May 12, 201214 yr Hi guys.. Does anyone know where to buy the proper oil for hybrid vehicles.. I mean the manufacturer specified 0W-20 & not the 0W-30 that Stafford & Toyota try to sell to u claiming it's recommended for the hybrids.. Thanks, Yusuf
May 12, 201214 yr I don't think there's a special oil for Hybrids. Use the same brands that you would use for a conventional one. There was a thread talking about stafford and what they sell. search and you'll find
May 12, 201214 yr I don't think there's a special oil for Hybrids. Use the same brands that you would use for a conventional one. There was a thread talking about stafford and what they sell. search and you'll find Only A/C Compressor gas is deferent from others.. It use non electric pass liquid. Other than the engine is normal petrol one.
May 12, 201214 yr Author Thanks guys. What I meant was i'm looking for that specific grade (0W-20) which is stated in the user's manual.. Stafford sells Motul 0W-30 for Rs. 2600/= per 1 litre can.. I want to use what is recommended & not what they are trying to palm off on me..
May 12, 201214 yr Thanks guys. What I meant was i'm looking for that specific grade (0W-20) which is stated in the user's manual.. Stafford sells Motul 0W-30 for Rs. 2600/= per 1 litre can.. I want to use what is recommended & not what they are trying to palm off on me.. Yes.. Always go with your instincts..
May 12, 201214 yr Author I need help to find it.. No one seems to be selling it over here.. So i'm trying to find a shop or retailer..
May 12, 201214 yr I need help to find it.. No one seems to be selling it over here.. So i'm trying to find a shop or retailer.. If you really want (0w20) use Toyota 0W20 Synthetic on toyota motor oil. Can purchase from Toyota lanka, i think.
May 12, 201214 yr what's your vehicle?. I use mobil 10W40 for my prius. It was recommended by Toyota lanka. You can get it from Laughs. Also Toyota oil of the same grade is fine.
May 12, 201214 yr 'YRD', Friend of mine using Honda and he used only once 20x40 Havoline. It is a normal car engine so you can use any engine oil. Sylvi Wijesinghe.
May 12, 201214 yr 2010 Honda Insight.. Grade recommended is 0W-20.. AS I said the very lubricant you want is available in Toyota motor oil Division.. Give it a try @ Toyota Lanka.
May 12, 201214 yr Author Thanks everyone for all ur help.. Will try T-Bag's advice n try at Toyota Lanka...
May 12, 201214 yr Author Toyota Lanka only has 5W-30 semi-synthetic oil... Any other suggestions of where I maybe able to find 0W-20 guys?
May 12, 201214 yr Toyota Lanka only has 5W-30 semi-synthetic oil... Any other suggestions of where I maybe able to find 0W-20 guys? In here we have in walmart on Valvoline and mobil. So I guess SL has agent for those brands, try with them.
May 12, 201214 yr Toyota Lanka only has 5W-30 semi-synthetic oil... Any other suggestions of where I maybe able to find 0W-20 guys? Generally the place to go looking is at Motorcade. Dunno if they have the grade you want, but worth a shot.
May 12, 201214 yr Author Tried Unit#d Mot#rs (Valvoline), Motorcade, Laughs, Toyota Lanka, A*W (Castrol), McLarens (Mobil).. No one has it.. Seems like it's not available in sl?
May 12, 201214 yr Thanks guys. What I meant was i'm looking for that specific grade (0W-20) which is stated in the user's manual.. Stafford sells Motul 0W-30 for Rs. 2600/= per 1 litre can.. I want to use what is recommended & not what they are trying to palm off on me.. I would say going for the 0W-30 would be better. We're a tropical country so having a slightly thicker engine oil will be better on the engine I think. Might be the reason Stafford sell it as opposed to the 0W-20.
May 12, 201214 yr Author I would say going for the 0W-30 would be better. We're a tropical country so having a slightly thicker engine oil will be better on the engine I think. Might be the reason Stafford sell it as opposed to the 0W-20. I initially thought so too.. So when I went to Singapore (similar weather to ours) I paid a visit to the Honda service center n they only use 0w-20. I asked them why n they said that the fuel efficiency will take a hit with anything else n also the lubrication passages n channel in the insight are really small n that the only other option that should be considered is 5W-20 (which is also not available in Sri Lanka)... To confirm what Kah Motors said (Honda Singapore) I fired a quick call to Honda Malaysia.. They too said the same thing.. So as u can see i'm stuck in a bit of a dilemma...
May 12, 201214 yr I initially thought so too.. So when I went to Singapore (similar weather to ours) I paid a visit to the Honda service center n they only use 0w-20. I asked them why n they said that the fuel efficiency will take a hit with anything else n also the lubrication passages n channel in the insight are really small n that the only other option that should be considered is 5W-20 (which is also not available in Sri Lanka)... To confirm what Kah Motors said (Honda Singapore) I fired a quick call to Honda Malaysia.. They too said the same thing.. So as u can see i'm stuck in a bit of a dilemma... It not like you are not going to use the car till you find the right type right? Suggest you go with the next best type that they tell you.
May 12, 201214 yr Spending a lot of time infront of the TV, arenโt weโฆ Captivity of the negativity... For the topic, I think you must contact the Honda agent in SL. (I don't know who some member will tell and nude me over this too..) Follow what they say, and surely you're not the only one has that particular model in SL. So it might help you and don't forget to post the agents voice.
May 12, 201214 yr no point calling motorcade. I asked them on thursday. said the lowest they got is 0w-40. someone here said we can find castrol 0w-20 in sl. calling A*W on monday.
May 14, 201214 yr 0w-40 should be better than 0-20w The numbers denotes the viscosity of oil.At different temperatures of the Engine Sylvi Wijesinghe Edited May 14, 201214 yr by Sylvi
May 14, 201214 yr Go to innnate graphics and motors, hmmm.. maybe he has the motul and castrol stock with him. just go claim your valuable discount too Edited May 14, 201214 yr by soulja
May 14, 201214 yr just spoke to sumith at innate. you can get 0w20 from mobil. if your really interested go place the order and you can receive the day after with a small discount. hope it helps.. safe..
