Sylvi
Everything posted by Sylvi
  1. Sir, Your need is for CFL bulbs or any other propose please contact me on 2573690/0712222420. I will advice you. Wijesinghe
  2. Sir, Nippon Show room at Buddaloka Mawatha at Bambalapitiya end near the bus stop has inverters they drain your battery very fast if you are using inverters you have to have high Ampere Battery They have 500 Watts AC 230 Volts you can call them on 2589992 and find out the cost. You will be able to get at 1st cross street 150 watts what you are looking I have 1 unit I bought few years ago for 3500 Rupees. I hope your battery is 40 amps so 150 watts inverter will draw more than 12 amps. Wijesinghe.
  3. Sylvi replied to Senaratne's topic in General
    Sir, You can contact me on 2573690/0712222420. My address is 418, Galle Road Kollupitiya Colombo 00300. Wijesinghe.
  4. Sylvi replied to Senaratne's topic in General
    Sir, Your Van If you can show to me I will give Free advice to you how to make same comfortable to Passengers as I have done this for last thirty years from the time free imports came to Srilanka. You need only to change 4 ply Tyre and a small modification for your rear Suspension then bumping will be less. In 1970 late RH 11 Toyota was the most popular van which I did lot of modifications to make that van comfortable for Passenger transport. Wijesinghe.
  5. Sylvi replied to Senaratne's topic in General
    Sir, Do you use this Van for loading or only as a passenger for loading have 6 ply Tyre is OK. As a passenger Van 6 ply on 13" rims will be uncomfortable Do you have 6ply Tyre on 13" rim 14" rims are bigger so there will be a little RPM problem for a Diesel van it will not effect much. 6Ply Tyre had same problem in a friend of mine's KR41 I advised him to change to 4 ply as he was using his van as a Passenger Van. He was very happy with 4 ply Tyre change. Mine also changed to 4 ply Tyre 13" Rim. In rear 2 helper springs are removed and used spacers for the gap of removed springs. Wijesinghe.
  6. Sir, I agree with you for your comment about glass wool is poisonous. Please note almost all A/C ducting s are covered with Glass wool and all ends are covered special tape so that glass wool particles will not escape from the joints. Glass wool also act as a very good sound transmission control and temperature control. This job has to be done by a experienced person. In a Automobile doors have two metal panels that alone controls outside sound. Inside the cabin we have the door covered panel that may be leather or some other materiel with form padded Board. If any one wants to add more (STC) only thing is to paste some material to inside of the outer metal side from inside of the door. Sound transmission control is mostly done with building a hollow block and paste one side with whatever the material you select for sound control. Wijesinghe.
  7. Sir, This fiber glass sheet is available at M/s, AJANEE TRADING COMPANY LIMITED No, 71 UNION PLACE Colombo 00200 TELEPHONE Numbers are 2325068 2304570 2433543. You have to request as for Air conditioning duct masking. There are so many Other importers who import this to Srianka as this time I cannot contact them will do by tomorrow morning and give you the info. I contacted them after 5pm they Informed me that what they have is 1 Inch thick by 4 Feet wide and 15 Yards they quoted me one role is less than Rupees 5000.00. Very recently I did a 3300 square feet Karaoke dancing flow (STC) with 2 Inch foam rubber sheet. this cannot be applied for Automobiles. I have (STC) experience in my field in USA done very little in Srilanka. There are several cheap things that you can try I do not know their performance under coat also so many applications. Can you get me on Email <[email protected]>. Wijesinghe.
  8. Sir, Re sound Proofing I want to comment as for my Knowledge this is called Sound Transmission Control (STC). This subject is a very vast subject and there are lot of forums on the web about same. For Automobiles and Buildings. There are meters to test before and after the amount of (STC). I suggest with my Experience to control out side sounds entering inside cabin of a motor Vehicle best is to use Fiber glass Wool sheet which has a thin layer of aluminum foil. Which is freely available in Srilanka used in Air conditioning industry. Paste inside door paneled frames if necessary hood lining also removed remove all seats and original carpets. Paste on to the flow board above said Fiber glass sheet fix all removed units back. Under body there are lot of chemicals petroleum based to apply few coatings something like tar which will dry in few hours. This application must be done when the vehicle is new or after a steam wash as it will stop corrosion also. I have used same on many Vehicles and happy with the performance. Wijesinghe.
