Everything posted by Ripper
Gunners Supercross, 2010, Minneriya
even if you leave aside his superb skills behind the wheel...both his cars seems to be performing really well...
Toyoto Hilux Vigo Height Lifting
oopsie...my mistake!!! didn't see the 2wd part imho it's pointless having a truck that's 2wd
Honda Civic Ek3,fb15 Super Saloon & Toyota Corolla Ae110,which Is The Best
fanboys galore!!!!
Aravinda won the championship. Very aggressive race it was with super driving by the top 3. Pasindu's car seem to put the most power to the ground cos the moment he got the lead...he just rocketed off. Some of the best driving all season imho.
Dihatsu Charade G100 / G101 / G30 (Diesel)
a colleague at work had a 65- one sometime back. no idea what the model is but he had a tough time selling it though it was in very good nick for it's age... the only problem is to get a car that's not hacked and in decent shape. diesel charades are driven mostly by very economy minded folks so most of em are not cared for that well. this is just my personal view from seeing many examples on the road etc... Si if i were you i'd think twice about this and if you really want one...take your time and wait for a good specimen. weekend sinhala paper classifieds should be a good starting point... In terms of fuel economy...my friends car was very good in fuel, decent comforts etc but parts were somewhat harder to source. especially things like lights and other body panels etc
Help Me Choose Between A Premio And Corolla
The premio is a bigger car for a 1.5 litre motor so chances are it's underpowered. On the other hand the 141 should be lighter for a 1.6litre motor and a newer car with better technology etc etc.. So if you want to stick with toyotas maybe it's best that you consider mechanical and body condition or both cars and see which will give you more trouble free years. I do understand your point on colors but unfortunately in this category of cars color doesn't give you much when it comes to resale. It's tough to find somebody who would pay a premium for a toyota sedan. In more "passion" driven cars folks are willing to dish out that extra premium for a more distinct and unique color... on the other points you raised... lookswise personally i'm not a fan of either cars but 141 should have better market acceptance due to it's "corolla" badge over the premio. Fuel economy should be more or less the same... either way...both are good cars in their own right so you can't go wrong
the vigo is already quite tall with good good ground clearance. If you're injto offroading and the likes a lift is ok but it will affect your road handling and balance. these kinda vehicles already have a higher center of gravity so you'll be making hta even worse with a lift. Outdoorsman, 4x4 motors etc all do lift kits..you'd have to go for new shocks etc... ARB, Old man EMU, Rnachos all get the job done
Ae 110
yiiiikes!!! that looks horrible!
2000 Mazda Tribute
that's funny cos i have a ford and the engine is from mazda
Window Tints-what's The Deal???
well some slave there must be cursing you and compiling a standard mail format they have to reply
I'm also thinking of getting tints done to the truck...damn heat is a bit of a botch these days... had like a light tint on the car front shutters but never got into trouble for it... just to be safe i'll fully tint the back and the canopy... It'll be super if the cops or somebody can clearly state the law as it stands today. this is one bloody mess. Even during war times things weren't this bad
Ran Engine Without Engine Oil..... Oooops.. Need Help!
and often does an engine start burning oil for one to be crazy to do an overhaul? valve stem seals are just a top end job which take little time and relatively little money to fix. To go around a simple issue like that and adding thicker oil is rather stupid imho... because there is no way to properly judge the amount of wear to decide on a particular weight of oil. Also just by trying to get thicker oil to plug gaps in an area like the stem seal you're also making the piston work harder... The thicker oil doesn't only go to the stem seals...it circulates all over and make everything run harder. Including things like the oil pump. but as always...we can agree to disagree!
there is a reason why the original manufacturer recommends a certain viscosity for a particular motor. If the motor is burning oil...using thicker oil is not the solution...it's just a temporary plaster. And to use thicker oil...how do you judge how much exactly the engine has worn out to use a certain viscous oil? Do you just just guess and say...ah ok...lets use 80w or 130w
Ac Compressor Problem
if you feel that the issue has got worse over time and happens only with the AC on...most probably your AC compressor might be shot and not turning as smooth as it should causing the engine to strain.. A good AC guy should be able to checkout the compressor for you!
- 2000 Mazda Tribute
Taprobana 4X4 Challenge 16Th Oct 2010
it took a JCB to pull it out
http://www.facebook.com/album.php?aid=240368&id=607877343&l=08e58f4800
2000 Mazda Tribute
shaaa...dont you just love this guy! well said matey!!!
R*D B*LL X- Fighters Jams
thanks mate.... will be there for sure that's a previous event they've done so should be a cracker!
using thicker oil as someone suggested is a big no no! if you have an oil burning issues it's best to address that specific problem rather than trying to go around it an make things worse in the long run. Thicker oil will not travel fast enough to top end of the motor on startup due it's heavier viscosity. Startup friction already is one of the biggest reasons for engine wear out and you wouldn't want to make things worse. and on the oil light...according to a toyota workshop manual i had sometime back... The actual low oil pressure point where it's very dangerous for the motor is even below the point the light comes on. meaning you can drive a bit with the light on. But ideally it should never come to that point. Oil level checks are supposed to be done every other day or so including other regular checks like brake fluid, air pressure, coolant levels etc... When you get into the habit of doing these it kinda comes naturally...
thanks shai... yeah 70 sounds decent and 3-4 hours is ok i suppose. The truck can hit 100-120 without too much of hassle but control at those speeds isn't comforting...especially after seeing so many crashes these days... yeah last time returning from sigiriya was bit of a bitch though with quite a bit of traffic on the road but don't have a choice in that matter. i will be out of the track the moment the races finish!
oil pressure bulb is supposed to light up when the pressure gets low but an electrical or related issue can always cause for it to not light up. it can even be a burnt out indicator bulb so it's best NEVER to depend solely on that. You should check your oil level at least once a week if not even more frequently. A regular tuneup wont make you loose oil at all. unless of course somebody drained the oil and didn't fill it up properly. or changed the oil filter and didn't screw it on properly making it leak oil etc oil loss IMHO happens only two ways...one is with some sort of a leak in the system and the second being the engine burning oil with combustion. If it's the former you should see oil leaks visible on the garage floor or on the engine and the bottom parts of the car itself. If it's the latter...you should see bluish smoke when the motor is running... either way it's relatively easy to spot the problem. Engine flushing wont achieve much in your situ. Personally i don't believe in flushing unless of course you're changing oil types or have had very badly degraded oil in the motor. I would say...first see why you have lost oil. is it a leak or is the engine burning oil. after that's sorted you can check why the oil light didn't come on.
Increasing ???
with lending interest rates coming down lot more people can afford to finance cars. the hitch is for people who can afford say 2.5mill or less....there isn't many options in either recon or brand new euro/jap market. so for those who want a non-chinese, non-indian car...options are very limited. Older popular jap cars in good shape fills this segment of the market and cars in good condition can demand a high price. If you talk to people who have been on the hunt on this budget bracket for a used jap car...they'll tell you how tough it is to find a good car. most these popular models in good condition gets sold within days of advertising if not hours even if the price is deemed high by many classic supply vs demand scenario There are so many people who hunt for specific models and the corollas are strong favorites for a lot of people.
A Toyota 121 Accident
i think he's fighting for a bit of common sense!
Buying Toyota Corolla Ae110
exactly...not only morons but also fake experts like dilukshan who yaps utter rubbish
