Kavvz
Everything posted by Kavvz
  1. No worries at all... But sad state of affairs really on how ATV's are registered- But to be expected I suppose. Sri Lankan bureaucracy at its finest! ? !!
  2. Nice looking CUV though, but I'm biased as I think the Rav4 is a pretty nice looking (and well thought out) CUV.... Is the Suzuki ACross (weird name though!) priced cheaper than the Toyota Rav4 its based on @iRage? If so they might be onto something there, as I guess it would make sense to rebrand it and sell it at a lower trim / price bracket and boost bottom lines at both sides a bit rather than compete with each other...I mean no point Suzuki spending money developing a competing model only to have the Rav4 come kick it in the nuts...?
  3. @Magnum is at this point probably beside himself with excitement at someone else on the forum buying a Hiace!! ?
  4. I never use seat covers. I prefer using the seats and enjoying the nice finish myself instead of preserving it under a seat cover for the next owner... ? Also seat covers interfer with some side airbags, so if your seats have an airbag tag on them: Avoid using seat covers. I do use rubber mats in my car though as otherwise it gets messy. I don't have 'full carpeting' where they lay rubber carpet all over the floor of the vehicle. That's just silly. I just buy 'all-weather' vehicle floor mats which are readily available from Arpico, Amazon , Ebay as per your preference and budget.
  5. Sounds like there is some sort of fouling into the intake mixture (probably coolant leaking into the ignition mixture as you mentioned white smoke) due to a worn engine / head gasket issues etc and the o2 sensors are picking up abnormal exhaust fumes and throwing the engine into limp mode as a result... I wouldn't drive the car further and would recommend getting it checked out by a mechanic as soon as possible. machang මෙම වාහනය ධාවනය නොකරන්න. හැකි ඉක්මනින් කාර්මිකයෙකු වෙත ගෙන යන්න. මම හිතන්නේ සිසිලනකාරකය ජ්වලන කුටිවලට කාන්දු වන බවක් පෙනේ. එය එසේ නොවන බවත් එය වෙනත් දෙයක් බවත් බලාපොරොත්තු වෙමු. නමුත් මේ වන විට අලුත්වැඩියා කරන තුරු මෙම මෝටර් රථය තවදුරටත් භාවිතා නොකරන්න (As the check engine light is on you could run a scan on the car to get some idea of what may be happening, but even then, run the scan with the ignition turned on and the engine off - with the switch in the Aux. setting. Either way I would get the car seen by a mechanic asap.)
  6. Kavvz replied to Watchman's topic in The Lounge
    Very much so @matroska And especially this one with the port-hole windows: Its one of those cars that you'd want to preserve and have around the house to enjoy. A very nice looking car indeed and the ideal runabout for a quick 'kaade paan' run!
  7. Kavvz replied to Watchman's topic in The Lounge
    I think you guys were all in the money but @sathyajithj99 got there first. Floor is yours!
  8. Kavvz replied to Watchman's topic in The Lounge
    Very close. You guys were all pretty much there...
  9. Kavvz replied to Watchman's topic in The Lounge
    And okay here we go:
  10. Kavvz replied to Watchman's topic in The Lounge
    Wow: That's pretty! Is there a story behind this one @matroska That looks very unique?
  11. Kavvz replied to Watchman's topic in The Lounge
    A Daihatsu Charade G10 or G20?
  12. Kavvz replied to Watchman's topic in The Lounge
    Nope no rules regarding open / closed boots...all good. ( But this1992 ish Nissan Sunny ( B13 ) SuperSaloon boot has no jackfruit in it so: ? )
  13. Same oil and air filters are fine @thusharak340 No issues there at all.
  14. Kavvz replied to Watchman's topic in The Lounge
    That would be jackfruit my friends: Delicious made into curry or boiled and shredded onto burgers with bbq sauce! (In the back of a Toyota Yaris / Mazda 2 Hatchback...)
