Everything posted by Sylvi
What's Your All Time Fav Car?
'Crosswind', I think in Ceylon former Governor general had this type or similar car in RR 1950s. I have a faint recollection of this shape. I am not sure above is the same model. If you see some of old indipendance films black and white you will see that car on Galle face. Sylvi Wijesinghe.
Lioc Extra Premium Euro 3
Members, I do not want to discuss of the above subject as this octane number increasing had come up i will post what I read some time back on the web. Toluene..my octane booster of choice Here is an article some of you might find interesting. I personally use toluene at a 5:1 ratio of pump gas to toluene and I always add 4 ounces of marvels mystery oil for every gallon of toluene.. If you are interested in running insane amounts of boost without spending $5+ a gallon on race gas read on. Jus in case you are curious you can find it at most paint supply stores. ENJOY! It's Typed Version of the Article: Octane boosters are popular in the performance scene because they often regain power last through detonation. Sold for around $25 in a handy bottle, they’re a convenient fuel additive and horsepower helper. But with so much brands on the market, you may be fooled into thinking they’re all as effective as each other. Which they’re not! Differing chemical compounds, additives and even volumes, mixed in with a good percentage of advertising, ‘independent" testing and testimonials all conspire to confuse the consumer away from the single most important paint: does it improve the octane rating? Let’s see what’s worth it in octane boosters. DO I NEED AN OCTANE BOOSTER? The boys at "The Macquarie Library" describe detonation as: "Excessively rapid burning of the fuel mixture, often caused by auto-ignition due to excessive temperatures in the combustion chamber, incorrect ignition timing, lean mixtures, too high a compression ratio or unsuitable fuel," – as in too-low an octane rating. Heard as a faint, metallic rattle, detonation is accompanied by a loss of power and can cause serious damage to piston crowns. The significance of detonation is such that many companies produce fuel additives designed to increase the inherent octane rating of a given fuel. The proliferation of octane boosters has in part come about in recent times thanks to low quality Australian fuels. White or "Super" leaded fuel has been reduced from 98 to 95-96 octane, Premium Unleaded has also dropped to a minimum of 95 octane. And this presents a problem for high-performance cars designed to run on higher octane European or 100 octane Japanese fuel. Japanese import performance cars, Subaru’s STI WRX for example, runs an ECU program for 100 octane, but sometimes detonates on our Australian PULP. All engines are different though and with Honda’s S2000 2.0-litre engine running a high 11.0:1 compression ratio, it relies on advanced engine management as much as quality fuel. But it can sustain its power on PULP. And of course any turbo owner who has experimented with boost will know if you run too much, it will detonate, so improving the octane is vital for maximum performance. We must state that unless an engine is detonation through low RON fuel, octane boosters have little use. However, in a turbo or high compression application, the inclusion of a better grade of fuel allows the engine management system to optimize ignition timing and fueling. THE CONTESTANTS For this test we tracked down nine different makes and models of octane boosters, two fuel "additive," a straight race fuel and a drum of Toluene. Where there were several different "levels" of octane boosters in the one brand, we chose the strongest version. The biggest claims the bottles have is the amount of "points" they claim to increase. This is ambiguous as a "point" can relate to either 1.0 RON (Research Octane Number) octane points, or 0.1RON octane points. The list of entrants in our octane Olympics included: STP Octane Booster Wynns Octane 10+ Power Booster, Amsoil Series 2000 Octane Boost, Super 104+ Octane Booster, VP C5 Fuel Additive, ELF HTX 330 Racing Fuel Stabilizer, Nulon Pro Strength Octane Booster, PowerFuel Super Street Nitro Based, PowerFuel Max Race Nitro Based, NF Octane Booster Racing Formula, NOS Octane Booster Racing Formula, Toluene, VP Motorsport 103 Unleaded Racing Fuel THE TEST To conduct these tests we contracted independent laboratory Intertek Testing Services, who would test our products on a knock engine. We had to also find a base fuel to add our boosters to so we went to the closest public petrol station, a Shell on the outward-bound side of the Westgate Bridge in Melbourne. Being a performance-based test, we chose premium unleaded fuel as this represents the most common high performance fuel (ie: if you start with regular unleaded, you’re wasting money!). We should add that "some" boosters would have improved the octane rating of regular unleaded proportionately more than our tests with PULP. With a RON rating at a minimum of 95, we first established the exact octane of the PULP. The biggest surprise was our randomly select Shell resulted in