Uditha88
Everything posted by Uditha88
  1. Uditha88 replied to shaan's topic in NISSAN
    Auto-power switch= Most probably it should be the switch to power on/off the transmission leaver, so that it might not be able to change accidently. Overdrive Button= It is used to off/on the the highest gear of the transmission. Eg. If 4 gear automatic, if you off the OD, transmission will not get into the 4th gear. Can be used in city driving condition where 4th gear seems not possible or when going downhill. Reasons: Will reduce the stress on transmission as no very large 3 to 4, 4 to 3 changes.
  2. What About; AUTOLANKA -> HYBRID Automotive OR OTHER -> HYBRID
  3. Others: Toyota Corsa/ Soluna, Nissan Presea, Mazda Familia Milage Would be(Roughly): Between 140000 - 200000 (But it varies)
  4. I filled Full tank when even 1 pump was closed. But I was lucky. Most probably solution for you will be replacing fuel pump. Take her to a mechanic. What to do...
  5. Uditha88 replied to prana's topic in NISSAN
    7-8 Km/L in City
  6. The place which generates noise must be properly identified. You might get help from a 2nd person or take the car to a good mechanic. After a test drive, experienced mechanic can understand the issue by noise. Additional: There are some gadgets even for sound recognition for vehicle diagnosis. Don't know whether those are used here. It's all Mechanic's experience.
  7. Uditha88 replied to jami's topic in Mechanical problems
    Also get checked for Break Bindings...
  8. Uditha88 replied to amdan's topic in General Automotive
    Either Dumi*** (body***.lk)or Asnka Ganepola (Macvud)
  9. Ya. Parts rare & expensive. But durable, powerful make.
  10. There are 4 transmission types 1. Manual 2. Automatic 3. Seme- Automatic 4. Tiptronic * Tiptronic is the generic name found by German sports car maker Porsche. * 'Tiptronic' to refer generically to any type of torque converter automatic transmission that incorporates a manual upshift/downshift feature * Manumatic is 1 of implementation of Tiptronic.
  11. Go for V-Tech then. But still those are very OLD...
  12. AE 100 (YOM: 1994) Manual 11 Km/L in City
  13. Wiper blades quality cannot be guarantee by just looking. I also suggest you first change the blades like Big_D mentioned..
  14. +1 (Srry. my quota is end. cant give u reputation )
  15. Bcoz better to give "Reputation" to other's than giving it to "his own" as the above one
  16. * 1st use VIC Fuel Filter. Run & check KML * If not satisfied, do a Injectors, Throttle body cleaning
  17. The Registrar of Motor Vehicles (RMV) is likely to increase charges for registrations with special number-plates from the current Rs.7,500 to Rs.70,000-75,000 shortly, informed sources said. The charges for a normal registration will also be increased by Rs.300-400 shortly from the current Rs.14,000. The charges have been increased by 1000 percent and according to the RMV most of the individuals who apply for special numbers are V*P’s, businessmen, architects, doctors, engineers and reputed professionals representing different fields. The move comes a month after the excise duty on hybrid vehicles and petrol vehicles were increased significantly. Hybrids between 2000 to 3000 CC were increased by 75% and 100% for hybrids above 3,000 CC. Earlier, there was no excise duty on hybrid vehicles but only 15% tax and a 12% VAT. In the past two months about 3,000 hybrids have been imported into the country.
  18. Please do a search. This topic has been discussed into depth. Well. Some people just tell those are not working. Some say so after they have tried it. But for some, it works really amazingly. (both for better MPG & passing Emission Test etc) So it seems it neither good or bad. So better give try & experience ourself...
  19. VIC is the best "Fuel Filter" in my personal experience. But the 1 Nissan Japan used is "paraut fuel filters" (I dnt think we can find it here) AND The Brand of the Air Filter doesn't do anything significant...
  20. So then I recommend you go for a "Presea". If fuel econ. ur concern, don't worry. It'll work same as "Pulsar" If ground clearance ur concern, don't worry. It'll wont hit on floor. Low clearance has given it more beuti + good grip. It's not extreme low. It's ideal. There are lots of vehicle lower than this level some with body kits too.. Buy it. U'll enjoy....
  21. You Missed Nissan Presea here. For your budget you can go for YOM 2000 good condition Refina too. Else 1996-8 CTII Excellent Car in Handling, Comfort, Stylish, everything.... Best looking out of your list....
  22. Query with "Elcardo". If u lucky....
  23. For the Month, If the car is Japanese Domestic, There is a sticker on windscreen with 1-12 numbered on a circle. The exact month that particular care made, is highlighted there. Else see the driver side door sticker for info to. I cant exactly say that the month is their. But it has info. like required tire pressure et.
