Ripper
Everything posted by Ripper
  1. well i think driving once a week and only 2-3mins run everyday is not enough to keep the battery. The started motor consumes quite a bit of juice while firing up and to recover that drain just 2-3 mins of running is not enough imho...Actually this even might be the reason for the battery to die in the first place... And also like me, if you have additional electrical stuff like stereos, high wattage headlights etc... those also take away some extra juice from the battery and the car needs to be running to charge it back to shape... On you charging system....If you have a multimeter or a voltmeter you can do a rough check on your charging system... In my car while it's running the battery voltage should hover around 14volts which is where it should be.. If you're not good with electrical stuff...take the car to a decent battery joint and get your charging system checked... Bad rectifier, regulator circuitry is also to blame at times for killing batteries
  2. http://www.cruzinperformance.com/injsteps.html well....manual cleaning is not as easy if you wanna do it right Actually Ruslan...i also think this really work well...once i had a small hesitation issue and my RPM's used to drop really low and stall once in a while... Used the fuel system cleaner and throttle body cleaner spray in conjunction cos it was a sunday and i just had to have the cat back in shape... and it really worked
  3. touch wood...so far i've not had any issues...still didn't face a situ where i had to do a manual cleanup I'm sure it's coming but hey this wurth thing seems to be delaying it quite a bit
  4. well the way things are going... won't be surprised if they start imposing a huge tax on lottery winnings too
  5. well i beg to disagree mate... using something like this before your injectors getting clogged fully will actually reduce the chances of that happening and you physically having to remove individual injectors and do a manual number one by one...
  6. to answer devinda's q on the other thread... IPTV has some major benefits over standard cable or sat tv... for starters...all usual tv programs are stored on a central server and if you miss anything you can always recall that episode or whatever and watch it at your convenience... and also...you can pause live programmes like cricket matches... say sana is having a go at the opposition and you just have to take a leak... press pause... do ya thing and get back and watch the match from the place/time you left off... of course you'll be slight behind that actual action but hell you won't miss anything... if need be you can FF thought boring stuff and catch upto the live game again... also unlike my horrible dIalogTV at present that hates bad weather or anything close to it... since IPTV is via cable lines... weather won't interfere with reception... IMO...those few pointers alone make the product a real good one... But their adveritising of course is really horrible... They have done a crappy job at explaining the product to people... If they can get good programmes on board... it'll be quite a good product offering
  7. errr whas up boss
  8. actually machang it's a very simple scene... Maybe i ave too much of weigh to it earlier un-intentionally The wurth injector cleaner comes in sealed can that you can add to your fuel tank when it's full... I think packaging does give some indication of fuel to treatment ratio... I just pump full tank of gas and add the treatment and that's it... Supposedly the treatment cleans it's way to the injectors and clean the injectors themselves... I don' think it's something you should use and expect super results if your injectors are badly clogged and messed up... I use it as "preventative maintainence" twice a year and so far no injector issues can't remember the price but it's less than 1500k or something around that area...
  9. heh heh... doubt that the case here
  10. manual meaning...spraying straight into the throttle body and into vacuum hoses???
  11. The real shocker these days would be to hear something having a price reduction we're so used to seeing price hikes it doesn't even register anymore what a sorry state of affairs eh?
  12. or invest the savings on some cold adult beverages Next best thing for a thai massage me thinks
  13. Ripper replied to sira's topic in NISSAN
    hate to get into this Toyota vs Nissan debate but if you compare a 121 against a N16 which i assume to be the competition... the 121 easily commands a lead when it comes to re-sale value and that i believe is a fact... The annual running costs for both cars is another debate but going by the limited inputs i've got from friends who own both cars... the obvious brand seems to be better over the other there too but that's just my opinion And i have the right be wrong
  14. Yep. I use wurth twice an year as recommended by one of my uncles who runs a garage... I think 3M is also pretty good but it doesn't go through the fuel tank itself... I went with Wurth thinking it'll clean the entire fuel system and not only the injectors
  15. Bloody Chip Foose was behind that too???? damn that man is a legend
  16. heh heh...even manufacturers will be shocked at the mpg values some sellers quote on their vehicles maybe the car was in neutral as it went on a slow decline Don well going for an older model will have it's own problems right? and guys...end of the day if you wanna be moving about in a car, there are certain "sacrifices" you gotta make... especially in SL at the moment. When you weigh pros and cons of the situ of our friend... i still think his present ride and it's figures can't be beaten so best to adjust "other" budgets and get on with life
  17. Ripper replied to ash's topic in General Automotive
    well there's a segment of folks who were barely able to keep a vehicle for personal use... and with increasing prices in all fronts are making them get rid of these vehicles i think... had a chat with my local service station fella and he was on that opinion... Properly maintaining a car these days is quite a costly affair sadly...
  18. well 14kmpl in maruti with bad ergonomics, little safety etc etc...i'd still take the far better 10kmpl option with a better car... talking about bikes...i had an NSR 250 for like 3 days and it never did anything more than 10kmpl Of course i was a lot younger and dumber so holding back on the throttle was never an option and man 10kmpl was worth it
  19. Ripper replied to sira's topic in NISSAN
    yep... Nilantha its time you make your case properly man! It's not at all fair to be dissing a brand or a model without giving valid reasons... right or wrong let's get it across so we can discuss it...
  20. yep... it think there is.. at least was but folks always find a loop hole in regulations and exploit it...
  21. some pics http://www.flickr.com/photos/27464878@N05/
  22. Ripper replied to sira's topic in NISSAN
    Because it's not a TOYOTA!
  23. well guys I was there sunday and took a few pics. will upload them somewhere and post a link here for all to see Not the best of shots since i don't have a fancy cam just yet About the show.. Like Dilesh said... It was ok. Not too bad as a starter i suppose. Navy had one of their IPC water jets on display...fully armed with LMG's, forward mounted 23mm canon... and rear twin barrel 23mm canon i think. They also had two "arrow boats" each having twin 200Hp outboards armed with what looked like grenade launchers and some high caliber guns... The arrow boat is made in SL by the navy and seems to be quite a capable vessel... A*W had 2 jetskis and 2 boats on display with lotsa outboard motors. One vessels i checked was 4mil minus the motor... and with it it was 6mil+ Most boats on display didn't have 100% perfect finish. Railings were not secured properly and the rubber skirting on the edges were not secured properly etc etc... But gotta admit that i never knew we did export so many different varieties of boats to other countries Personally i preferred the boats made by Neil Marine. They had the best finish out of the lot displayed and the styles and lines of the boats were just plain awesome... await pics
  24. yep but we don't earn in US$ now do we
  25. how about an FB15 or an AE110. One of my office mates just sold his FB15 V*P model for 15.5 or summin.. you might be able to hunt down something like that for less...
