Everything posted by jami
- Nissan Cefiro
Peugeot 406
Alto 800 12kmpl........ or realy hearts
Best Toyota Car
YES AXIO a fault product.......
What To Buy For About Rs 2 To 3 Mn
For that price range, Toyota - 121/Carina Nissan - N16/17 This is the best option to you, even you can sell, bcz both have good second hand market, good on fuel, less maintenance, parts freely available. N16/N17/Carina - Comfortable
Breakpads
Experts, i have replace a new ball joint for the front wheel left side one. i have noticed it break pads wear down more then other side, and replaced the break pads again. even the rim heat is too high compare to other side. why is this...
Breakpads
- Peoples Leasing
yep sure. but heard some branches allowing it AND SOME ARE NOT- Peoples Leasing
Is it possible to transfer the leasing to a another party (Peoples Leasing)- Gearboxproblem
thanks for the ideas. ill check with this- Gearboxproblem
- Tata Nano
i think nano is a better choice for our people to pocket, rather going for a teak panel, or BURUTHA Panel. So dont blame it before it lands on to the road.- Gearboxproblem
yes it is 1.6 engine and it's fast- Removing Tough Staines In Paint/ Body
cut the mango tree.. simple- Gearboxproblem
yes this is true.. and i used to do it when it happen. and want to know how this function?- Gearboxproblem
where is the best place to do this in Kandy/Badulla area??- 1500Cc Or 1800Cc For Short Distance Drive
1.5 is the suit for short distance drive without arguments.- Gearboxproblem
thanks. This TCU Controlled code can identify by the scanner? and what result it gives?- Road To N'eliya
peradeniya/ kandy roads are very good and even no suspension forces for the vehicle. even you can travel through awissawella / ginigathhena / hatton road- and the road is good. nuwaraeliya to badulla or welimada road is too bad bcz of the road construction is going there, you never go there by a car prefer use a SUV. even the Raja mawataha road to badulla via Vicoria/randenigala reservoir road is damaged but you will able drive safely there. from ohia and from nuwaraeliya to Horton Plains road is acceptably in good condition you can manage to drive by a car.- Sound When Releasing The Brake Pedal
yes checked pads are ok....... what is the best pad can we use??? any girls here- Atf
yes the cost is too high comparing to other low mileage ATF, but ATF with less durable one get more heated and may cause other part damage like rubber parts. i found with long lasting ATF heating temperature less and cooling time and cooling temperature much good compare to a ATF with low mileage durability.- Atf
hmm idea is right, but what ATF will make that no of mileage?- Permit Vehicle
what kind of a permit is it? what is maximum allowed CC? For that budget Terios is ok and if you able to pay another 5/6lks you will able to import a good one- Atf
What is the most suit ATF for N16? for stand over 50000 miles or around 25000-50000 miles- Auto Gear Shift Problem - Nissan Bluebird Sylphy G10 (2003 Model )
i ve got n16 1.6l/ problem is gear changing from low to next not in a smooth way, i have to accelerate over 3000rpm from low to change the gear. - Peoples Leasing
