Everything posted by Sylvi
Rex Ton Front Belt
Members, Can any member give details of changing front belt what will be to cost of same. As this belt is giving noise like slipping when we pour water it stops but in few seconds it comes again. Want a detail replacement method what are the thing have to remove. I have not done this before. If any web page is available like to have that Sylvi Wijesinghe.
Will Hybrids Fail Or Succeed In Sri Lanka?
Last years article. http://sundaytimes.lk/110313/BusinessTimes/bt03.html Sylvi Wijesinghe
Double Clutch Gear Box
'T-Bag', Double clutch denotes that you press the clutch and nutral the engine then release the clutch then press again to engage the gear as far as I know this was practiced by good old day drivers.; Sylvi Wijesinghe
Where To Buy Hybrid Oil (0W-20)?
The numbers denotes the viscosity of oil.At different temperatures of the Engine Sylvi Wijesinghe
'YRD', Friend of mine using Honda and he used only once 20x40 Havoline. It is a normal car engine so you can use any engine oil. Sylvi Wijesinghe.
Personal Car Importer Association?
'ShanTheBest', I don't think any one formed a association yet.As you do only once no one will be interested to join. There two Associations one is a very recently formed one by' "Wasana" Mr. sampath and old one is headed by Mr. y@ga p#re#a To my knowledge. Sylvi Wijesinghe.
Paint
'Kmcsb', It is highly over priced. TOA normal one can will be not more than 750/=. Heat resistant can will about 1000/= Rupees. there are other Thai made Spray cans for 600/= Rupees. I checked up from a paint shop Colombo 02. Sylvi Wijesinghe.
Oil In Spark Plugs
'Kmcsb', Some times the oil on the plug may be which had spilled when they changed the packing of the cover. Dint they cleaned the head area after changing the cover packing? normally the head area is cleaned with diesel and wipe off well put a small piece of cloth inside the plugs also clean them up. Your car has plug hole was it full of oil even it was shown on the spark plug lead wire cover lead. Was the plug tightly fitted to the engine head. Sylvi Wijesinghe
Nissan Alternator
'harshansenadhir', Normally the earth of the diode plane earthed to the Alternator housing. There should be a heavy wire to the Alternator output wire, It carries power from the alternator to power the accessories and to maintain the battery. The smaller wires usually in a plug are either the alternator's voltage sense, Stator, regulator/indicator light. Very rarely good Alternator will earth., on their + wires. Sylvi Wijesinghe.
Best Engine Oil
'madoc', You can safely use Toyota oil on your Toyota car, Sylvi Wijesinghe.
Good Mechnical Workshop
'sam01', You have not given any details about your vehicle only said 1200 4x4 please give the vehicle model year of Manufacture. Sylvi Wijesinghe
Buyleasing
'pug306xsi', I sold a vehicle with 1year 4 months before the lease was over, paid the full payment two years ago. they gave me the papers without any trouble. But they are very slow takes about 30 days to give a lease. Sylvi Wijesinghe.
members, Actually sakvith did the total damage to all people who was living on interest. One family had 2M invested with Danduvam mudalali in down south 5 of them in that family lived like Maharajas in Ambalanthota. They still have paddy lands and existing. Golder key if top man I am not mistaken was miss lead by the workers. Till sakvithi got out of the country every thing was going smoothly. Sylvi Wijesinghe
Under Compression Engines In Kia/ Hyundai Dieasel Models
Members, my opinion they had not maintained properly with regular service. If any one has service records oil filter changed at what kilometers then it will be helpful to other members in future. Sylvi Wijesinghe.
Paint
'kmcsb', To my knowledge one can is enough to do two coatings. if you use same sparingly. Without spraying on the either sides on the place you select to keep the cover. The new can I bought last was Rs.550.00. Check up there will be cost increase. Sylvi Wijesinghe.
Nissan Alternator
'dpk', Charging light will go off if 1 volt above 12volts are produced from the alternator but that is not enough to charge your battery. It is better you change Alternator to a another used good serviceable one because Diodes & regulator will cost you more than the used alternator. Alternator regulators act in different ways. How long ago you had on high RPM warning light go off. Sylvi Wijesinghe.
Temperature Gauge
'ferrarif50', You first of all get the internal wiring checked up or you can remove the meter try same out side. Because the temperatur gauge it not connect to your fuel tank. Sylvi Wijesinghe
Paint
Kmcsb, It is better you remove the cover form the engine clean same thoroughly, then use Toa spray dry for three hours and fix same. Sylvi Wijesinghe.
Nissan Alternator
DPK, First of all dismantle the alenator and check up what is wrong on same. Some times may be a small repair like brushes. How many killometers your car has done. Rs. 5000.00 is the range of used Alternators. Sylvi Wijesinghe.
How To Clean Alloy Wheels
I am behind cannon show room on the same building on Galle road Kollupitiya better you call me before you come land line 2573690/ mobile 0712222420.
'ashan82', you have to use the wire brush method with a cleaner your out side is OK only inside there are spots. If you can show the wheels when ever you come to Colombo I can advice you. Sylvi Wijesinghe.
'ashan82' , Can you explain the condition of your alloy wheels. They were never cleaned before? Do you get patches or like corroded spots only Most A/W cleaners use very thin wire brushes attached to a hand electric drill. Some times if they are not that bad dirty you can try with soap and water have to take out the wheel and use normal floor cleaning brush clean same. Sylvi Wijesinghe.
Music To Drive By
Members, another top hit by harry belafonte during my small days,
Place To Buy Electrical Wire
Anjo, Did you try on old road behind the Fish market. there are two shops sell wires. There few shops selling Auto cables in Maliban street,1st cross street Pettah. Almost every shop will have Auto cables in Panchikawathe. Just try going to Negambo or Kochikade There are few big auto spare parts shops. I don't think you need very thick wire as the alarm handles only very low amperage. Sylvi Wijesinghe.
Exhaust Leak
Members, Log into this web page you will find lot of information. http://www.paraglidingteam.nl/PPGTechnics/sound%20and%20noise/Mufflers/1155795969.pdf Sylvi Wijesinghe.
