SeanD
Everything posted by SeanD
  1. But what part of the video made this clear? I'm not talking about playing CDs here. At no point during the actual test was the radio (or any electrics, from what I could see) ON. I would be more interested in what would have happened had he left the radio on. I am aware that lightening isn't attracted by radio waves, but cars still have antennas. Will a radio that is ON cause the lightening to be conducted to it, or a voltage surge and explode? That's my question. This was not even addressed during the video. Really, they should have left everything running, because you're more likely to be driving (or stuck in traffic) in a thunderstorm, than sitting in a parked car. It's kind of like how they said it's OK to use your cellphone during a thunderstorm. And it was, until people started getting plowed by lightening while on their cellphone.
  2. SeanD replied to Smart accu's topic in HONDA SRI LANKA
    They certainly are NOT, these days
  3. I failed to get anything related to the question from this video. Sure, the radio worked after the lightening stopped, but that's not the issue at hand. I would think there is some possibility of problems, mainly due to antennas. I can't find anything much online, but I did find this on a US govt website, talking about 2 way radios. I would thing the same could apply to a normal car stereo as well: "While inside a safe vehicle, do not use electronic devices such as radio communications during a thunderstorm. Lightning striking the vehicle, especially the antenna(s), could cause serious injury if you are talking on the radio or holding the microphone at the time of the flash. Emergency officials such as police officers, firefighters and security officers should be extremely cautious using radio equipment when lightning is in the area." http://www.lightningsafety.noaa.gov/outdoors.htm Anybody know anything more about this?
  4. Was it just one day or does it keep happening? Is it the level in the bottle or the radiator? If it's the bottle, as I've said above - the coolant level in the reservoir will rise and fall depending on the heat in the system, it will usually be fuller when the engine is hot, and later goes down as it's sucked back into the system. Don't keep adding to the reservoir (and don't add water in there) as then it can be overfilled and explode (as a friend of mine who kept filling it up found out the hard way).
  5. Don't ever run your radiator on pure water unless you want to replace the radiator every couple of years and cause other problems in the rest of the cooling system. There's quite a larger proportion of radiator corrosion in SL than I've seen in other countries, mainly due to this issue, and due to not even using distilled water and instead "topping it off" with normal tap water that's full of rust and impurities. Most coolant brands like Caltex etc are made according to certain standards, so it shouldn't be a big deal what you put in, but don't mix brands as there is the possibility of silicate forming inside your cooling system, due to compounds in different brands reacting, and also other unpredictable reactions under the heat inside the system. Make sure to fully drain your radiator and then refill it with one brand after flushing with water. Check on the coolant bottle and see if it says premixed, in which case you can just use that stuff. If not, you will have to do the 50-50 with distilled water. And modern Hondas (and I think Toyotas in the last couple of years) are recommended to run only on their Honda or Toyota brand coolant (claim is that they are formulated to run better with their cooling systems- there is some debate about this so you'll have to do your own research). I put the genuine Honda stuff in my Honda as the price difference is very small, and my Nissan runs on whatever A*W puts in it. For any other brands try and go with the green coolant, as using the orange stuff makes it hard to determine whether it's rust or whether it's coolant stains you're seeing in your system. The genuine Honda stuff is Blue, and the Toyota is red or pink. You shouldn't have to replace the coolant more than once a year (sometimes a couple of years or even more) depending on your driving habits. Pay attention to the level that your coolant reservoir bottle is at when the engine has just been turned off (hot), and that should be about the level you're at when the coolant has expanded. When the engine is cold that level may drop as it's sucked back into the cooling system. Don't overfill it as the bottle could explode when the engine is hot.
  6. There are speed sensors fitted on our roads now that detect if you are even 1 kmph over the speed limit. If so, the horn is disabled so you can't horn to tell people to get out of the way so you can go even faster! Kidding I've never heard of a similar problem before. Working on the relays should have fixed it.
  7. SeanD replied to rauf's topic in NISSAN
    Guess that's pretty much what I have, I got mine at the tail end of 2004 but it was referred to as "2005" model I guess. And the petrol mileage is about what I get as well, mostly non-AC driving.
  8. I tried google but all I got was spam. However, most of the real search results were returned from Sri Lanka, so I'm assuming this car originally goes by some other name. You might also be able to contact some guys who own this car and ask if you could borrow their manual.
