Everything posted by Ruslan
Need A Help (engine)
Mate, Why don't you give a call to the seller and get some first hand info. since it bears a 325 number, he might have done a Engine swap.
Atf Prices
Check your ATF Dipstick. Type of fluid should be mentioned at the end of the Dipstick
Xenon Hid Kits
That's a neat job you done there. and thanks for the pics. one of my friends using exact type of Ballasts/kit in his P11. but he's only using it for low beams.
Xenon Hid Kits
Machan can you get couple of pictures of your HID fixed lamps. (Of course not directed to the camera ) wanted to know, is it Bixenons or just LO beam?
(possibly False) Rumors About A Strike?
This JVP lot is the most unproductive lot I've ever seen. they've being already unproductive and advise others to be unproductive as well. in recent Moratuwa uni has won a international award. i think the reason behind is that they are not plagued with these JVP buggers unlike other Unis in the island.
What exactly they want anyway? Just put the Military personal to operate the CPC and rest of the organizations.. this is going way too far it seems..
4.1 Subwoofer For Car Audio???can I Do This>>>?
you can do it machan. i have seen this before. couldn't remember where. creative subs input is 12V AC just bypass the Diodes in the AMP located inside the sub.
Toyota Specialist Or Good Garage
Send you a PM..
One Word Thread!
Once In You Should Take Alcohol With Whatever that lobsters cooked with parippu,Butter and beer mug which holds Massive amount of Guinness. Ripper enjoys cuddling his huge soft barf bags with lotsa Intrest. Car Drinks because it enjoys SHAI's tiny nipples and really loud beefeater farts That smell nice. Christmas is coming. Not for naughty hand job related activities but Instead hardcore mud wrestling babes exposing tight pumpkin juice jugs. MasterDon needs some of those juicy melons, otherwise he might go obama on dine-mor donkey racing hippo kebab making buttock inspectors. Meanwhile girl on wheels too need some kind of extra vibrating piston which reciprocates the rubber ducky up her tailpipe with Devinda's black thong wearing fantasy boobies banana hammock. Why virensti likes punany rubbing maruti Indians butts we'd love to kick into Peri's cerebral software license expired rectum. Honda hobbits love Supra_Natural's pink onion flavored buns and bananas bonanza making achchaaru based nuts. MeanGreenZ28 floods Carburretors with Strenuous circular mango chutney mixed mousse' Pink yogurt not without eating camshafts grilled piston-rings, onion-rings, valves and grease filled bearings Jammed solid waste. The reality Bugatti has no hair at the tip of his left Balljoint but pradfred likes little balljoints with
Who Is Using Iridium Or Platinum Spark Plugs
Nope NEVER do that machan. plug needs better electric conduct between engine block. by putting tape your increasing the resistance between the Block and the plug.
check this thread.. http://forum.autolanka.com/index.php?s...p;hl=petti+kade
Toyota 121
Does your 2003 equipped with Power steering or EPS? most of the 2003/2004 came with EPS i think.
Toyota 121
For 2003 G it's ok. but you could've searched more. most of these 1800CC s got low market value, because people think that they are bad on fuel. i've seen couple of 2005 Luxels in Nugegoda area. true that those are not common like 2001/2003 counterpart.
You can use a Torque wrench with spark plug adapter attached to it. some times you may need to use a extender.
One Word Thread!
Trick is to properly torque them when you fit them. not too tight, not too loose.
Xenon Light
Maybe they produce 100/90W light output not the heat. just like our household CFL bulbs. and Glass lamp housings are more capable of handling high heat than their plastic counterpart. Those are HID bulbs machan. bulbs using electric arc to produce light at high voltage (just like Camera flashers, CFL bulbs, Tube lights etc). Ballast used for converting standard DC 12V into high voltage.
Toyota 121
Nope, there's a Luxel which came in 2003 and in 2005 as well. G-Limited is just a G grade with added options (some of them have seen with gate type shifter as well). 2003 Luxel (Front bumper and front shell different from normal G and X grades) 2005 Luxel (shell is different normal versions)
One Word Thread!
Xenon Light
55/60W would be ok as long as it doesn't contain any blue tint around. and try to stick with proper brand like ripper said.
My cars engine (Toyota 1ZZ-FE) was recommended (in Service manual) originally to use Iridium's. it came with Iridium's as well. (Originally NGKs). bought plugs from Agents. better check with your Cars Engine manual or service manual (if there any..) to verify with to use what kind of plug. found out that eBay got some super deals.
Xenon Light
Those are not Xenons. those are cheapos with blue coated film around. we have discussed this earlier as well. http://forum.autolanka.com/index.php?s...50&hl=xenon
I'm using Denso IK16 Iridium's in my Corolla. it can lasts around 50-60 thousand Kms. but be sure to clean/check it at least between 15k intervals.
Exchange A At 212 Carina To A Galant Or Ek3 Virs
i would go with the Honda as well. most of the Brand new Galants doesn't equipped even with ABS or air bags if i remember correct.
Toyota Ft-86
Exactly, AE86 is the real deal.. Link i posted before got '88 Supra as well. it's good at least this FT 86 making way into production.