  9. Sir, Have you sorted out your problem of Sound Transmission control Correct technical term for (SOUND PROOFING) inside of your Vehicle as your first post to this forum is on end of January and few replies for same was send to this forum. Wijesinghe.
  10. Sylvi replied to MADZ's topic in The Lounge
    Members of this list, I know my English it is the Queens language. I understand what you mean by ELBOW GREASE Please do not try to teach me English. I have read good English long ago can stand on any forum and answer any question. One member said glass houses should not throw rocks at others" He may be a one covered member who had used to same? Dogs will bark at moon but moon will never come down. Regards, Wijesinghe.
  11. Sylvi replied to MADZ's topic in The Lounge
    Sir, Please do not write with your limited English Knowledge and insult indirectly members of this Forum like (good joke jack ass!) may be you had not washed yours. Elbow Grease please do not think I do not understand English what you say is someone did with a bottle of some thing I believe him he has done himself as he visited my work shop and got the idea of polishing which is very good and he must be great full for writing his experience for I quoted Rupees 15000.00 which he did with (Elbow Grease). All list members must be thank full to him(Eureka) for exposing this method which is a world record and must go to world record books. Wijesinghe. .
  12. Sylvi replied to MADZ's topic in The Lounge
    Sir, This Forum is meant for Automobiles not to write about Telecommunication system in Srilanka still as this topic had come up. I will write few words about telecommunications of srilanka. I hope members will not find anything wrong about same. SLT once had a Monopoly in Telecommunication system in Srilanka in late 1960's Fujikura of Japan was entrusted to do the microwave system in Srilanka fixing repeater stations in Hatton, Nuwaraeliya, Deniyaya, and Mathale. I did maintenance of their cable testing equipment. Due to this i traveled all above mentioned towns with Mr Otha who had a very good English Knowledge first he was a Customer of mine later we were good friends he is no more in this world I first visited japan with him after completion of the project in 1970. I was very close to Mr, Otha Japanese who was the project director in that project due to close association with him I have a good Knowledge of the Telecommunications system in Srilanka. I am one person who has best Intercommunicating Telecommunication system in my office having ISDN,ADSL, I think person the who said about Dial up that was in 1990s SLT first provided with that technology. Later then the SLT management (JAPS) provided late 1990 with outdated technology ISDN which give end user digital network with two telephone numbers which still I have. In early part of 2000 ADSL was provided at a high cost with very poor speed. We had a Srilanka ADSL forum who complained to TRC at Colombo for SLT cheating Srilankans by advertising high speeds and providing with low speeds of ADSL. TRC had a hearing on their Adutorium inviting Forum members to represent for our ADSL FORUM complain. One Mr, Siriwardana who was highly educated on ADSL forum spokesmen argued the matter with SLT Engineers on that meeting final result was. TRC Administration ordered to do a monitoring of ADSL speed test in 5 different situations with SLT and TRC Engineers to get a Speed matter sorted out. I was asked to monitor for 3 hours at TRC and later another member of the Forum one Mr, Wasanthe Guruge who is a Electronic Engineer took over from me in the afternoon at TRC for next three hours. Later competition came to Telecommunication Industry and lot of new technology's came to Srilanka like Mobitel with dongle give very high download speed I too use same on my lap top. Cost too had come down due to competition. Above is totally out of the topic in this Automobile forum. I only wrote above for members information. Wijesinghe.
  13. Sylvi replied to MADZ's topic in The Lounge
    Sir, I am not wasting my time I have enough time to write Wijesinghe.
