Everything posted by Az
Inner Tire Touching The Wheel Wells
Yes, I feel that the handling is a bit better, but that may be a placebo affect I haven't tried cutting full with a packed car at higher speeds
Well, the ride is much more softer & comfortable after I went for larger, thicker tiers. I'm assuming that this will put less strain on the suspension as well. Isn't that the case?
Fixed 1/4" spacers for all 4 wheels from Amila. Now there is no more rubbing. Each spacer costs Rs. 600. Thanks guys for your help.
Ecu Remapping
Yeah, went for a higher profile. Makes quite a difference on the pothole ridden Colombo roads. Hmm.... 60k is way too much. Does it take great effort to remap the ECU? Can somebody enlighten us on how ECU remapping is done? Perhaps, the HW or SW involved is costly.
Ecu Remapping
Went from 175/65R14 to 185/70R14 According to http://www.miata.net/garage/tirecalc.html the speedometer reading will be 5.4% slow. Can this have an adverse effect on fuel economy? I do add this percentage to the mileage when calculating the fuel economy. However, some say that this can cause the gear shifting to happen a bit late since the speed is not accurately detected.
Ecu Remapping
it is a Vios. I recently changed my tires to ones that are a bit wide and larger diameter, purely to enhance the ride comfort. Due to this, there is a difference in the speedometer reading. According to Nigel, this has a considerable impact on fuel economy since the ECU takes the speedometer reading into consideration when deciding on when to shift gears. So, I was just thinking about whether the relevant entries in the ECU can be reset, in order to achieve better fuel economy. I may not necessarily do it, but just been thinking about it.
Ecu Remapping
Hi Folks, Are there any reputed places in Sri Lanka which do ECU remapping? Thanks Az
Petrol Prices Up From Tonight
Only 95 octane was available when I went to purchase fuel in the night. Perhaps, that is what they are referring to normal
Yeah, no ballooning. These are stock rims that came with the Vios.
- Door Visor
No, it is not jutting out of the wheel arch. Will try after loading the vehicle. Thanks for the tips.
Excellent! Is this Amila at Karagampitiya junction?
- Inner Tire Touching The Wheel Wells
Is there a way to resolve this without changing the rims?
I changed my tires a couple of months back and went for thicker tires. Originals were 165, new ones are 185. Now, when cornering hard, the inner sides of the tires are touching the wheel wells May be somebody on this forum has already faced a similar situation. Any ideas on how to overcome this? Can some adjustment be done so that the tires are moved a bit outside from their current positions? Thanks in advance Az
Grounding Wire Kit For 1nz And 2nz Engined Cars.
- Auto Lanka Stickers
Ecu For Manual Gear 1nz-fe Engine (vios)
Wasn't Nigel able to repair your ECU?
Leaving A Car Unattended
Yes it works. I was also worried about this problem for sometime, and when I went to check my battery, the guy there noticed muddy rat foot prints all around the place and said that I should hang a Toilet air freshener. I have tried it and it works!
To avoid rats getting into the engine compartment, hang a couple of air fresheners inside the engine compartment. I've been having this problem of rats in the garden getting into the engine compartment, and this solution has worked for me.