  15. Mostly Baseless, I think as: While it's true that a car sitting in traffic vs a car running on the highway will take longer to reach its 10,000km oil change mark as long as you change the oil within the 10,000km limit or within 1 year whichever comes first; generally you are well within the tolerances of oil life and lubrication property lifespan that most Fully Synthetic oil is designed for. Also please note that while some oils are marketed as synthetic engine oil sometimes they are synthetic oil blends. (Synthetic oil + mineral oil. This applies to fancy name brands such as mobil as well -Only some grades of mobil synthetic oils are fully synthetic, some are blends.) So the lubrication properties and the oil change interval may vary based on this fact. Also at the end of the day there is definitely no guarantee that if you use fully synthetic oil your car will run past the 200,000km mark with no problems, it will not have engine sludge etc. But what you are doing right now (using fully synthetic oil and changing it at the 5000km mark) will certainly help keep your engine in optimal condition as much as possible. And hopefully you will be able to use the same car past 200,000km as well. By stretching out the oil changes to 10,000km while using fully synthetic oil will you be able to do the same: Probably. Would I recommend it? I don't see an issue. Do I do the same: Yes ( I don't use the same brand of fully synthetic oil as you though) Can I guarantee that this is good for your engine and that you will have no issues running the engine past 200,000km? No. Can I guarantee that by using Mobil fully synthetic oil you can stretch your oil changes to 10,000km and run the car past 200,000km without any issues; No- No guarantee. And if anyone gives you such a guarantee I would be extremely skeptical. Will you probably be okay stretching the oil changes out to 10,000km with Mobil fully synthetic? Yes. But that would be the same for any well known name brand of fully synthetic engine oils (including Mobil, Castrol etc and most likely Havoline as well.)
  16. They are probably saying that because some agents in SL use Mobil fully synthetic and do 10,000-15,000km oil changes etc. While maintaining warranty and for those cars Havoline fully synthetic isn't rated (it doesn't meet the manufacturer's specifications). That being said as long as you want to maintain your warranty status you'll have to follow along with their guidelines, no point losing your warranty to save a few bucks and then regretting it later.
  17. You're living the good life then @speed8 !! I envy you! (Dad taking care of most of the bills, and your mother still cooking for you and and taking care of everything else! Man those were the times! The best years of my life really.... )
  18. Well you can try. Also note some service stations / gargages have external charges that have a 'battery repair' option that helps get rid of deposits and scaling that could be fouling cells, but here's the thing, the issue with your battery may not just be current draw and charge retention but also voltage fluctuations. 8 years for a cheap battery is pretty good. I've always had to replace my batteries around the 4-5 yr mark and that's despite buying fancy batteries claiming to last longer and perform better etc. So really the time maybe right to invest in a new battery. No harm in trying to resuscitate the old one of course. Nothing like reusing and recycling...but just so you know you might have to think about getting a new battery to truely solve the issue.
  19. Also he's a 'hell of an enthusiast' but doesn't even know what car to buy? Please... At 12 I had a list of 'first cars' I wanted to buy!
  20. Wow! Crazy stuff...1.9m for just the documents! Hoooly! (Not that its right at a lower price but still !! )
  21. I would recommed this as well. It seems as your battery is faulty. It maybe holding charge but a couple of weak cells are possibly throwing the voltage off (these issues are exacerbated by cold weather which is why the car is behaving normally in hotter climates).
  22. (Fat guy problems!) And commuting while 'hun-angry' has proven to be the root cause of many spousal disagreements in our household @Devinda_Z so really its a heath and wellness issue at this point not to!
  23. Wow. I always assumed stuff like this would happened dingy repair garages or in some back alley but never did I think I would see people taking out ads etc for shady illegal deals! ?
  24. Decent solutions above (WD40 does leave a residue though, which won't harm paint but it will attract dust) but why complicate things? Just buy a packet of baby wet wipes from any supermarket and keep them in your car (not the wipes with alcohol, unscented baby wipes with water on them). Not only will you then easily be able to wipe off bird poo, but more importantly they will also be handy for wiping off malu paan / short eats or kottu residue off your fingers
