Everything posted by kumudug
Radiator Fan Directly Coupled To The Supply
Never mind guys I found the relay thus found the short. Apparently the relayed were on a different diagram. So now I need a different kind of help. So I figured its either the relay or the temp censor that is busted. (I'm gonna check that now and make sure) So where would I be able to buy parts of this kind except for the agents
Hi. I need some help from you guys Here is my problem. I bought a Mazda Demio recently and the radiator fan of the car is directly supplied from the battery. This was done when the radiator top tank was damaged previously. Apparently the fix was done by a makabas. Obviously now I want to fix this the proper way. I checked the wiring and just couldn't find where the "makabas" shorted the wires coming from the temp censor. Normally how does these guys do that. Here are the info I know and observed so far 1) The wires at the censor end is not shorted - so the short is done probably at the fan end. 2) Checked the wires in the fan end and couldn't find the short circuit. 3) Wires in the censor are pretty thin compared to the wires in the fan. My assumption was there should be some relay that drives the fan which gets operated from the wires from the censor. Couldn't find such a relay in the engine part diagrams. Can you guys please help me to do a DIY fix for this problem
Honda Spada Vt 250
If you got your carbs cleaned the mechanic should have adjusted the air/fuel screw as well. Did the mechanic remove the whole assembly and cleaned or did he just removed the air filter box and sprayed from there. If thats the case its not a complete cleaning. Its better to get a complete cleaning and after that the air/fuel screw has to be adjusted.
Honda Spada Vt 250
Taking into account the non smooth engine and high fuel consumption my guess is the air/fuel mixture is off. Get the carbs cleaned and tuned by a good mechanic. Be carefull not to let a makabass mess up your carb. I'm thinking this has a single carb. If so this won't be a much difficult task. If you are handy you probably will be able to DIY this given you find a part diagram. Also check the air filter or better replace it. Also since you bought it recently its advisable to check chain, sprocket, cables, do a coolant flush, change oil, check spark plug etc etc.
Adding An Extran Radiator Fan Pros & Cons
Sorry for going OT but it seems that you took your ride into a track after the new mods.
Laptop Prices
I don't know about you but no amount of battery draining or resource taking is gonna get me to go back to xp. Well I haven't used my new laps hardware on xp but my desktop used to be xp and now its Win7. I have to say speed vise its like no difference. I mean for instance if you install vista to a machine that used to run XP you would definitely feel the difference but I have to say I'm not seeing much difference in XP and Win7 in my desktop. Stability vise also Win7 rocks. Haven't given me a single blue screen so far
Laptop Prices
The slowness is probably due to the S/W junk. Mine is with 4G of memory corei5 version. Well my battery lasts max for about 2.5 - 3 hours that's why I said the battery is a bit disappointing cause if this is the time I get from the brand new battery its gonna go down to like 1.5 in one years time. Trust me this thing is pretty fast. I even don't feel the painful slowness of the new vs2010 when working on this.
Laptop Prices
I have to disagree with you here. I baught an inspiron 1464 from singapore about a month back and its really impressive except for the battery.
How Take Out The Starter Motor On A Cbr?
Did you check the battery properly. You said you jump started from your car. Did you use the car battery when you tried to give direct supply to the motor. If not you should check the battery. Even though the battery has the voltage at first you need to check the voltage when the load is applied. For the battery to be good it has to have at least 10V when load is applied. Also keep us updated. There is no saying when this can happen to one of us too. Also I totally agree with you about mechanics. Most of those guys are just makabas guys. I also don't let anyone touch my bike or car. Specially not my bike. Hope you get your problem rectified soon. And about that link (Dan's Motorcycle Repair - http://www.dansmc.com/ ) I think this "Dan" is the god for us people who wanna DIY stuff in our bikes.
Check out this link. According to that the motor should come out and when it does the sprocket falls off so you need to remove the right side crank case cover to replace the starter motor. In your case I guess the starting sprocket is a bit tightly bound. Anyway try to find the gasket or buy some packing sheet and be ready to make you own gasket. http://www.dansmc.com/electric_starters.htm
Mileage From Synthetic Oil
I think you are talking about mobil super 1000. Its not a fully synthetic oil. As far as I know Mobil1 is the synthetic range.
Rpm Meter For Mazda Demio
Thanks.
Thank you very much for the reply. I hate to ask this question but where is motorcade?
Hi guys. My Mazda demio doesn't have a RPM meter built in. Probably because its a basic model. I really would like to get a rpm meter fixed. Do you guys know any good place that I can get this fixed? If so any idea about the price?
- Enviromental Polution
Brake Caliper Painting
I was also thinking of doing a DIY job. Checked TOA heat resistant but only 2 colors were available. Siver and black.
Pet Question !
Just one more addition for VVTI's post. A dog is a huge responsibility. Think before you get one. If you are just thinking of getting one for protection think twice. Dogs are not meant to be put in kennels all day or leashed. They need love.
Pet Question !
My respect to you fro saving the puppy.
Digi Cams
Try HitAds. I'm not sure about 370. but I saw a W380 in HitAds for around 32k from some store in pettah. Pretty good deal for an amazing point and shoot. Maybe they have W370 too.
Can The Polize Impound Your Car For High Speed Driving?
They do fine for that. But I guess they don't do it all the time.
Mazda Demio Workshop Manual
Any help guys. I even looked for Haynes manual and its not available for the Demio.
Hi Guys I recently bought a Mazda Demio. Now I'm sweating all over trying to find workshop manuals. Any help you guys can give is greatly appreciated. Its a 2000 with the B3. So at-least a workshop manual for some other Mazda or Ford with the same engine would be really great.
Happy Birthday Mani!!!
Happy B'Day Mani
Emission Testing..
http://www.laugfs.lk/ecosri/standards.htm
A Thrill Of A Bike, In A Car..?
Not even close
