Everything posted by kush
NSZT - W62G toyota 08545 - 00v51
Is it for you to fix it to another car, or to replace the set with a aftermarket. Try searching Toyota wiring diagrams it comes with standard connector for audio Following might help to identify the connections
Japanese Car News
Hope it will be good to drive as the Corolla Sport
Issue with Honda CR-V 2018 JDM
Time in the head unit is from GPS cannot change, it will show Japan time
Check For Pending Parking Fines Before You Buy Your Next Used Vehicle
From little i know about the law To get details about the owner from RMV thy will need a court order Then RMV will give details, if Tenaga lawyers has little bit of brains they should ask for details of owners who had the possession at the time of violation. If they go to that stage then you can always deny charges and proving their claim will be with Tenaga lawyers, they will need evidence. As Crosswind says i don't think they stand a chance. Unless the defendant accept the charge.
- 12 replies
- used car
- used vehicle
- parking
- toll
Engine sound after 2800rpm
Check the air filter, filter housing and hoses, clips connecting the housing to the intake manifold. Check the breather pipe, vacuum pipe connecting to the brake servo (technically you should feel decrease in brake assist if anything wrong) These are the issues i could think of
Toyota Carina AA60
Considering the vintage of the vehicle you might not get this at Delkanda. If you cant find it you might have luck in Kurunegala area. I don't think anyone will be able to give a specific shop, you will have to walk around and see. Take a printout
They can't take the car to courts, so it has to be the previous owner. Risk is to the previous owner until the car get transferred.
- 12 replies
- used car
- used vehicle
- parking
- toll
Dr's permit 2019 , budget of 3-5mn
I think it is a good option, has a very good following in UK In SL context since it is a "Nissan" it will be looked down upon by so so ""Toyota/ Honda"" clan. In fact I was considering this for my self then i decided on the Corolla Sport we did not want two SUVs in the family. New face lifted comes with 1.3L engine, plus you will get the warranty and technical support of the agent. And will be within your budget
You cant match the original unit unless you have a very deep budget I was fortunate to get the SD card (importer shipped it separately with the extra key) Once you get used to the menu with little bit of juggling and google translate frustration goes off I have Toyota NSZT-Y66T which has only Japanese menu (no option to change the language) 9" of HD display, FM up to 95, CD/DVD, SD, Bluetooth of cause TV and Navi which does not work here Initially I was not happy with the sound quality then i discovered it was in default, toggling around the menus I found settings that has so many customization options that i have never seen in any of the aftermarkets even at higher end. My only issue us that the unit does not play FLAC, not bothered about Navi as I have got used to the phone Best is to use the unit for couple of months to see whether you really want a change.
Sweet spot for the permit is 1200cc petrol or 1500cc hybrid hence the 3008/5008/CH-R/ Corolla Sport or Aqua/ Axio/ Fit/ Grace/ Vezel/ or New Insight (expensive though) 1300-1500 you get a good choice from the likes of Civic/ CRV/ Audi../ BMW.. / Mercs although personally you will not benifit much unless you're using your own permit
Vehicle for Doctors permit
There is nothing in that price range for the permit You can get a 1.0L T Audi A3/Q2 or a VW, tax will be less than the cost of the permit
Used car/suv around 4.0 to 4.5 million
Mazda 3/ CIvic/ CRV
CH-R/ Corolla Sport you pay only for the car on the permit Only issue rear seat space which will not be a priority for you
Peugeot Parts
No each unique key will have a code which you need to programed to controller unit in the car depending on the car this could be 2-8 or more keys. Once you go in to the programming mode it get initialized so you need to program all the keys. This is the common system there could be other variation, do not know how the Pugs work.
- Toyota axio 161(non hybrid version)
- Corolla 141 spare parts and body parts availability
Peugeot Parts
Try Ali express if your requirement is only the casing Programming need to be done carefully as you may have to reprogram all the keys again (depending on the vehicle) key you're using too
Servicing Audi A!
Got your point, make sense provided you have the previous service records if it is a used car.
Servicing Audi A!
Welcome to the world of Euros, Grey or Black/ White you will have to live with this. There are routine maintenance which you will have to do, replacements that need to be done based on age not mileage. Parts are expensive as they are genuine, a oil filter 4-5K, air filter 10-15K, A/C filter another 10-15K, oil 4-5K per liter (and these cars hold 5-6 liters even a tiny engine). Wait till you hit preventive maintenance where they will start replacing parts Rs. 58K sounds reasonable for what they have attended, even a Toyota could have cost so much at the agents. Service for a Corolla 141 @ 60K km came to Rs. 45K few years back
Repair Tyre Punch
Most of the time you don't even have to jack it up if the nail is in the outer side of the Tyre Locate the nail by moving the vehicle slowly if you have assistance of someone this will be easy. Remove the nail and plug in.
Repair Tyre Punch
I keep a puncture repair kit in the car available through local and international web stores. This is the same kind you get in the wayside tire repair shops. Comes in handy when you do not have a spare and dependent on the car puncture repair kit with the bottle and the pump. This is a permanent solution and most of the time can be done on site without even removing the wheel.
Peugeot 3008 Local Agent Version - Made in Where?
For Pugs RHD will be a very small fraction of their sales. I don't think they will manufacture them in different places for UK and SL, they may be coming out of the same factory. Specifications and features will change for market requirements and preferences.
- Wading depth?
Kdh 2012(201) desel
Black smoke indicates unburden carbon, what did you expect when you remove all the systems that are there to reduce them in the first place. Your fuel mixture may be too rich now, if re calibrating the ECU is possible there may be a solution.
Wading depth?
This is what the owners manual says although the wading depth is given at 300mm there are so many caveats Better to avoid Driving through water Pay attention to the ground clearance of the vehicle. Fast-flowing Deep Water Before driving through water, check the water depth, water speed and the condition of the surface beneath it. The water must not be more than 12 in. (300 mm) deep. Make sure that the door sills and rubber seals are clean before starting to drive. Do not drive through deep or rapidly flowing water. Deep or rapidly flowing water, such as mountain streams or flooded roads, can cause the vehicle to deviate from the desired path and roll over. Avoid producing bow waves by driving at an appropriate speed. Never open the doors when driving through water. Impaired Braking / Soiling Soiling can impair the braking action. Check and clean the brakes if they are soiled. Impaired Steering - Driving in Water Danger of steering assistance failing during a long trip in water if the drive belt slips. If steering assistance fails, more effort will be required to steer. Risk of damage to the engine and accessories if water gets into the vehicle. Before driving through water, check the water depth, water speed and the condition of the surface beneath it. The water must not be more than 12 in. (300 mm) deep. Make sure that the door sills and rubber seals are clean before starting to drive. Do not drive through deep or rapidly flowing water. Deep or rapidly flowing water, such as mountain streams or flooded roads, can cause the vehicle to deviate from the desired path and roll over. Avoid producing bow waves by driving at an appropriate speed. Danger of damage to electrical systems. Avoid driving through salt water. Switch off-road mode on. Switch off the air conditioning compressor. Switch off the headlights. Do not over-rev the engine. Do not perform manual gear changes when driving, and try to avoid stopping. Moving off in water can be difficult due to the high resistance and the loose surface involved. Start driving through water at a shallow place at walking speed. After checking the body of water, take the shortest route through it. Never drive into water with momentum. The resulting bow wave could damage the engine and accessories. Adapt your driving style to unfamiliar surroundings. Drive through the water slowly and at a constant speed. Never turn around when crossing a body of water. If it is not possible to cross a body of water, the vehicle must be backed out in reverse gear. Information The alternator can fail if the vehicle is driven through water for an extended period.
