Everything posted by Sumiya
Latest Tyre Prices
Hi MR Supra He he I did not talk about pirelli company , i am talking about the tyre that is what i clearly said it is an European Tyre, Pirelli Mother Company started in Turkey initially( As i know these info becs i have been working for pirelli agent here in sri lanka few years ago) Pirelli Turkey product was the best out of the tyres produced by Pirelli , now i don't know where it is now,now these situation might have changed.Company is in a particular country does not mean the product is from same country.if you can understand !! Thanks Regards sumith
Latest Tyre Prices
Hi Guys Original Pirelli is from Turkey, but there are so many countries having sub factory of Pirelli, any way it is said as an European tyre. Thanks regards sumith
11 Sri Car Modified
Hi Guys is there any one know what is this original car model ,year ,engine and setup etc ? Thanks regards sumith
Is Toyota - Soluna Good?
Hi Upesh SU-14 is a good comfortable car it is a bit heavy car, so i don't think so it may be doing on fuel, specially regarding your budget , you should be very careful, i don't think so you may be able to buy a good SU 14(diesel) one for that amount, you may have petrol version. Thanks Regards sumith
Weird Performance Problem.. I Could Use Your Advice
Hi Saturn It doesn't look any issue in the carb, just see whether you can see the float level of the carb through the glass(if your carb is having it only)if it sits in the middle while your car is in start there will not be any issue on it, and not even vacuum problem if it is vacuum problem you will always have it while your car is in start,if the carb lower needle is blocked you may have similar issues but as long as you try to move your car it tends to stop or knocking,Just check your ignition coil it might not supply correct amount of voltage when it is hot or check your ignition coil condenser .tell me where are you staying thn ill tell you agud guy for carb adjustment. Thanks regards sumith
Has Any One Fixed Mechanical Temp Guage ?
Hi Guys As my experience Mechanical Gauges are very much accurate than electrical, so i always prefer them rather than depending on electrical,i have learned lot of lessons from relying on electrical stuff,i don't say they are not accurate all the time. but cant rely on them for long time, they used to malfunction when they get old. Thanks Regards sumith
Hi maliths Yes , that is the one, i am going to use electrical and mechanical both together with T connector to the Upper radiator hose or into the engine block sensor location need to find a good place to buy the stuff also thanks regards sumith
Neo Engine
Hi Jeff It seems the purpose was that, it is fuel efficient and environment friendly version engines with low emission Thanks Regards sumith
Nissan Wingroad Fuel Consumption
Hi JAFF If it is Manual Transmission , it is not enough doing 7-8 at least it should do 10, as mistaken_ID said you may consider the tyre size and profile ,if you are not using them as factory manual specs it might not do better in fuel,as well as very low rpm and speed driving does not give you any improvement in fuel rather than wasting them , so you should always drive it in middle rpm and speed Thanks Regards sumith
Hi Guys has any one using a mechanical temperature gauge, i just need some information how it is configured, if you got pics that would be great ,which way it has been connected etc thanks regards sumith
G1 Class
Hi Guys Looks like a BIG STORY on it, no time for reading ,pleas read these links , they got details about it http://www.motortraffic.gov.lk/news.php go to Page No 36 on this http://documents.gov.lk/Acts/2009/Motor%20...%2008%20(E).pdf Thanks regards sumith
Toyota L-touring Wagon
hI Edward As my knowledge the difference between the L and G Touring essentially is the trim and suspension package , G may have a better suspension and more luxury features like upholstery etc.most of the parts are exchangeable.if any one can supply more details if known would be greatfull Thanks regards sumith
All About Mark Ii 1999
Hi Malaka That is fairly enough doing 9-10 according to the size of the car and size of the engine and room inside it with comfort,it might still do at least 7-8 in Colombo.you may increase it by considering a engine tuneup, Tyre size using etc Thanks regards Sumith
Hi ha ha Agree with Tikiri, i Think Mark ii is one of the most luxuries and comfortable car made by Toyota, Might be Father loves you more than him self ,Just kidding guys don't take them serious thanks regards sumith
Hi friend I am doubtfull whether you are referring Toyota Mark ii or something else if it is so please refer you will get basic info here http://en.wikipedia.org/wiki/Toyota_Mark_I....29_X100_series Thanks regards Sumith
What Engine And Bhp Rate You Get ?
Hi MR Dilesh Accepted , probably you are correct ,purpose of this is to to get some general idea about in a easy way what power rating and configuration ,this is not needed if everybody has all those factory specs for each and every vehicle that has been produced , that also will be possible if that fellow does not have any other work and can consume all his time on reading factory specs, Merely most of the people here doesn't need how it is made, but if it is there to eat that is all they want he he , that is why we are called renowned Sri Lankan Thanks regards sumith
Hi Guys This was most interested topic in some other forum,i think it will be same here , you guys please post what type of engines you used and what is the Configuration and BHP Rate you have or had ? First of all i ll write mine as i remember Nissan Primera SR20DE 2.0 with- 140 BHP Mitsubishi L400 with 4M40 2.8 L TD I4 -125 BHP Nissan FB 14 with GA16DE-1.6 -102 BHP Datsun Sunny A12GX 1.2 - with 83 BHP Datsun BlueBird L16- 1.6- 96 BHP I don't have all these with me except 3 and 4 Thanks Regards Sumith
Happy Birthday Mazdaspeed!!!
VERY HAPPY BIRTHDAY DUDE Thanks regards Sumith
Cops Got Some Reason To Fine
hi jehan80 I have done interior cleaning also,so wanted to remove it and paste it back but forgot it , any way that is my mistake thanks regards sumith
Yes dude Vehicle was serviced day before , i forgot to paste it again Thanks Regards Sumith
Hi Guys I was coming down from up country,cop fined me for Not Showing Revenue License on the windscreen, i don't know how these guys can see something wrong and fine , worse case is that i want to go up again to get my DL we always see Dirty cops with Bribery faces on the road everywhere , but better to pay a fine rather than giving them money Thanks regards Sumith
Which Has The Best Market Value?
hi JAFF It is 1500 CC, that is mid range in power and fuel consumption, 1300CC good in fuel but less in power 1800-2000 CC are week in fuel but high performance and i have heard 1500 CC engine is the best balanced engine out of the engines produce for cars specially Thanks Regards sumith
Which Jap Car To Select??
Hi Mate Your first option is the best ti think that is Corolla AE110 Thanks Regards Sumith
From Where To Buy Electrical Spares ?
Hi Guys Just tell me from where i can buy stuff needed for a car wiring ,Wires ,Connectors Wire Clips,Tape,Fuse Box Etc Thanks Regards Sumith
What Is The Best Wagon Type Car To Buy .........1.4 Mio
Hi Mate , Go for L Touring , that is a long lasting powerful comfortable car It is professional Thanks Regards Sumith
