Ruslan
    19
Everything posted by Ruslan
  1. It's Toyota Part # 30140-12030 and As iRage mentioned Gearbox code K311 for 1.8 Variant.
  2. 1st GR Yaris in SL? wonder how much that has cost? Interesting.. looks like a 2nd Gen? @iRage https://www.facebook.com/share/p/1Ao8eLgyhC/
  3. There's Axio 141 GT which has a 1NZ-FE Turboed engine. not sure how many ended up in SL.
  4. Toyota Coolant? i think it's around 15k for 4Ltr could be more that that last time i check.
  5. and do let us know the Trim level of this. was it a Pre-Facelift or Facelift? post Pics please..
  6. Do not ever use Totachi, this is some shady Brand which has some Russian Origins. people fooled by the labels with Japanese letters in it. you cant even find this Brand in Japan i think. Idemitsu is a Good brand in Japan but its not imported to SL.
  7. That's too Pricey 2x times i believe. "Zerex Asian Vehicle Coolant" which marketed by Valvoline Agent also contains the same content as the Toyota Coolant. or else "Bear Brand (Seiken) hyper long life coolant" is a safe bet. these all prominent brands available in the market. https://www.facebook.com/share/p/17UQ9tAxWv/
  8. My Thinkin is Gov should only allow Brand-new import through Agents and curtail importing Grey imports.. i know as Enthusiasts will go up in arms against it. but to curtail importing Garbage and exhausting reserves i don't see any other option. for the record I'm driving a 18 Year old barge. but I'm satisfied with it at least for now 😁
  9. I do have the same model and had the same symptoms. unfortunately you need to overhaul and rebuild the Transmission at a reputed place. Oil pressure is not keeping up during the Cold start since the Clutch bands and discs are worn and expands once heated up.
  10. ohh.. the Rats.. i think you better take drastic measures to get rid of 'em rather than Spray them off.. tried, failed!.. so end up placing poison for once and for all.. (I know it's bad but can't help).. to get the Marder spray there are bunch of places which I'm using and these folks do deliver (Courier) as well.. will inbox the places..
  11. Lol, i don't know from which end these Gov officials talk.. apparently they cant manage issuing Passports to the Citizens nor do they able to issue Driving licenses to the new applicants..
  12. Adeh, those wheels looks lovely. i believe that was the intended Suspension geometry hence the steadiness.
  13. As i Remember they didn't asked for 7 Receipts at that time. whomever checked it, looked for the final receipt and didn't make any fuzz. this was a 1 day transfer back in 2018. by the way how do we get a Tax printout, I believe we can request this over from their counter?
  14. Thanks, Mine is a K series.. 👍
  15. Sorry for Hijacking your thread, but need to clear this up since I'm also missing in-between tax paper (I think i only got 6 papers during transfer. Final one is in place. not sure why RMV didn't make any noise back then, perhaps there's a Final one in place?). so when you want to transfer do we have to submit these with MTA forms or just RMV casually saying good to have them? Asking since really want to avoid bayyas asking "Mahaththaya kola adu hinda gana adu karala denna" type of talk. not want to sell my car in near future but asking just in case to avoid the trouble.
  16. What is the Mileage of this Car.. check for any abnormal play in your axles while the car in stationary. seems like an Axle (Inner) CV issue.
  17. Yes AT set would do better (it will definitely cost you more) specially if your planning to go slight off roading in bad roads.. HT Tires wouldn't stand a chance and tend to break the Steel radial.
  18. And most of the 4L (V6?) ones came with Air Suspension which is a costly affair when it comes to maintenance.
  19. I'm with the Classic Quad lights. like the Color scheme as well.
  20. Nope, Maybe it’s from one of those “yaka squad FB groups” sadly not in FB..
  21. yeah also the "Reputation" from baiyyas "Prado eke awa SIR"😆 etc etc..
  22. She's looking gorgeous. you cant remove the Sri Lankan Mindset, just ignore them. most of the folks thinks that when it comes to replacing parts that's the end of the vehicle and you need to replace the vehicle immediately. Restorations and rebuilds are not in their books.. on Wheels, Factory Spec wheels would be fine i guess.. if you can source bits and pieces from yahoo auctions that would be cheaper.. well that's my go to place for hard to find trim pieces, tail lamps and headlamps etc. quite resourceful i would say.
  23. Most Probable cause is your Headlamp Stalk (Switch) is faulty. if the Relays and Fuses are fine then that should be your problem. you can check this yourself if your competent handling a Multimeter properly unless better seek professional help.
  24. Well, stay away from Technicians who doesn't want to perform diagnostics and coming to a conclusion. eventually you'll end up throwing up parts randomly and not resolving the issue. like @iRage said, better find a competent Technician who's willing to perform thorough analysis and pin point the issue.
