1. Congrats on your new car.
2.Any work done to the wiring/electrical system will void the warranty. So no cutting/splicing or altering of the wiring.
3.Seek the dealer's assistance for your need.
Not unless you're a heavy 4x4 enthusiast.That way you'll ignore the slightly thirstier engine, and lower re-sale value.
Plus,all tyres need replacing at once.
Welcome to AL.
1. GET THE MONEY READY.
2.Get a car maintained at the agent.This is the best bet as you are less prone to end up with a car held together with chewing gum
3. If you are planning on getting a BMW with a 4000cc engine, Dont ask of the efficiency.!
Good luck.
What ever you do, Don't wash the engine,.. If your car is an Auto ,as modern auto's don't have a dipstick you might want get the fluid level/condition checked. but it's best to let someone qualified to do the job.
All body panels should be cool - to stop wax baking. wash and dry in a shady ,well ventilated aria.
start with a small area at a time.
keep all plastics + beading clear as the drying wax will make them white.
I think the title should be 'low efficiency' 8km per 1L is a crime for your vehicle !
As Davy has pointed, get a scan and address to getting the engine back to correct running as you'll fail your next emissions test.
and don't use high obtain petrol.
It will be a hit from what I see with the stability of 4 wheels., and prob , will embarrass most hybrid owners with it's efficiency
On the down side it has minimal safty and no a/c from what I know.
Go to your owner's manual. refer cooling system maintenance.The max line denotes the upper limit for the coolant to be stored leaving for expansion clearance .
Your cat may be blocked.causing excessive back pressure on exhaust. Considering the age of your car , it may have been driven on leaded fuel when it was imported here.- your exh oxygen sensor may be faulty, causing the engine to run rich.
also check the t valve and cooling fan/s for proper operation both with a/c on and off.
Was it imported new by agents?
maintenance e done as per recommendations and recorded? and not gone down fix it after it goes bust road?
Get a pre-purchase inspection done and make a decision.
