Mani
Everything posted by Mani
  1. Mani replied to Watchman's topic in The Lounge
    Holy mole, You figured it out with just that picture of the reverse light?? Impressive...
  2. Mani replied to Watchman's topic in The Lounge
    Good call Schiffer...
  3. Mani replied to Watchman's topic in The Lounge
    BTW. Not a Japanese...
  4. Mani replied to Watchman's topic in The Lounge
    Little more...
  5. Mani replied to Watchman's topic in The Lounge
    Nope..
  6. Mani replied to Watchman's topic in The Lounge
    K let's try this one...
  7. Mani replied to Watchman's topic in The Lounge
    It was a 1964 220S. I don't know the W# so who won?
  8. Mani replied to Watchman's topic in The Lounge
    Try this one.
  9. Mani replied to Watchman's topic in The Lounge
    Ford Granada?
  10. Mani replied to Watchman's topic in The Lounge
    280 or 260 Z
  11. Someone else take it please.
  12. BMW 8 series 2 door coupe??
  13. Mani replied to joybook's topic in TOYOTA
    Know what you're getting into first. I was a proponent of Hybrids in SL until I started looking into service side of the equation. Below are some parts that is Hybrid unique that if goes wrong will set you back few bucks. Parts only pricing. All in US $$ and the cost in US. In SL prices may be significantly higher + labor if you find one that is qualified. HV inverter $3,800 AC Compressor $2,800 Battery pack $5,000 Transmission $3,500 --- $7,000+ depending on what went out.
  14. Cadillc
  15. Finally got one... Someone take my turn please.
  16. Camaro.
  17. Don your PM is full... The sharing garage option can be seen when you're on-line as you access your garage. There is a tab called 'online' where the shared cars are located as long as the person you're playing with chose to share.
  18. It's on this weekend. Look for a room called 'slow banana'
  19. Mani replied to MADZ's topic in The Lounge
    Squirrel circumcision...
  20. Easy way is to go under the car and locate the fuel feed line where it transition from hard line to a soft line. It is very near the tank and should be held by couple of clips. Undo one of the clips and pull one side of the rubber hose out and let the gravity do its thing.
  21. I'm in the Pacific time zone.
  22. haven't been on-line in a while. My tag is DDRRIIFFTT... Note: I'm 12-13 hours behind SL time.
  23. Pretty sure it will not work on the 2nd gen. Definitely no on the 3rd gen.
  24. Mani replied to Naz's topic in Mechanical problems
    Don't flush the engine before you find out if your engine does have a sludge problem and how bad. Just remove your valve cover, which is fairly easy to do, and look at your cam area for sludge build up. If there's a heavy tar like build up then you don't want to flush the engine. All it's going to do is loosen up all that junk and clog up your oil passages making a bad situation worst. If there is no sludge, then your problem is somewhere else.
  25. Sifaan, Click below for the links to the forums. They are in French. http://www.google.com/search?hl=en&source=hp&biw=1280&bih=585&q=citroen+c5+climatisation&aq=1p&aqi=p-p2g8&aql=&oq=ci
