kusumsiri
Everything posted by kusumsiri
  1. Update Here are the rim painting tasks. After applying filler Final status
  2. @Manoj20030120 If scroll up you must see this reply.
  3. One previous owner converted the wiring to negative earth and an alternator also fixed. It is a 3 wire alternator having inbuilt regulator. But the control box fixed as a dummy.
  4. Update : Because we already discussed about electrical works in this thread added the relevant images here. To suit it changed the thread name from "Project Moggie - Bodywork" to "Project Moggie - Body & Electrical work". First two images shows the control box and fuse box in the way they were. This is how the viper motor and flasher were there. Below images are the present status of wiring. The hole on the control box cover was repaired and added some dummy wires to it for better look. Thank you @varotone for suggestion about flexi tubing. Original status and present status
  5. I am still thinking about the angle of the tire. It seems something odd for me.
  6. Here are some images after applying the top coat. Used Toyota white 058 as the color.
  7. A Morris Minor shell with Fiat powertrain. So it is neither the Minor nor the Fiat.
  8. Another wonderful year is going to end. But don’t worry, one more year is on the way to decorate Autolanka !!!
  9. @Davy or any @Admin, Same question asked in thread too. Shall we merge this with it ?
  10. After sanding the primer, applied the filler coat. Gray color filler applied on the body shell. Later thought to use white color filler as the top coat will be white.
  11. Changed my Viva Elite timing belt as a DIV task on last weekend. Added some images for reference. The new belt has two stripes to make the job easier.
  12. Be care about it like @kmeeg said. I think best method is explained by @Davy
  13. Body filling was the next step. Unfortunately I have only few pictures of this step. Anyhow followed the above video instructions throughout the filling process. Additionally applied putty on top of filled areas and small scratches. After all preparation applied the primer coat. Below images are after sanding the primer coat.
  14. I did not try it. So may be possible. But need to fill the tank before use.
  15. So seems it equipped only airbag & Immobilizer. See below images.
  16. It need to wait around 3-4 minutes till the tank fill. When its reach 50-60 psi I am starting the spray work. In the beginning the pressure it bit high. So controlling it by sprayer adjustment. When pressure reducing need to adjust it gradually. In short it does not hold constant pressure. But can manage when you are familiar with it. With fully filled air tank, It can spray complete panel once. I could apply last coat also using it. But panel by panel. The hood was the biggest panel which I couldn't handle with it. So hired a compressor when painting the hood.
  17. Painting was a most challenging field for me. Because never attempt to do a vehicle paint job earlier other than painting walls in the house . But I have watched (not seen) many times how a painter working from applying filler to last coat. There is a neighbor who do paint jobs and that was a big strength for me as it is possible to clarify somethings from him. So finally decided to learn the art of painting by Moggie. Gathered the basic knowledge from reading some articles and found following video very informative. Also these two technical books. How To Paint A Car At Home In 4 Easy Steps (video)  Causeway Automotive Paints (pdf) Debeer Paints (pdf) Next challenge was a paint gun and a air compressor. Bought a F75 paint spray gun and some flexible hose after expending around Rs 2500. But a air compressor is bit expensive. So again started to find alternatives. Firstly bough a 'paint zoom paint sprayer'. Though it could use with my spray gun with modified hose, the air pressure was not enough to spray well. So found an old deep freezer compressor and a empty AC gas tank. Used them with a foot air pump pressure gauge and some clips to make my air compressor. What could not find was a safety pressure release valve. So had to keep eye on the gauge frequently. When I get familiar with spray gun, watching pressure gauge was not essential as it can feel pressure via spray flame. Tried to remove existing paint in most body panels as the first job. Because the floorboard was completely new it made my task easy.
  18. Does your airbag indicator light up in pre ignition ? My Elite manual does not light up both airbag & ABS indicators because its not a premium. Is there any other sticker than Immobilizer on your back windscreen ?
  19. https://www.facebook.com/japanbodare/photos/a.265140630595143/775274146248453/?type=3&theater
  20. This thread will give you good idea.
  21. Welcome to the forum @DennisLin, We have discussed it under this thread. Better post your request there.
  22. Don't shout. We are watching the drama.
  23. @srinathkani Check whether rear speakers equipped as @hrmsaid. If it is, then need to check connections. If you are capable to get player out, it can check easily. Also the user manual of the player will help you in this case.
