3
Everything posted by kushan
Guys, My Vezel's LED low beam light indicator is not showing in the dashboard suddenly. It was parked at outside yesterday and it rained heavily. Can it be a fuse issue, but all the other indicators are working as expected. Note that, all the indicators are lighting up when I turn on the engine, but not that one. Not even when I turned on the LED low beam lights.
Guys, Accident has happened 2 month ago, and then and there I called the Insurance company and filled up the form given by assessor at the scene. But did not do the repair yet. My insurance expired end of last month, and can I still claim for it?
How Would The Market React To The 2015 Budget Proposals?
kushan replied to tcfern1's topic in General Automotive
Vezel comes down by 50K Now only Excise duty, no more VAT, Custom duty, NBT etc.. http://www.ceylontoday.lk/51-76391-news-detail-vehicle-prices-drop-by-rs-80000-to-12m.html- 158 replies
- Budget 2015
- duty tax sri lanka 2015
(and 5 more)
well, not every one I just edited the post, is it ok now?
yeah I saw they have deleted my previous posts also, no worries. Hope you are satisfied Supra. I have no intention of advertising here, even the mods and others can search the previous posts I have made and check whether I have advertised before. I just wanted to highlight how to validate the auction vehicle with the actual vehicle they got.
Beware, Vezels Are Invading The Country. Good Bye All Ion & Prmios.
kushan replied to knightowl's topic in General Automotive
Multifunction comes with Z grade, Navi package offers Z grade options + the wide angle rear camera + Audio control switches + 2 additional speakers + separate wiring harness for the sound system - so you don't have to cut and fix if you are planning to fix another Amp or so. -
No, but yes in X and X.L Hybrid grades dude, Hybrid X comes with FF and 4WD, and Hybrid X.L comes only with 4WD but with more options when comparing with Hybrid X. And Gasoline G comes with FF and 4WD -
I have already replied to your pm. yeah dude, it looks like I'm advertising myself here, xxxxxx Edit: You ARE advertising and it is NOT allowed!
I think they will increase the vehicle import tax, and will reduce some tax from essential goods. So they can hit the majority saying "podi minihata sahanayak dunna"- 158 replies
- Budget 2015
(and 5 more)
Yen is rising
It's actually 4.9 - 5.3m 5.3m - Z Grade Navi package at the current Yen rate, and the Yen is rising again, hence it may go up in another 100K in next week. -
yeah it can be, adding so many options affects the fuel figures. -
yeah it was not there, since 2006. But now they gonna market Vezel as HR-V there. It's the 2016 HR-V for them (not even close to previous HR-V though, so this has broken down the hearts of fellow HR-V fans there) http://automobiles.honda.com/hr-v/ -
Well, you need to look for the chassis code not the grade to decide whether it's AWD or FWD. RU4 is the AWD one. Both X and Z grades are coming under FWD, and also in RU3 chassis, it may come under RU4 also. So the fuel figures are same within the same chassis. Z grade is the highest grade where you can get all the set of options. Vezel is being called as HR-V in USA and they have targeted it for urban areas so it goes as Urban SUV. http://automobiles.honda.com/hr-v/ -
Thanks mate, gonna open it up on tomorrow, will keep you posted.
Can I know why you asked whether I'm seeing the large bubbles or small ones?
Honda HR-V, 2000 manufactured. I can see large bubbles at the first and goes away in 10 minutes, then I'm getting small bubbles a lot. Mechanic open up the reservoir and put the overflow tube to a water bottle, when the miss comes in, bubbles coming out of it. So he said I need to replace the gasket.
I also having the same symptoms, I have done the followings, 1. Full tuneup (Cleaned injectors, Throttle body, IACV, and fuel filter outer mesh) 2. Scanned and no error codes. 3. Replaced the ignition coil (I'm having a distributor with one coil) 4. Mechanic checked the cylinder pressure by a hand held gauge and it was OK. 5. Replaced the plug wires It was OK after I replaced the ignition coil, but one day after it came again. Replaced the plug wires and the issue went away again. But after 2 days it came again. I can see the air bubbles coming out of the radiator. and yeah garage smells like a petrol pump, even after 8 hours of outside parking I can still smell petrol when I came near the vehicle.
yeah Don, still can see the air bubbles and the engine misfire is so heavy that I can't even drive without pushing the pedal to the floor. So you think this misfire is caused by the head gasket issue?
- 42 replies
- oil in radiator
- 2002 lancer cs
(and 2 more)
I also can see air bubbles coming out of the radiator, you mean gasket failure is the only thing that could have caused this?
- 42 replies
- oil in radiator
- 2002 lancer cs
(and 2 more)
or if its Hydraulics, top up the power steering oil and see.
Hino is a fully owned subsidiary of Toyota (like Lexus), Previously toyota came up with coasters and it has been re-badged under Hino, but with more options and comforts. Same thing with your Caravan. It has been re-badged in Japan under Isuzu. So keep calm. All the vehicle manufacturers in Japan has linked with another in someway. You need to do bit of a search to know what exactly and why.
Why you had to come in your own car? they didn't give transports?
Why can't you restore it for him, at his own house? give him a quote on this and see how it goes.