a quite high 96-8 RON. We precisely measured and mixed each additive to the PULP, according to each manufacturer’s recommendations and specs and poured each into the knock engine’s tank. The compression ratio was then slowly increased until it started to knock, gaining a threshold of detonation and subsequently a maximum RON rating. Of less importance but still worth mentioning is the design of the bottles: since most people will be pouring it straight into a tank, the design of a bottle is important to prevent any spillage on paintwork causing damage. So let’s look at the results! THE RESULTS BASELINE OCTANE 96.8 Octane points It’s very easy to confuse octane ratings as there are a number of separate international standards. MON (Motor Octane Number) is the number derived from a fuel when it’s applied to a test engine run at 3000rpm rather than 600rpm and higher inlet temps and ignition advance. The Australian importer of 104+, Andrew Holdsworth, suggested MON is seen as a more real-world test. Though none of the fuel companies promote the MON figure which is normally between 7 and 10 numbers less than RON (Research Octane Number). Intertek’s Graeme Marks believes RON provides the general public with an idea of which additive works more effectively. And being the most commonly-used reference, we’ve used RON for all our tests. 11th PowerFuel Super Street Nitro Based 946ml treats 35 litres RRP: $35 Right from the start, we were told PowerFuel’s additives weren’t necessarily octane boosters, but horsepower helpers. We kept this in mind when testing both the products, but of the two only the Super Street claimed it was specifically designed to increase the octane rating of PULP. With a 20-percent nitro mix, Super Street Nitro-Based still improved octane ever so slightly (0.2RON) but the real test for these two would come on the dyno runs. OCTANE IMPROVEMENT: 97.0 (+0.2 RON) 10th PowerFuel MaxRace Nitro Based 946ml treats 35 litres RRP: $45 Containing another 15 percent more nitromethane than the SuperStreet formula, MaxRace doesn’t claim to increase octane, but the verbal recommendation was the same, ie: its main characteristic is to boost horsepower, not octane. For a fair comparison of these two additives, you need to look at the power they produce. As for octane, it proved very similar toe the SuperStreet formula bumping up octane ever so slightly. OCTANE IMPROVEMENT: 97.0 (+0.2 RON) 9th STP Octane Booster 350ml treats 57 litres RRP: $10.95 One of the cheapest of the group, the STP was also one of the hardest to find. Auto stores either didn’t stock it, or had simply run out! Claiming to increase the octane 2-5 points, in a well-designed-for-pouring bottle, the STP – used in the ratio determined by the label - improved the octane marginally by just over half a point. A little disappointing unless you interpret STP’s claim actually meant 0.2-0.5 points. Then it’s a good result! OCTANE IMPROVEMENT: 97.4 (+0.6 RON) 8th Wynns Octane 10+ Power Booster 325ml treats 60 litres RRP: $10 The Wynns was the cheapest of the lot and claimed an increase between two and five points, again not actually listing what a "point" related to. Strangely though the 10+ could indicate 1RON and if this is the case going by our tests it almost lived up to its name. It didn’t quite live up to its claims however, increasing the octane rating by 0.8RON. OCTANE IMPROVEMENT: 97.6 (+0.8 RON) 7th Super 104+ Octane Boost 473ml treats 83 litres RRP: $25.95 The acknowledged winner of all previous testing in this country, Super 104+’s bottle stated we should expect an increase between four and seven point. With a new formula introduced about 12 months ago, identified by an "Eagle" logo on the back of the bottle, the Super 104+ seems to have lost its edge with a marginal gain of just less than 1.0RON. OCTANE IMPROVEMENT: 97.5 (+0.9 RON) 6th VP Racing C5 355ml treats 75 litres RRP: $19.95 VP has a strong reputation with fuels and its high octane formulas are very popular (VP?) with drag racers. VP Racing’s C5 Fuel Additive lacked any indication of contents nor claims, but the C5 additive still provided a reasonable increase of 1.3RON. OCTANE IMPROVEMENT: 98.1 (+1.3 RON) 5th NOS Octane Booster Racing Formula 355ml treats 60 litres RRP: $28 NOS, a relatively new octane booster, comes in "1/10th" scale bottles designed to emulate the actual nitrous bottles of its successful NOS systems. The Racing Formula is the strongest of three concentrates and containing Hydrotreated Aliphatics and Methylcyclopentadienyl Manganese Tricarbonyl (try saying that 10 times in a row), it contains a lead replacement which NOS claims increases the octane rating by as much as seven points. Obviously not recommended for street use, it also included with a handy pouring spout. In testing, it proved a good result improving the octane rating by almost 2RON. OCTANE IMPROVEMENT: 98.6 (+1.8 RON) as much as 7 points. ***************************************************************************************************************** Further more I have tried Acetone 2% on full tank it gives me a I to 2 KMs for a liter. Sylvi Wijesinghe.
