February 12, 2009 ...i normally enjoy making odd remarks about things that everyone says , but i don't know where to begin with this! ..come to think of it, i don't really know what to say to this! something tells me its better to just take a back seat on this one and just have good laugh! oh man...how rude instant moral high ground for dev or did you just kfc'd out of it? Quote
0 Supra_Natural Posted February 12, 2009 Posted February 12, 2009 oh man...how rude instant moral high ground for dev or did you just kfc'd out of it? he KFc'd! and it does strike me that we've drifted MILES off topic on this one! might have even scared jayanth off!! Quote
0 mazdaspeed Posted February 12, 2009 Posted February 12, 2009 my my,,,aren't we in a mood today agree with the first part of the post... latter part is HIGHLY debatable... and in this case, i beg to differ especially on the last statement Uβr right Ripper β Ever since he vent Solo He been on the High side Looks like Prad is on a role β Ya heard some crazy stories of the Maruti back in India What about that drink man ??????? Quote
0 harshansenadhir Posted February 12, 2009 Posted February 12, 2009 good point but if the pistons are bad...or even valves for that matter...shouldn't the condition of plugs be a dead give away? needless to say that.... however since he was very sure about the plugs and distributor and all electrics related to igniting the plug, I had to think of other possibilities... Quote
0 mjayanath Posted February 12, 2009 Author Posted February 12, 2009 (edited) Sorry Edited February 12, 2009 by mjayanath Quote
0 mjayanath Posted February 12, 2009 Author Posted February 12, 2009 (edited) Oops Edited February 12, 2009 by mjayanath Quote
mjayanath
Is this normal ?
39 answers to this question
