Miyuru Daminda
Everything posted by Miyuru Daminda
  1. Is there a way to prevent water to remain on the windscreen? because my car's windscreen catches thin layer of water during rain (viper blades are new and in good condition). Some suggests that applying wax/polish to windscreen will prevent this. Any idea?
  2. u got my my point !
  3. We can share about how our cars behave in real life. These information will be very valuable for car buyers and will help for owners to keep car in good shape.
  4. Hi all, I'm suggesting to start reviews forum( sub forum) something like this http://www.team-bhp.com/forum/team-bhp-reviews/.
  5. Most of the time it's DIY Many tachos have 4 terminals. 2 terminals to power and another one to dash board illumination line and signal input to ignition coil. Simple as that.
  6. There can't be a direct relation between coolant and break. May be a break bind may cause brake fluid overheat. Even you can check it Assume that your car is front wheel drive To check front wheels Apply hand brake and gear to neutral jack right front wheel and check wheel is rotating freely, then do same for left Shift gear to 1st release hand brake jack right rear wheel ......then left if there is a brake bind you can feel it simple as that, however do this only on flat road if you don't like to get ur hands dirty, just visit a good mechanic. If there is no brake bind next thing that you need to check is master pump ......
  7. If brake fluid is in bad condition ( old, contaminated..) it is more likely to boil fluid in low temperatures that cause sudden brake loss. When did you changed brake fluid? Normally brake fluid should change in every 2 years or 20000km.
  8. Please can anyone tell me a good place to buy a tachometer meter with shift light and how much will cost it. Ah another thing: It should support 3pot engine because my car is an Alto
  9. U.S. carmaker Chrysler plans to file for bankruptcy, Obama administration official says.
  10. Driver Maruti Alto : 140kmph in Kurunegala-Puttlam road. Only once reached that speed because I felt like flying beyond 120kmph
  11. Wearing a seat belt is for more safer than not wearing it for any one For pregnant women, lap portion of the belt should be worn as low as possible across the hips. However drive slowly when there is a pregnant women on board, or during a crash some sad things may happen ... I can't imagine some people never wear a seat belt even they doing 100+kmph . I used to wear it since 1st day of my driving and now I can't even do 10kmph+ without it.
  12. When I'm listening to Lakhanda auto club program, some caller shared a serious problem that faced during emission test. During they testing caller's van, they kept it full rev for few mins and finally engine blowed :violent-smiley-099: Now he have to replace engine. So be careful when testing and never let them to rev your motor more than 3000rpm (NEVER EVER)
  13. Wrong, not all cars comes with a relay because normal electric horns draws 2A-3A that can handle by a switch. But power horn may draw 8A-10A that may shorten horn switch and wiring lifetime.
  14. any idea about the cost of horn relay?
  15. Hi, I just bought Roots Windtone horn. Sounds like a hell , but I didn't installed a relay with horns. Is it really need to install a relay?
  16. Then what about the good interval between potty applying and paint applying? few hrs or few days
  17. I have few questions about body repair. 1. If car's body deformed + scratched little bit because of a accident will it cause corrosion of body after some time? 2. Is it ok to apply paint in the same day that apply Putty or is it better to let it to dry for about a week and apply paint?
  18. Can anyone comment about Wurth wiper blades when comparing with other brands ( Eg: Bosch, Syndicate ) .
  19. Just increased the engine rpm little bit by my self and no vibration now. When I have a free time I'll take it to a garage to check rpm correctly and adjust because alto does not have a tachometer in meter panel
  20. Can't it be a problem with ideal speed control system? Some addition : When engine start in the morning engine speed is higher and reduce after few mins.
  21. Hi, I have a Maruti Alto only clocked 4500km. After engine is got warm, in ideal speed if I turn the AC on I feel considerable engine vibration. If AC off again vibration disappears. What can be the wrong...? *************Sorry it's vibration, but I can't edit title *********************
  22. Is it confirmed that currently cops are not using speed guns?
  23. Nope radar gun will take few seconds (2-3 secs) to get the reading, if ur doing 70-90 kph u may be able to slow down before they got a reading but not probably when ur doing 140+ . However laser guns gives instant readings but I don't think SL cops using it. Most cops have Xa band radar gun. I think radar jammers are illegal ( even in US where radar detectors are not illegal).
  24. Does new EFI car's radiator fan controlled by thermostat switch or car computer
  25. Directly connecting power supply to radiator fan is the cheap and bad solution for thermostat or relay failure of cooling system. When u do this engine will cool more than required and will not reach the correct operating temperature. Running a engine with low temperature will reduce the fuel efficiency and increase engine wear. so better to fix it as soon as possible. I don't think it will cost much.
