Everything posted by H.C
Suzuki Jimny
Well Ive had first hand experience of the terror due to poor handling of terios few years back. I was the front passenger in my friends Terios,when it went with two wheels(Like a night rider type of stunt) after taking a bend just after Belihuloya. Thank god,it came down on right side and still remember the silence inside the vehicle for few minutes! .
Ek3
Ha.. ha..Got delayed to Sunday due to saturday on call duty! . You have a point there. But what I did was , just put the door in closed position like when you put into AC fresh air vent door off mode from dashboard.Ive noticed a another small rubber flap covering a another opening in the rear end of my car closd to the fuel lid.May be it has something to do with cabin air circulation or pressure balancing.
Car Sparepart Best Place Ebay Or Abroad
<blockquote class='ipsBlockquote'data-author="vishkid" data-cid="232654" data-time="1360669530"><p> Just out of curiosity (reviving the closest thread I found). Has anyone imported any big motor spare parts from US/Aus and if so <span class='bbc_underline'>what sort of taxes can we expect to pay</span>? I'm talking about fairly heavy parts like wheel hub assembly or suspension links.<br /> <br /> If the total duty are anything like 50%, I can expect to make a saving of around 25k LKR/part on most of the items on my checklist - even compared to Panchikawatte.<br /> Unfortunately the HSCodes/Tax calculator on customs.gov.lk is down so I do not hv a reference.<br /> <br /> TIA</p></blockquote> Machan PM our conversion Guru , komi!. He has brought in some heavy stuff including Type R GB, seats and hundreds of other stuff!.
Ek3
Yep, its the AC fresh air door not closing properly. In Eg/Eks its a sheet of foam pasted to thin metal door which will build up rust over time. As Rumesh mentioned you need to remove glove box and blower motor to access it. If you are lucky bit of WD 40 will do the job for you . In my case its not closing properly as lever mechanism was busted. So permenently closed it with sheet of foam and power connector to AC fresh air vent door motor was disconnected.
Car Over Heated N Stalled
<blockquote class='ipsBlockquote'data-author="SAM K" data-cid="232067" data-time="1359979027"><p> Hi Don,Thanx a lot for the fast reply ..well noted and one more thing, can the t belt cover melt due to excessive heat and it get deformed and touch the t belt? and do i need to dismantle all and check the t belt propelry and also a compression check for any cracks in cylinder liners.. Will these be necessary .please advice..</p></blockquote> If you are reffering to lower part of the T belt cover , its due to hot water escaping through water pump seals. I had to replace them with the pump as I mentioned before . Suprisingly T belt cover was available brand new at tech motors!
As don said check the water pump because "kara kara " noise is most probably related to bad water pump. I faced to similar situation 3 y back and paid the ultimate price due to ignorance. ( I too have Eg single carb). In EGs water pump situated near the area you are discribing and see any water leaks from the right side of the engine ,below the pulleys. Hope you havent blown your head gasket, but run the car with close eye on temp gauge specially with AC on.
Buying a new smartphone
<blockquote class='ipsBlockquote'data-author="Magnum" data-cid="231995" data-time="1359900851"><p> <br /> dude its Android, you can always tweak things and get stuff sorted out(it'll need rooting though)</p></blockquote> Hmm.. searched a bit in xda forum and there are few custom ROMs with dock support. But each one of them have some other issues as well and I will lose warranty too. So waiting for something official!
<blockquote class='ipsBlockquote'data-author="Magnum" data-cid="231956" data-time="1359813528"><p> <br /> Just google as "updating Samsung galaxy I9300 through odin" and you will get step by step instructions.</p></blockquote> Thanks mate!. Got the 4.1.2 via kies today. Ive connected it in wrong format before!. Still no car dock support!
<blockquote class='ipsBlockquote'data-author="Magnum" data-cid="231944" data-time="1359803593"><p> <br /> Why don't you update through odin? its faster</p></blockquote> Thanks for the tip machan! Will try that!. Recently changed to Android from 10 years of Nokia , so still learning!.
<blockquote class='ipsBlockquote'data-author="Magnum" data-cid="231940" data-time="1359795073"><p> <br /> Yep that's the case, different countries get the update at different time.<br /> <br /> Im using s3 , international version. Updated to 4.1.1 and lost car dock support. Got 4.1.2 notice via kies late December, but its no longer there!( I was bit reluctant to update then) <br /> <br /> what phone are you both using?</p></blockquote>
<blockquote class='ipsBlockquote'data-author="vishkid" data-cid="231617" data-time="1359473291"><p> Machan did you get the 4.1.2 OTA update? The "driving mode" makes a comeback there, should be similar to car dock (I hv not used car dock in android).</p></blockquote> How did you update to 4.1.2?. Kies not show any update!
Happy Birthday Masterdon
Happy birthday MD!