  9. SeanD replied to rauf's topic in NISSAN
    I have a 2004 1.3 litre manual N16. It was not the best choice, but I had no choice as the 1.6 was out of stock and would not come in until the crazy vehicle taxes were to come in place a few weeks later. In terms of reliability, I haven't had a single day's trouble with it. But if you're talking about performance, forget it. Fuel economy also not good, compared to the 1.6 my friend has of the same year. That's due to the reasons others have mentioned, weight etc. It's a heavy car and I've really no idea why they even built it with a 1.3. Do not, I repeat, do NOT get the automatic version of this I've had the misfortune of driving this once, with the AC on, and the damn thing barely moved. By the time you get up to speed it's already time to brake. With the manual, you can learn after a little while when to put the power down and what gear you need to be in to get the performance you need. Then it's not an issue to overtake or whatever. This is also how your friends manage to negotiate hills with 5 people in it. Once you're past the learning curve you can do this, before that I had trouble even getting out of underground parking lots. There were couple of times everyone else had to get out of the car. I don't know about the resale value, most people nowadays just want a reliable car due to the crazy prices they have to pay. If there isn't much of a difference then get the larger engine, otherwise don't worry too much. I usually drive with the AC off, I find that gets me something like 80km per tank more! Even taking in to account drag etc with the windows open.
  10. Park the car and then see where the drops seem to fall. Put some white paper underneath it (and be sure you clean up afterwards, as if you have any pets at home or in the neighbourhood- licking spilled coolant can be very harmful to them). Then open the bonnet and you can estimate what part of the cooling system may be leaking, It could be something simple as they didn't tighten the drain bolt. It's possible they also overfilled and coolant is leaking out of your reservoir bottle. See if there is already any spilled coolant inside the engine compartment, as it could simply be dripping if they spilled it around the reservoir area, and slowly draining off onto the ground. Coolant doesn't evaporate very fast as far as I know, so that could be the case.
  11. Air conditioned as well
  12. Whatever happened to that Killer Starlet GT anyway?
  13. This is the sort I was referring to, as the ones I've seen were in the States, put in by people who knew what they were doing, and they just, as I said earlier, "fit." And I'm one who hates those stupid noise barrels on cars that don't come with performance systems by default, so that's saying something. I haven't seen this yet in SL, although there may be some. I HAVE seen a couple of Beetles in SL with BAD "beat barrels" come to think of it Rameez: The models my relatives had were the 505 (two different ones), and a 305 (these were all owned by different people). This is all prior to 1995, I have no idea what happened to these cars after they were sold. In my lifetime, I remember all 3 cars spending more time in the garage than out. The 505s in particular, seemed to have pretty much everything that can go wrong with them go wrong with them. One of them was permanently parked on top of a huge pile of gunny bags as it seemed to have oil and coolant leaks that nobody could fix. The 505s had the habit of just stopping in the middle of the road at the most critical moments - wasn't helped that it was driven by an elderly person who couldn't really get down and push that monster of a car by himself. They were all driven with care though. Parts was not the problem - I think parts were freely available, and even original parts at the time were not too pricey I think. The Lankan Peugeot dealers at the time didn't seem to do a good job (I believe it's the same company still but perhaps they have cleaned up their act) and eventually they were taken to a "Peugeot Baas" who seemed to make at least the 305 do a little better. Eventually all of them were sold one by one, perhaps the new owners had better luck. I have to say though, that when they did decide to run, I still remember an extremely smooth and almost joyous ride that I haven't felt since then except in a BMW. The 505's especially felt extremely silky. As none of the cars had a functioning AC, (more problems there that were not worth fixing) I always rode them with the windows down and they had a satisfying grunt. And while at the time the cars felt old due to the rapidly changing nature of cars at the time (more so than today), at the time I guess some of them were not even 10 years old. For cars in that age group I felt the problems were unacceptable. But if you're looking to get one I wouldn't just take my word for it, as maybe these peopled were cursed with 3 troublemakers I know the 504 is supposed to be a very reliable car, and I certainly see more of those running around even these days. I can't remember the last time I saw a 505 or a 305.
  14. I am assuming you would not want to spend a lot of money on repairs or on running costs, so I would not be to go for something that's too old just cos the price is right. As someone else mentioned above, your best bet is to look for a Japanese vehicle or a VW Beetle out of colombo (further the better actually). I saw some Peugeots advertised on sale out of Colombo a little above your budget, but given my experience with 3 old Peugeots of the same era among various friends and family members, I would not touch them with a 10 foot pole (sorry Peugeot fans). Ps - Save a little more and put a performance exhaust on the Beetle I've seen a few and it just FITS.