  14. Sylvi replied to MADZ's topic in The Lounge
    Sir, ALTHOUGH you had pointed out. I never spammed Please withdraw that. I don't blow my Trumpet. You are wrong may be as what you think opinion differs. What you have written shows your Limited Knowledge. I am not compelled to divulge to you or others in ths forum to what I write to exchange my experience in motoring Industry. I only send once a reply to a message it may be something wrong WITH my Computer or in the Forum receiving end that message had repeated number of times. In this Electronic era lot of mistakes can happen. If it is in my side i Request a Apology from list members. IT IS OBVIOUS TO PIN POINT A MEMBER FOR A MISTAKE NOT PERSONALLY DONE WITH HIS KNOWLEDGE BY A MEMBER. ADVERSE COMMENT FROM ONE OF THE FORUM MEMBER IN THIS ELECTRONIC ERA WITHOUT KNOWING CORRECT FACTS. FOR REPEATED MASSAGES. EWEN in YAHOO FORUMS REPEATED MESSAGES HAPPENS I FIND TO READ THAT HE IS ANNOYED. HE HIMSELF CANNOT MIND HIS LANGUAGE. CALLING UNCLE MYSELF.FURTHER MORE ALL MEMBERS FOR uour INFORMATION. HE IS NO RELATIVE OF MINE. WITH THIRD GRADE ENGLISH EDUCATION IF NOT HE WILL NEVER WRITE THAT. HE MAY HAVE HAD NOT READ GOOD ENGLISH OR GONE TO A GOOD SCHOOL FOR HIS ENGLISH EDUCATION Wijesinghe
  15. Sylvi replied to MADZ's topic in The Lounge
    All membersr note, At last one member had given the correct answer for all list members as a lesson . Do not forget we are Srilankans Have a History for more than 2500 years. and we are proud of that. English is a International link language for business matters as I think. We Srilankans embraced english only after British established their Coliny in Ceylon after 1815. Wijesinghe.
  16. Sylvi replied to MADZ's topic in The Lounge
    Please note all members in the list. Lanka Internet was originated in Walukarama road Number 156 next to Walukarama Temple in Colombo 00300 the land which I sold to one Mr, Dudly Fernando who was at Colombo Commercial Company Colombo 00200 as a Senior Civil Engineer as it was exes land for me in Colombo I did not want to have that Tenement land as it was giving problems to me. To This forum what I have written about Lanka Internet and my inherited owner ship of the land which which they occupied is not relevant to this Forum I want to explain about Internet in Srilanka and the History as for my Knowledge. I may be wrong informing about SLT as the Pioneer Internet Provider in Srilanka as for my self I first obtained my Internet and Email through SLT. If i am wrong I will request a apology from all list members of this forum for my wrong information. One member had requested Where I was called Uncle i do not think he had read my message and understood correctly. Members note no Police officer or any public officer cannot call Uncle Mother Farther brother Sister when they are on duty to any person who come for their assistance. They have to be polite in Addressing the general public as they ere paid to to do a part of work for the Srilankan Civilians. With tax payers funds. The Member who wanted information for my post to this Forum he will never request a answer for his post to this Forum because he was ignorant of courtesy of addressing general public. Wijesinghe
  17. Sylvi replied to MADZ's topic in The Lounge
    Sir Thanks for your Comments. I do not want to abuse any one on the Forum I only want to share my Knowledge may be I know only .00001% of Automobile Industry in the World But the fact is I want to share last 50 years my Experience in Automobile industry in Srilanka. I want to share with others with good intentions as most members were not born at that time. It is true this forum is not meant for history of Automobile industry History of Srilanka We had Monsoon reliability trials going around Srilanka on a route given to all participants before the start of the trial. WHAT HAPPENED TO MONSOON RELIABILITY TRIALS? AS THIS WAS A ANNUAL EVENT IN GOOD OLD DAYS AND ALL ESTATE SUPERINTENDENTS WAS ENTRUSTED TO JUDGE AND ENDORSE IN THE LOG BOOK THE PARTICIPANTS CARRY WITH THEM E THIS EVENT STARTED FROM COLOMBO ON A FRIDAY OR SATURDAY EVENING AND END UP NEXT DAY MORNING IN COLOMBO. Wijesinghe
  18. Sylvi replied to MADZ's topic in The Lounge
  19. Sylvi replied to MADZ's topic in The Lounge
    Note facts are stubborn 1970s was the golden era in motoring in Srilanka thanks to our old generation of Auto Mechanics. Humor for new rich motorists.As plug and play is available. Wijesinghe.
  20. Sylvi replied to MADZ's topic in The Lounge
  21. Sylvi replied to MADZ's topic in The Lounge
  22. Sylvi replied to wug's topic in NISSAN
    List members, Please understand some are good in English many motorists are younger generation did not have English education like others in this forum so members must tolerate them and tell them to write if they can in English instead of using offensive words. We all were toddlers one day in the past. Wijesinghe.