Project R
<blockquote class='ipsBlockquote'data-author="Octanehead" data-cid="231708" data-time="1359585126"><p> <br /> Especially those silly mindless school kids who carry their backpacks only on one freaking shoulder for so called "Isstyle" and end up daubing their grubby little bags on our paintwork and knocking the side mirrors the other way around! </p></blockquote> Yes mate!. I learnt the lession hard way ,twice. So got hold of relay via ebay and found a switch locally , one day of DIY and problem solved.
Project R
<blockquote class='ipsBlockquote'data-author="Komisiripala" data-cid="231679" data-time="1359554890"><p> <br /> <br /> got flat wheel caps from JJ. honda logo is printed at a place called "leaf" in borella. opposite ananda. i have a contact there let me know if you need any prints. they have most of the vector files as well</p></blockquote> Thanks. Need to visit jj first . Machan make sure to fix the retract function in mirrors . Our people are so good at breaking side mirrors when walking pass them.
Project R
<blockquote class='ipsBlockquote'data-author="Komisiripala" data-cid="230987" data-time="1358938704"><p> since progress is slow, here's a shot of my new alloy caps. <br /> <br /> <span rel='lightbox'><img src='http://img20.imageshack.us/img20/9449/photo1bs.jpg' alt='Posted Image' class='bbc_img' /></span></p></blockquote> Machan did you get these from jj or ebay?
<blockquote class='ipsBlockquote'data-author="vishkid" data-cid="231617" data-time="1359473291"><p> Machan did you get the 4.1.2 OTA update? The "driving mode" makes a comeback there, should be similar to car dock (I hv not used car dock in android).</p></blockquote> well driving mode was there when using car home ultra. Ive got samsung infuse4g official car dock which was a petfect match for s3 and worked with ICS. ( charging and audio out option). With JB they have removed it in all the updates except in one us network. It is a huge blow to the after market car docks like i Bolt.
Car Warming Up
<blockquote class='ipsBlockquote'data-author="kmcsb" data-cid="231628" data-time="1359481601"><p> <blockquote class='ipsBlockquote'data-author="H.C" data-cid="231613" data-time="1359470747"><p><br /> most probably someone have removed the thermostat to prevent a heating issue. Take it to a proper mechanic and see weather thermostat is intact. If you put a thermostat, just check the condition of the radiator as well and as Rumesh said, drive her with frequent eye on temp gauge. Themostat comes first in my list.</p></blockquote><br /> Machan do you where is FITV (fast idle thermo valve) located in our engine..i looked aroud but unable to find it.. I alredy cleand idle control valve..do you know where is it?</p></blockquote>Actually my motor is D15b3, so it doesnt hav that. (Non JDM)Do your one have an ECU?
Machan schifer, are you using a car dock with your s2. . If so, just check wheather its working. Because I upgraded to JB in my S3 and later realized that they killed the dock function with the JB!
Car Warming Up
Congratulations Davy!!
All the best machan! .
Car Warming Up
<blockquote class='ipsBlockquote'data-author="cmxjn" data-cid="231302" data-time="1359186153"><p> Could be the thermostat stuck open</p></blockquote> May be some makabas has removed the thermostat before you got the car! Its around 4000rs.
Project R
<blockquote class='ipsBlockquote'data-author="Komisiripala" data-cid="230659" data-time="1358679252"><p> the stock headlights smudged more than a van Gogh painting. so i asked our resident DIY-guru Davy for some help in restoring them. he didn't just help, rather took over the whole undertaking. and the end result... well...<br /> <br /> <span rel='lightbox'><img src='http://img545.imageshack.us/img545/6500/74034885.jpg' alt='Posted Image' class='bbc_img' /></span><br /> <br /> <span rel='lightbox'><img src='http://img838.imageshack.us/img838/9859/51163783.jpg' alt='Posted Image' class='bbc_img' /></span><br /> <br /> <br /> davy my man tell me where i can make a statue in your honour! <br /> <br /> blown away. mind you this is after bara had a go at the lights...</p></blockquote> super work Davy! Realy hard to see a projector lence before the Davy touch. Almost like two set of lights.
Range Rover Evoque
<blockquote class='ipsBlockquote'data-author="Komisiripala" data-cid="230497" data-time="1358422836"><p> So in essence it makes since why my colleagues buy appreciating automotive assets. (Spelled T-O-Y-O-T-A)</p></blockquote> when I was doin my interns, I almost pleaded my Senior colleague to buy at least a damn yaris without getting a Alto!. I met him few months back and guess what, he is having a alto and his answere was couldnt afford anything beyond that. So basically thats the story of the majority. I too getting one 3years down the line and wondering what I can afford. I know what komi is after !( Supra is in right track, neda machan)
- Project R
Civic Eg4 Jdm Spec'd
Nice to meet another Honda fan here in AL. post few more pics machan. komis project has implanted few cancer cells in my brain too, regarding a B16A swap!. I think best option is to buy a car from here and do the upgrades .