Tax/duty For Toyota Prius & Honda Insight????
Venura, it is very difficult to anyone to predict the exact duty and other charges on any vehicle until it is cleared from the port. Some times there can be delays when the vehicle arrives on to the port, not having correct documents. If you have a good family friend importer who will disclose the cost of a Vehicle duty and other charges. Then it is best to request from him. No importer will give you the correct cost of duty and the other. Including under invoiced charges on used Vehicle because then buyers can come to know the margin they have. If you have any documents of the vehicle, with all details. You can go to customs they will help you. The most corrupt Government department is customs in Srilanka, Without Palm oil nothing comes out from customs to the importer and at last end user has to pay for all that. Sylvi Wijesinghe.
- Find Fiat Spare Parts In Sri Lanka
Steering Wheel Woes
NRX, As you have mentioned about the Curb knock after that your rim has few dents on the rim instead of that rim you can buy a used good rim from any used spare part dealer. Don't go to straighten the damaged wheel. First of all show your car to wheel alignment place then, disclose what are the problems you had and en counted after that they will inspect your front wheel alignment, not only that test your absorbers too. I think M/s, Nalaka has a full package under rupees 5000.00. if it is small adjustment on the front after your Curb knock they will attend to same. Only thing you have to tip the workers. Sylvi Wijesinghe.
Fb 15 Battery
'maersk', I agree to your comment on the post 1st few lines. About having a higher amperage battery yes there are advantages, when you stop the car on a long distance run if you want to use any equipment it will serve your discharge without any problem, that too for like camping lights,TV, Musical set up. Draw of current has to be under 5 Amperes. Can fix even 200 ampere hour battery to any car there will not be any effect on your electrical system. I assure all motorists that will not Damage or any adverse effects on to the car. Only thing you will carry extra weight. that will effect on the cars fuel consumption. Amperage is the capacity of the battery, there fore the requirement if it is normal use, the manufacture will fix a low amperage battery. If idling requirement is more then manufacturer will fix a lager capacity battery, Like special communications lighting and any other accessories. Off road winches are used only high amperage battery is necessary. For example all fire fighting engines use higher amperage batteries, due to their requirement on emergencies. Only thing they have a bigger Alternator which can produce high amperage. This above is my experience in automobile electrical maintenance industry for few decades. Sylvi Wijesinghe.
Steering Wheel Woes
'NRX', The best advice is already given by (The Don's) post. I too agree to his post, get your wheels balanced also. do a shock absorber test. That will not cost you much. M/s, "Nalaka" at colombo 02. Next to "Arpico" show room will do all what you require for your car problem. Sylvi Wijesinghe.
Parking With Ac On For Long Time
'hatharasinghe', There is nothing wrong if you do not drive the car, keep your engine running. Because engine run little faster and consume according to the engine speed, what is required for the A/C compressor and the cooling fans, other current what is necessary to run the engine. Petrol will consume very much less than moving the car on the road. I have done this in USA Arizona during the summer when we went across to Mexico, we stopped for lunch for two hours in a Trailer attached caravan. The vehicle was a ford 6 cylinder with attached caravan for 4 people. Meters did not show any overheating of the engine. Sylvi wijesinghe.
Fb 15 Battery
'Reckless', You are correct 45 Amperes the battery is enough for the said car, originally it comes with a less amperage battery, due to Japanese Self starter motors are developed to start with low amperage battery's. Sylvi Wijesinghe.
