Everything posted by VVTi
Toyota Considers Corolla Recall Over Steering Problems
- Engine Temperature Will Increase 90%
Check the pulley and see if the belt is loose or slipping there... then you can flush the radiator and see. DIY. Remove the drain nut at the bottom and hold a water hose at the top and flush off the gunk... you can run the engine for a short while to circulate fresh water to wash out the insides as well. See if there is a lot of muck. Tick off all the possible scenarios,- Radiator Woes
Brasso, Silvo, WD40 and SuperGlue.... you have no idea how useful they are.... my tool kit has all 4! Even took the SuperGlue and the WD40 on my Jaffna trip. Just in case....- Radiator Woes
This what it will look like... later on I had it polished with brasso... ) he he he he he.... why stick conformity? http://yfrog.com/eudsc01115cj- Engine Temperature Will Increase 90%
Yep, normally it is driven by a pulley that is run off the belt that is connected to the alternator on many models. Check if that pully is slipping. Check the fans like someone said as well. But normally at high speeds the oncoming air tends to cool the engine, that's why normally you see drop in the gauge when going at moderate to high speed with no load (no climbing or hard acceleration). But if your engine is heating up at high speeds, it could mean that the water is not circulating through the engine enough. If your engine is working normally with no boiling or leaks, First to check should be the water pump. Also when did you last flush the radiator? It might be a blockage there as well. Again, due to no water circulation.- Toyota Pltz
Great Car. I had one. Minimum running costs. Toyota reliability. Get the 1.5 litre one. It has enough power to get you a decent ride, plus the all important fuel consumption figures are great.- Radiator Fan Noise
Is one of the blades bent or broken? I know of one situation in N16s where the motor bearing wears off and it makes an almighty noise... only remedy is to replace with a new fan motor... since the motor is a sealed type. Check the mounting brackets for any breakages, cracks or loose mounts.- Radiator Woes
i did mine in Copper from Lionel Radiators, cost only 6000 for the top tank as I had the same issue Ripper has... till the day I sold the car, the fix worked.. from August 2007 till last December.. no issues, no leaks... they gave a 12 month warranty also.- Engine Temperature Will Increase 90%
Check your water pump, and see of the pully is slipping. Sometimes at high speeds the pulley slips and not enough circulation. Happened to an old Accord I had few years ago. Changed the pump completely.- My Mark Ii Engine Wrecked
I think you should rebuild too.. perhaps its not as bad as it sounds... get another opinion by another garage.... give this guy a call, 0777738011 (Chulan).- 260 Z
- 260 Z
Curious to know... how long were you running the engine with no water or even glancing at the temp gauge? For an engine to knock out due to overheating the issue would have been there for a while? How often did you check the coolant levels? Maybe there is a lesson to be learnt here for all of us.- 260 Z
- 260 Z
- What Is The Best Brand Of Car Detailing Wax
Hunters and Browns...- Windscreen Repairs
Dear Mr. Wijesinghe, with all due respect, in 2007 the car I had at the time had oil like film on the inside of the windscreen right across. This made driving impossible in the night or rain. After trying many ways to get rid of it I saw an ad you placed in the ##### and I came to see you. You took one look at the problem and said, it will cost Rs. 15,000. I was actually desperate enough to agree and go ahead. But since I did not had the money at the time I left thinking of coming another day. You explained that your product is sourced from the US and etc.. basically you told me exactly the same things you just posted here. On the way out I took a look at what your staff were doing and all I saw was a white paste that smelled live Brasso/Silvo being used on another windscreen. This gave me an idea and I bought one on the way home and tried it and Voila!!! My problem was sorted within 60 mins!! So in my mind, you could have used the same thing on my windscreen and charged me the Rs. 15,000 without an ounce of remorse. Later I also found out a replacement windscreen would have cost only Rs. 17500... would have been cost effective if I smashed it and claimed from Insurance, don't you think? I had a similar situation with another very well established company in Sri Lanka whose Director oozes respectability and charm. He invoiced me Rs. 25,000+VAT for an item that he 'allegedly' replaced in a product I have at our office during the course of a routine service. When questioned why, he gave me a long speech bordering on aggression that I should not question his expertise and only HE knows whats good for my product, etc etc.. I told him to kindly remove the part and take his aggression and respectability elsewhere where someone gives a damn. Later I contacted the factory that actually manufactures this part in the USA and had them deliver it to me via NORMAL post. My total cost? USD 38! That's less than Rs 4500.... you do the math on the profit margin.. it borders on robbery. I will leave you to ponder about what ails this country when it comes to businesses ripping people off... Thank you for your time.- What Is The Best Brand Of Car Detailing Wax
Hmmm... when you turn towards JAIC Hilton from Union place, go past Cargills, turn left and as you come to the T junction its to your left.- Windscreen Repairs
machang, Silvo you can buy from any place... check teh supermarkets.... it is the companion product for Brasso... but Silvo worked better than brasso for me. Try first with Silvo before you crank up the intensity. try to hold back on the super cut till you see the results from Silvo. Its about Rs. 120 and it worked fine for me. Better than parting with multiple thousands on a strictly DIY job.- Windscreen Repairs
Hope you are not the guy next to Lalsons.. Because he was about to charge me 15k for a chronic smudge job that I got done with a bottle of Rs. 120 Silvo....- Smart Cab
Be careful when you drive these with Dual Purpose licenses. One of our office vans is registered as a LA and the driver got slammed with a fine for driving with a DP and the company also got hit a with a fine for letting an ;unlicensed' person drive the vehicle. This was last month. If that is the case, not all cops are aware.- Civic Ek3 To Sir
I just visualized peri coming in his VZR with a big rake strapped on to the roof and commence... 'raking muck'... Ha ha ha ha.. Sorry Peri... you opened up yourself to that... ) No offense, since most in this forum is practically in perpetual PMS... either they are sensitive to criticisms or their nipples are tender.- Civic Ek3 To Sir
Ahhh.... reminded me of the choice stuff we had in Hikkaduwa last weekend.... Thanks Da Kool guy... needed that comic relief.- What Is The Best Brand Of Car Detailing Wax
What is the car you have? What is the paint condition? If I were you I would start with a cheaper alternative. Try Motorcde, he had some good brands. Most places charge about 10K to do a good detailing job and I went and bought stuff from all over and do it myself. 3M liquid polish/wax would be a good start and as you go along you can experiment with different brands.- Ac Usage
If you maintain a constant temp of 22-24 it will be ideal for both passengers and the car in general. In sri lankan conditions there is no way a car AC can do 18 (min temp) setting, this will only cause the compressor to be engaged all the time, using up more fuel and cooling the interior to an uncomfortable level at times. By keeping at a comfortable setting, the compressor has to work at a minimum level to keep the inside cool and you will not feel that cold on the long run. Also, I as a habit switch off the AC, but keep the blower on during the last 2-3 minutes of the journey as it will dry up any condensation that was built up during the usage and prolong the life of the cooler inside the dashboard. and it help to keep my glasses from fogging also... - Engine Temperature Will Increase 90%