  15. Why don't you just load it on to a lorry, and take it to a GOOD mechanic, of whom you'll find plenty of recommendations on this site, and get them to do everything you need? Because you may neglect one aspect in favour of another, and then not catch it until it's too late or the damage is done. Do you know the history of this car? What was the reason it was just lying around in the harbour? Was it imported by a car sales or what? And has it been wrecked/have permanent chassis damage? I know a couple of guys who bought cars through customs contacts like this, and ended up regretting it and spending more on fixing it up than the car was worth (of course, this is before the crazy taxes came in). You could end up with a very good deal, or you could end up with a total lemon, the only way to find out is to have someone fully knowledgeable check it out, especially due to the environment it was kept in.
  16. What sort of car is it? Your profile says you have a Toyota? I believe Toyotas like Hondas are very fussy about certain fluids, make sure you only use genuine coolant. If the fluid level in your reservoir is going up and down, that's normal. But if it's empty like you say, then there's a leak somewhere. That link someone gave above is what I used a few years back for a similar problem on a friend's car as well - it's good. If you're not using genuine coolant then I hope all owners of the car have not just being putting pure water, as that could have destroyed some of the internals as well. Best thing is to take it to the agents (or a shop that has such a system, most mechanics do not) and get them to do a pressure test of the entire system, that will reveal any leaks that you can't find through normal methods. Although, since you're losing so much, you've either got a severe internal leak, or there is some SERIOUS evaporation happening somewhere if you're not noticing spilled coolant.
  17. Think you can do it online now. Search the forum for the recent thread.
  18. What happened to Duncan btw? Haven't seen him here in years...and that site seems to be dead too.
  19. SeanD replied to Rebel's topic in General
    I seem to recall a lot of 505s in the PD when I was a kid in late 80s early 90s. Let alone seeing them in the PD, you don't even see them on the road anymore, not that I know of anyway.
  20. What exactly is the meaning of "open papers?"
  21. Have experience with a 33, a good car if you can get it at a good price. Be careful about the owner offering to do all the necessary repairs, since he may try and skimp on stuff behind your back, leaving you with more costly problems later. See that you get ahold of the full diagnostic. Nice to see you back after such a long time.
  22. It's thick for the very reason I told you. Anyway I would imagine that insulating the floor is harder as well. Sounds like you're on your way to what you need, let us know how the engine muffling turns out. And yes, google is your friend
  23. As far as I know, the decisions have already been made and will be revealed after April. The rumours started around the time this committee was put together some months back. I'm not sure what the outcomes are, but I believe they have revamped the complete tax structure. I don't know if car taxes were changed but I do know one of the external researchers for this committee who believed this would be the case. If you know someone on the committee then ask them and see maybe: http://www.lankatimes.com/fullstory.php?id=23863
  24. You would probably need to spend a fair bit of money if you want anything more than a "noticeable" reduction. Although you haven't mentioned in your posts, I would assume from your profile that you have a Civic EK-3. You really need to first identify where the noise is getting into your car, before spending money on treating areas that are really not going to give you much, if any, benefit. For example, simply packing your car with insulation is not going to do much about engine noise if you don't know how the engine noise is being transmitted to the cabin. It could be through thinner panels, hollow pillars, or simply the fact that the body panels are vibrating enough to cause a high level of noise in the cabin. This is not something you can just "fix" by packing it with insulation and foil- it may work in some cars, and do absolutely nothing in others. I'm not qualified in acoustics or auto-body design, but I do have a physics degree (knew that'll come in useful someday!) and know enough about the subject to tell you that a lot of that stuff being sold in the shops is simply snake oil, and the ones that work will not work universally across every car unless you know how exactly your car lets in the noise. I'm willing to bet that one of the key differences in the noise level of cheaper cars vs more expensive Euro-cars is the method used to prevent the body panels transferring vibrations to the interior. If you need that kind of isolation, then get a Eurocar would be my suggestion. Next time you see a Merc of a Bmw, go rap you knuckles against the A pillar and door panels, then come back and do that on any Japanese car. You'll see what I mean. It's like the studios in Sri Lanka that coat their walls with normal yellow Arpi-foam, under some sort of impression that that's going to "soundproof" the place. It does not work like that. Acoustic foam is very different to Arpifoam, and the cuts and thickness of it have to correspond to the wavelengths you're trying to block. If you're serious about doing this, then I suggest you look in to and import some proper material. That Wurth stuff might work, but don't fool around with other unproven crap. Might look into getting a different set of tires too, maybe that's the cause of some of your noise. Earplugs would work too. Or better yet, just turn up the radio a bit louder. Don't worry about not hearing something important outside the car when you do that- if you had got the cabin as quiet as you wanted to, you wouldn't have heard that anyway
  25. What exactly are you trying to achieve here?
