K.o.N.o.S
Everything posted by K.o.N.o.S
  1. Guys I am planning to polish & wax my car & this will be a first time for me to perform such a task. Hence if you could give me any advice,any tips/experience you had in the past, that would be really helpful to me. I love these DIY jobs and I will be using autoglym products. Also I would like to know whether polishing & waxing prevent small scratches or not.Just want to protect the clearcoat. Thanks.
  2. Welcome to the demio club.As a proud owner of a Mazda demio I would like to state that you are taking a wise decision to buy the car. Look for a one with CVT , ,RPM meter and a double din player.When I was hunting for my car I was looking for a one with HID headlamp as well.could not find one with HID so settled with the other options.mind you demio is bit of a bumpy ride on hard surfaces. But you can have a surprising amount of fun just by driving the car. Further it was the world car of the year 2008. Totally deserved in my opinion.My one does about 10-Kms (city limits) and about 14 (outstation).
  3. Thank you for the info
  4. Thanks much. I am actually planning to add caltex premixed ( green) coolant so Won't have to add water. Further may I know the reason as to why should I fill the reservoir to the max line? Shouldn't that be between the max & min lines?
  5. Thanks for the info Davy. Also may I know the cooling capacity of the system? Is there a proper way to measure besides collecting the draining water from the system? ( demio 2009 YOM)
  6. Guys, my car was leaking coolant for sometime and it turned out the issue was with the radiator cap & radiator tank ( the one that connects with the radiator cap). So I replaced the cap and the tank and on the process the garage guy drained my old coolant. He advised not to fill it with new coolant at least for another 3 days because of the newly installed tank. Instead he filled the system with water only. I am planning to add fresh coolant to the car this weekend. My question is should I do a total flush of the coolant system before adding coolant or just add coolant? The mechanic said a total flush would not be required. Appreciate your expert opinion on this. Thanks in advance
  7. Thanks for your input guys.. have decided to go with autoglym..
  8. Thanks. I heard Autoglym is really good. Any agent in Sri Lanka? Was able to find 'dreams-auto' after googling.
  9. Can someone recommend a quality car polish and a wax ? Don't want to contaminate the paint using cheap products. Appreciate your input.
  10. Good for a country rideGodsmack- Running Blind
  11. Try changing your tire pressure. Mine Also a demio 2009 & I changed tire pressure -front 30 psi & back 29psi. Ride is far more smooth now. However demios tend to have steering rack issues.so better get this checked. Also be aware that demio is bit of a bumpy ride on hard roads by default. & that's the fun in that
  12. Nicely done Davy
  13. I think you can not tell whether the car is CVT or not by looking at the gear shift lever. For example my Car has the attached gear shift lever positions and when I am accelerating I can feel the gears are shifting. maybe a pro member can shed some light on this.
  14. Has anyone tried this vinegar method? Need to make sure before I try this on my car
  15. Thanks Davy. May I also know if there are any cons in installing a hid headlamp? Will there be unnecessary stress on the electrical system?
  16. i am interested in installing a HID headlamp for my demio 2009. Can someone pinpoint me a location to buy in SL?
  17. As mentioned earlier 121 is ridiculously overpriced in SL & it is out of the question. So that leaves you with 141 & allion. All of the 240s are close to 15 years old and With regards to comfort it degrades for any car overtime.Allion 240 2004 model will cost you somewhere between 3.7-3.8 mil. you can get a decent 141 2008 model for the price range you are seeking. so It's obvious that you are better off with 141.
  18. Hi. The issue still persists and I could not find a time to test the system.
  19. 2 of my friends who owned Honda Insight were consistently complaining about the fuel consumption. So I would advise against buying a Honda Insight.
  20. Treat your car like your baby. I mean you wouldn't wanna give your baby to someone else to wash him or her for you right? You should have a bond with your car and should be able to take care of her on your own.
  21. Thanks rumesh. Yes there seems to be a problem with the cooling system. Going to get it checked asap..
  22. For the record i did not do any repairs on the coolant system.i am guessing the water leakage is condensation from the Ac. That's nothing to worry about right?
  23. Thanks Davy. Yes you are correct. There seems to be a leak under the car. I checked right after I have driven it. However I checked the leakage. I got couple of drops into a cup & It seems to be water not coolant..any insight about that? Meanwhile I will check further on the coolant system.
  24. Guys need your expert advice. i am regularly checking the coolant level in my reservoir and it consntantly dropping below the low mark. Car is Mazda demio 2009 and I am using caltex premixed (green) coolant. Is this something I need to worry about? Should I get my coolant system checked? FYI I checked the coolant level in the reservoir when the engine is in both cold & hot situations. They both read as either near low or below low mark.Appreciate your advice