The Best Tactic To Get Around A Police Officer(Traffic)
'rangerover, I appreciate your post giving your opinion. It is a correct reply for members of the A/L. Sylvi Wijesinghe.
'ransam', You are perfectly correct , like what happened to our late Comedian Mr, Nihal Silva ( Sargon Nallathimbi). Sylvi Wijesinghe.
Al New Appearence
Members, The site works Very well to both of my ADSL connections. I have no problem in posting posts. Sylvi Wijesinghe.
Another Exotic Arriving In Sl Shortly!
Mr.CARBON B4', Yes. I have a computer by my bed side, when ever I get up I log into the Web and read. I go to sleep by 8.30 or 9.00 PM. Due to my old age, I sleep only for 6 to 7 hours in the night. I have a nap about 1 hour in the afternoon after lunch. I agree with you as most developed countries do like to have Asians, to head their organizations Some Srilankans also holding responsible posts in NASA. Sylvi Wijesinghe.
'liya, Yes, This is our mother land we must not forget always some one will help you if you are in difficulty on the road, I have been to 30 or more countries west as well as east. You will never get this srilnkan hospitality in the west. When you contact the party invited you for a assignment they will want to work from the very first day. It is Ok if you are young and prepared for any rough life. But I cannot understand the reason when in Srilanka has plenty of opportunity to start life leaving this paradise island and going to a first class country, to be a third class city dweller. The money you spend to migrate you can buy a small land and do some plantation or do buying and selling. Yesterday I came across a person from a very well to do family started to buy a car do few little thins for same, groom it so that it will be attractive to a buyer and sell at a profit. Today he has more than 15 cars for sale. makes more than .5 million for a month. Has his own painter tinker and a mechanic in leased out 1/2 land few miles out of Colombo three families are living from his business. he has come up within 5 years. now not interested of his parents money too. Above is my opinion that can differ to a another person. Sylvi Wijesinghe.
Hybrid Car Tax Down To 8% By 2012 Budget
Members, OK we have all reductions of taxes, What about devaluation of the Rupee will effect on the imports. Will some member who is conversant on the old tax and new taxes, enlighten to A/l forum giving all figures will be appreciated. Sylvi Wijesinghe
Straighten Bent Areas Without Heating
'frontwheel', Please understand your first post was not a very clear post. so most members gave different opinions of theirs to your first post. Please do not miss understand my post. You have got some Makabass advice to straighten your front wheel problem. As one member say you will end up with some more problems. My advice is for you to go to a wheel alignment place like M/s. 'Nalaka'. Or to a reputed garage. First tell them exact problem what you have. Get them to examine and give you an a advice, get their expert opinion for your problem without wasting your valuable time by replying with different ideas by above said basset. Some times you may have to change the arm, it will not be very costly. I once had a accident on one of my vehicles the front wheel arm cost me new rupees 4500.00 only. not only that the arm fixing chassis unit (Bracket) also needed some straightening which was done only by hammering no heating getting the exact position of the other side. If you have a health problem do not go to a retreaded Hospital attendant, go to a qualified Doctor for correct treatment. Sylvi Wijesinghe.
'The Don', Yes you are correct. I went there they have divided that land and sold to sanitary fittings people.One time they did good business,owner was a ex employee, one Mr. Ratnayake at D*MO according to information I received yesterday. Sylvi Wijesinghe.
Used Jap Vehicle Traders Fear Business Decline
Members, One post says Hybrid cars tax down to 8%. Sylvi Wijesinghe.
frontwheel, Do you have a ordinary steel sheet pressed wheel or a alloy wheel. Alloy wheels can be straightened there is a machine with Marcotec.They were having their work shop at Nawala I think the are no mote there, If you go there, that was situated almost close to Nawala turn off to Narahenpita junction opposite a bakery. towards open university on the main road, Will try to get the address as I will be visiting that side today to buy some bathroom fittings. Sylvi Wijesinghe.
You are referring to merc dealer is it the D*MO Pandithage family?. Sylvi Wijesinghe.
