Davy
Top Contributors
  1. Did you mean to say 29 front and 30 rear? If that is the case, then you might be running with over inflated tyres at the back. Usually the front tyre pressure is higher than of the rear tyres for front-engine cars. What does your B-pillar tyre inflation pressure chart say? If tyre pressure is good and if shocks and bushes are okay, then it could be due to misaligned rear wheels.
  2. Resale value is not as terrible as people say it is. After 6 years of owning a Lancer, I can still sell it for a little over the price I bought it for... confidently. So I wouldn't call it poor resale value. Also, I personally don't believe in making a profit out of owning a car. There are so many other factors to consider when buying a vehicle besides resale value. Finally, being so fixated on resale value will bias you towards buying a car that will please the market (next owner), but not you.
  3. Bumping this old thread to share this video: Didn't know that they actually do a lot of local work on cars before they're put on the road. Wish the documentary was more technical and in more detail.
  4. This is totally wrong. You can buy a decent pre-facelift (say 2001/2002) CS1 for around 1.6M. It is the CS3 that could go up to about 1.8M max. Examples (CS1): http://autolanka.com/ad.asp?ID=175393 Examples (CS3): http://autolanka.com/ad.asp?ID=174150 http://autolanka.com/ad.asp?ID=174068 I don't know where you have been looking, but you've been looking at the wrong cars.
  5. Yes, you're right. I probably had my wires crossed while I was thinking about it earlier. Since you need the delay after the door closes, we can safely assume that the circuit is open.
  6. We heard you the first time. EDIT: And the second time. EDIT: And the third and fourth times. Seriously, stop opening new threads for each car that comes into your mind OP.
  7. Rumesh is right. I was indeed referring to the suction piston. I distinctly remember it being part of the carb repair kit. If I were you, I'd still look into the possibility of repairing the carb using a genuine repair kit. The carburetor you'll be buying will probably be a used one and God knows what issues it will have.
  8. Not clear as to why your carburetor needs to be replaced because the piston is damaged. I'm pretty sure you get the piston as a part of the (genuine) carburetor repair kit.
  9. No personal experience with Dum!nda, but his work is good as far as I've heard and prices are bit on the high side. Just make sure you don't let him turn that car into a fiberglass freak show.
  10. Also, having a capacitor parallel to the bulb means that when the capacitor discharges, the current doesn't flow to the bulb totally, most part of the current travels outside the circuit to where the resistance is much lower. To prevent the current from flowing outside, you have to use a diode (a rectifier diode would do the trick I suppose). This way the capacitor is guaranteed to discharge only through the bulb. Someone correct me if I'm wrong, it has been quite a while since I got my hands on a circuit so I have forgotten most of what I have learnt in school
  11. Are you serious?
  12. This is supposed to be the car I'm talking about. Photo Credits: Pradeep (source: Facebook)
  13. Welcome to the forum! Please do a search on the forum following the instructions given here. Finding a good tinkerer is proven to a be a very difficult thing. Where do you live? It's a car you've had with you for twenty years! You don't need anyone else's opinion to decide if you should spend on it or not. The car should pretty much be a member of the family by now.
  14. Does the engine idle properly at 800 RPM? If yes, then it's probably a faulty oil pressure switch or low oil pressure as Rumesh has mentioned. What's the mileage of the car?
  15. Why people use Nitrogen on standard cars is either because some vendor claimed untrue improvements about using Nitrogen, or because they were told by another person who uses Nitrogen that their car is better on fuel and feels much better to drive after using Nitrogen. If tyre pressure is checked periodically (ideally tyre pressure should be checked weekly - especially for a car that is not run daily), and if suspension components are good and are aligned/balanced properly, tyres will last their intended lifetime - without having to use Nitrogen. So, as The Don correctly mentioned above, Nitrogen is unnecessary for a standard road car,
  16. Welcome to the forum and welcome to the Lancer family. UniMo will not charge you for an inspection. They will do the necessary checks and give you an inspection report free of charge. Just call them up to confirm. I personally think thy're the best, if it is just an inspection. They will of course tell you that you need to attend to every nut and bolt in the car, in practice you really don't need to. Just be mindful of that and you'll be all good. If I were you, I'd get the timing belt changed anyway - just to be safe. Make sure you use a genuine spares for this repair.
  17. There are kits available for this if you don't want to go through the trouble of creating the circuit yourself. For example: http://www.jaycar.com.au/productView.asp?ID=KC5392 With installation instructions: http://www.autospeed.com/cms/A_3068/article.html If you want to create the circuit yourself (which is what I would have done), then have a look at this: http://pcbheaven.com/circuitpages/Car_Dome_Light_Off_Delay/ Do share with us what you decide on doing. Good luck!
  18. Saw photos of another Tesla Model S in the country (a black one this time) on Facebook.
  19. Maybe you can look for a dash kit like this one?http://www.jjautomotive.eu/index.php?page=2&itm=664 The one in the link is not a AT212 dash kit, but you might be able to find one that's meant for yours. If all efforts fail, I'd dump the whole "wooden finish" and paint all the panels in a nice satin black or another colour to match the interior of the car.
  20. Forgot that you opened a thread yourself about the subject? http://forum.autolanka.com/topic/16355-engine-cleaning-of-hybrid-cars/
  21. Welcome to the forum. Your car's idle controller mechanism maintains a higher RPM until the engine reaches operating temperature. The RPM gradually drops to normal as the engine reaches operating temperature. This is absolutely normal and you have nothing to worry about.
  22. From sira's explanation,it sounds to me like the CV joints are worn out. The clicking sound from the CV joints is usually not heard when the wheels are pointing straight. And I like to think that OP was going in a straight line when he did 120. To determine if your CV joints are worn out, you can try taking a U turn while accelerating a bit hard (steering on full lock), making sure you don't spin the car. If you hear the clicking sound then, your CV joints are on their way out. Make sure you do this both clockwise and counterclockwise. This is a simple test, so only obvious cases can be identified by this method. A better test would be to have them inspected by a professional. If the CV joints are good, my next guess is that there is a slight bend in one or both (unlikely) of your drive shafts.
  23. Thanks The Don. I thought I was being paranoid when I thought the home page was filling up with multiple, similar, useless threads. I'm going to quote OP here so that he doesn't miss this thread. Hi StarOnline, welcome to the forum. Please use this thread for all your "news" posts. There is a thread named Post Whoring which you can use as well. That way the forum stays clean. Thanks!
