Everything posted by nira74
Flood Victims (automotive) - Learning Points
If turning back or taking an alternative route is not possible, other option is to knock off the engine and have the vehicle pushed across - as a lot of folks with vans actually got done at Ja-ela.... of course there were plenty of dip-sticks around to do the job - for a fee of course.
Nissan Fuel Economy Survey
YOM: 2000 Transmission: Manual Engine: QG-15DE City Driving: 9 - 9.5 km/l Outstation: 12-13 km/l
Volkswagen Passat
1.8T Engine is known to develop sludge if not regularly serviced and maintained.
98 Honda Integra
....."Reputed car dealer with a long history of dealing with Hondas......" sounds familiar,..... if it is one Bearded dude down Dutugemunu St. with an English sounding first name steer well clear of the Crook ! I was duped by him some time back....Excuse he gave me was that Autovision expert recommends not to wash engines so that is why it was so oily.... he had even gone so far as to lower the pressure of the tyres so that the loose suspension would not be noticed.
Spark Plug For Fb15 2003
I own a 2000 YOM Wingroad with a QG15DE Engine. Recommended plug is NGK BKR5E-11. A*W once fitted BKR5E Std plugs - re-gapped to 11mm. Currently running BKR5EIX-11 Iridium plugs generally advisable to stick to the recomended plugs in terms of heat rating.
Accident Of A Subaru Wrx Blue At The Kolpity Junction
Would he be in trouble over the legality of the car as well ? - regular 1500cc import with different engine no and higher cylinder capacity ?
Nissan Wingroad Fuel Consumption
I've been running a 2000 YOM Y11 Manual for the last 6+ years and I get 8.5 to 9.5 km/l in Traffic. However I run on 95 Octane fuel. This figure goes down if I run on 90
Speakers
Check out the owners manual of your Head Unit.... probably will find that it is not recommended to user 2 Ohm speakers
Smart Cab
Went to the Garage recently and was shocked to a brand new one in stripped down of all accessories and seats, being prepared to be converted into a Double Cab....
Bluebird Engine
1998 onwards the SR18DE was replaced by QG18DE which is 1769cc whereas SR18DE was 1838cc... SR18 Engined Bluebird and Primera was subject to Luxury tax.... so if you're buying a second hand one now, gotta make sure you get all the Luxury Tax vouchers from the previous owner, or else you will run into problems transferring the car.
Frameless Wipers
Any comments from those who have used them ? Did some referring up on the net and most reviews of even the renown brands say that the edges tend to lift off the glass causing a smearing effect.
Avoid Fancy Dust Caps ......
Agree on the Steel Valve Stems, but it seems a bit much to have to use loctite or WD40 just to keep some crappy dust caps from jamming up. Hereafter will stick to the regular rubber ones or the Nickel / S.Steel ones with a rubber gasket which I have been using without any issues (or loctite..) for the last 15+ years....
Some time back, I bought a set of nice looking dust caps which came in a fancy pack and was quite expensive compared with regular ones. They had metallic blue and red ones too but i chose black. Yesterday when I went to the shed to inflate the tyres the guy there said that the dust caps were stuck and better to get them removed at a Tyre shop because one of the valves was broken. Had a hard time finding a tyre repair joint who was open on Sunday evening, and that guy to charged me a Premium for replacing all 4 Tyre valves (I think he figured that no one else was open and I hadn't a choice...) Turned out that the Dust Caps were made of Aluminium which oxidizes on the inside after a while and jams the threads on the valve stems.... ! Take my advice and get rid of these dust caps if anyone of you uses them.... Picture of what was left of my Tyre valves...... dust caps still cannot be removed....
Autolanka Funniest Moments
have come across this car quite often on the Negombo road. Funny thing is that it is driven by a fairly elderly gent !
Mini Traveller
Snapped this outside a post office when roaming the streets of Stockholm recently. Pretty Neat !
- Toyota Specialist Or Good Garage
Guys work is good. Been going there for some time. Reliable guy and he does not take longer than necessary to finish a job on account of the number number of folks waiting to get their cars in..- Autolanka Funniest Moments
- Grounding Wire Kit For 1nz And 2nz Engined Cars.
Would advise a bit of caution on the 406 ... it's notorious for extra sensitive and fragile electricals. For example on BMWs the ECU even measures the resistance of the wiring and would start throwing fault codes if it got any 'Non Standard' readings. Peugeot may have the same issues. PS: Thanks for the Great Share and Post JadeyBlitzen .... I'm gonna try this out on the Corolla.....!- Autolanka Funniest Moments
REVERSE SENSORS...S....S- Bmw 760li V12
He, He,.... CC badge stands for Consular Corps. - found on Diplomatic Vehicles, but in this case the colour of the badge is unusual .... usually it is white text on black background.... first time i've seen black on white- Bmw 760li V12
as per my info, it was an insurance write off which had a 'cosmetic' make over.... not to mention the cheap darley road additions on the bumpers and doors. .... i don't think there actually is a production BMW 780....- Experience With Indian Alto
Just my two cents here.... but there is one distinct advantage the Maruti has over almost all other brands..... especially when it come to careless folks who frequently lock their car with the keys inside..... No need for Slave Island locksmiths or complicatedly bent dress-hangers..... all you need is a bread knife to pop the lock from the outside. The wife perfected the technique when she used a Zen some years back... but it still works on the current 800s, Zens and Altos.- Wanted Pajero Io Or A Honda Hrv
A Good Buddy of mine bought one recently and now calls it his 'Pajero Aiyo'........ on account of all the trouble he's had with it...- Spark Plugs
Set of 4 NGK Iridiums off e-bay cost less than 35 Dollars from the US including postage to Sri Lanka. No issues at all, and the postman delivered it home a little over one week after purchase. Some models specify Platinum plugs only. Some time back I was advised by the Nissan agents not to use normal plugs on my Bluebird SSS as it may mess up the ignition coils. Those cost quite a lot (around 9.5k for the set) but the recommended replacement interval is very much longer than normal plugs. There is no observable performance gain from changing from normal to iridium or platinum plugs, but the more expensive plugs last longer IMHO. - Toyota Specialist Or Good Garage