'CARBON B4', I am not criticizing any one or try degrade any one there are facts you cannot hide. I will give brief history of Rama DBK. MR. K.P.W. Ramanayake was a broker from early 1960 during the starved period of motor vehicles ( 1962 to 1978). He used to take Morris oxford and Austin cars from Colombo drive, sell them in Jaffna and buy two Morris minor cars from Jaffna, drive them down to Colombo sell them in Colombo. Then when open era came in he started buying reconditioned Japanese Vehicles from the importers and sell them. There were only few importers at that time. There by he became a motor car dealer, I would have imported few hundred Vehicles to him with his funds. For about five years. He started his import carrier in 1985 before that he was using my Trade plate CC235 with his name as "Ramanayake Automobiles" on that plate. "Ramanayake Automobiles". I named his Business name to register his legitimate motor vehicle dealer business. First Japanese exporter was introduced to him by me. Later his son Jagath Ramanayake who is a giant exporter in Vehicles, was send to japan For further studies and to work under a Pakistani vehicle Exporter who was married to a Japanese. He worked for some time there, Later after study of export Business jointly started with few Japanese exporting vehicles to Srilanka first. later to all over the world. By my above statement I do not try to do any harm to him or his family's creditability. I and my family still have very good connections with him and his family. I am happy for his sucess, in Automobile trade today. Sylvi Wijesinghe.
Auto News
Members, From the web, Fuel Cell. Researchers have built a completely autonomous lab-on-a-chip device, which has an integrated micro fuel cell.Methanol fuel is used to power the electronics while carbon dioxide (CO2), produced as reaction by-product, pumps the liquid analytes around the channels. Microfluidic technologies have been touted for some time, and while small devices have been demonstrated they typically rely on large and expensive external equipment such as compressors and various electronic components. This essentially renders them unsuitable for applications such as point-of-care diagnostics and field work in developing nations. Around six years ago, a team of Spanish researchers from the National Centre for Microelectronics (CNM) in Barcelona came across the lab-on-a-chip problem. ‘We attended two or three microTAS [Micro Total Analysis Systems] conferences and saw that there were many platforms and a lot of technologies but not many commercial products,’ Dr Neus Sabaté of the CNM told‘The two main reasons seemed to be the lack of autonomy of these devices and the lack of consensus of which was the best technology to put everything together.’ At this stage, the researchers began investigating micro fuel cells, at a time when there was talk of them being used in laptops and mobile phones. ‘It’s clear now that micro fuel cell research has lost the battle against batteries because lithium-ion batteries are getting better and better. But we think we’ve found a niche for micro fuel cells with lab-on-a-chip devices,’ Sabaté said. In the current prototype device, the micro fuel cell is composed of two silicon current collectors and a commercial membrane electrode assembly (MEA). The collectors are fabricated with deep reactive ion etching (DRIE) to allow the reactants to distribute by diffusion. When the micro fuel cell starts to deliver electrical power to a certain load, CO2 gas is created at the anode side as a result of the oxidation of methanol molecules. The accumulation of CO2 in the inlet chamber causes a pressure increase that forces the liquid in the sample chamber to displace towards the analysis chamber. ‘We’re taking advantage of these by-products, which are generally a nuisance for these kind of devices, and turning it into mechanical power,’ Sabaté said.The researchers hope to further develop their current prototype device, but Sabaté believes there may be even greater potential for micro fuel cells that can take sugar water and even variants powered by the very same fluids they are analyzing. In addition, they are working on a device where the entire platform — both the fuel cell and the chip — are made from the same biodegradable polymer, making a much more flexible, robust device. Sylvi Wijesinghe.
- Continuous Ink Supply System
'The Stig', I buy refilling tubes from U/P Bambalapitiya. 1st floor there are many shops who sells them, walk around and compare the prices, buy the cheapest. There is a another quality of printer ink which will not smudge for water drops, that is expensive but that cannot be used like the other, number of times on one cartridge due to viscosity is thicker than the other one and it dries fast. Printer has to be used daily. Sylvi Wijesinghe.
Mirage7777, You keep only the printer and return the new cartridge request for ink filling tubes for that cost, They can not refuse according to the consumer protection act, what you buy do not serve immediately, you had bought same without your knowledge. Further more because it is only one day and unopend cartrige, speack to their manager or request a credit note so that you will buy some thing later. If you like please inform what is the make of the printer you bought. That is very cheap price you have paid. Sylvi Wijesinghe.
