Davy
Top Contributors
  1. The manufacturer specifies a maintenance schedule for every model they produce. Usually there are two schedules - Normal for when you use the vehicle in regular conditions and Severe if you use the vehicle in harsh conditions (dusty, extremely hot or cold, frequently towing etc.). It is up to the owner to submit the car for service at each mileage (or duration) specified in the schedule, but the agent is responsible for executing the checklist for the mileage/months the vehicle was brought in for. So the first question is, does the customer get a service booklet when you buy a car from the agent? The booklet explains service schedules applicable for the car and what is meant to be covered in each service. This is meant to be kept in the car. The following PDF is the Service Schedule booklet offered by Mitsubishi in the US for non turbo cars (this is the 2011 version) https://mcarsstatic.cachefly.net/pdf/owners/owners-manuals/2011MY Warranty NonTurbos Maintenance.pdf If you look at the 60,000 miles service, note that it's a major service where valve clearances are adjusted as well. So if the local agent just changes oil and filter and does an undercarriage wash, wash the car, vaccum it and hands it over to you all sparkling, that's not a complete service. This is a bit more clearer in the following maintenance schedule booklet as everything is summarised into a table: https://mcarsstatic.cachefly.net/pdf/owners/owners-manuals/2015 Maintenance Section- Turbo.pdf The schedule in Australia is a bit different than the one in the US. There are 4 schedules (A, B, C and D) where A is the regular 15,000 km (7500 km for turbos) schedule and the other three are additional services required at specific intervals (like 25,000, 50,000 and 100,000). So if the car has done 150,000 km, the agent has to carry out steps mentioned in schedule A as well as B and C, because 25,000 and 50,000 are multipliers of 150,000. The booklet explains this well. So if the local agent doesn't follow the manufacturer schedule, you might as well take your car to any other service station and get it serviced at a cheaper cost IMO. The whole point of the "agent maintained" status is to be able to service the car as per the manufacturer specified schedule. Of course for a repair like timing belt change, it makes sense to go to the agent. This is one of the main reasons I asked my father to stop going to the Mazda agent and go to Mazna instead because they do the exact same thing and the owner of Mazna is a family friend who personally looks into the car most of the time.
  2. They used to have a checklist back in the day and it was quite comprehensive. I had a couple of them and gave it to the buyer of my CS3 with the rest of the maintenance history documents. However, the checklist I'm talking about was given during a couple of those free inspection campaigns that the agent had. Not during routine services. I've never taken my car to the agent for servicing. So not really sure how comprehensive the service reports are. Do they do an actual manufacturer-specified service?
  3. Hi Riaanvt, welcome to AutoLanka forums! For an issue like this on a GDI, the first thing I'd suggest is to get your high pressure GDI pump checked out and cleaned.
  4. @Hyaenidae Done. You guys can continue the discussion here. I've added a link to the starting point of the new discussion to the original post for ease of access for new members reading.
  5. Not necessarily. If it's the gearbox mounts that are worn out, then you can just replace the worn out mounts. But depending on the car and how the mounts work, replacing all at once (or a few) needs to be done. This is because a mix of old and new mounts mean that the new mounts will be under more stress because the other older mounts don't absorb engine vibration as much.
  6. Davy replied to MalindaG's topic in General
    Big or small, if there's uneven wear on tyres, then your alignment is off or you have wear in your suspension. So I suggest getting it checked out.
  7. What's the issue with the rocker cover? Is it plastic on the Viva Elite? No, they're not critical jobs. Even you can do them at home given you have the proper tools. I've seen people recommend Janatha Motors for Viva Elite parts. Get a quote from there and take it to a good garage. Tagging @Sampath Gunasekera as he might be able to advise as well.
  8. Hyaenidae's response above is spot on. CY4 is the model that came with 4B11 engines. The RalliArt is also CY4 by the way, but has a 4B11T. All engine models that came on the CY series Lancer has a timing chain. As for stretching issues, the chain in the 4B11 has a wear sensor that illuminates the check engine light if at all the chain has excessive wear or stretch. I'm not sure if this is available in the 4A engine series, but I would assume it is - at least after a specific model year. If you're asking if the engine has an inherent timing chain stretching issue - then I am pretty sure it doesn't. I haven't tried the ELM327 Bluetooth OBD scanners on my car, so not sure if they work. I have a D900 OBD scanner and that's what I use.
  9. Davy replied to MalindaG's topic in General
    Get your front suspension checked out. Probably worn out control arm bushes. How's the condition of your shock absorbers? Also, are the camber and toe in figures in the wheel alignment report within spec? Excessive positive camber or toe in are the main reasons for outside tyre wear if all suspension components are in good condition.
  10. The oil leak and noise are probably two different things. Get the distriburor o-ring replaced to fix the oil leak. It's an easy repair. As for the noise, it's hard to say based on what you've said. Take it to a good garage and have a mechanic test drive the car to find out what the actual issue is.
  11. What were the errors shown during the scan?
  12. As others have already said, I'd pick Mazna over Colonial any time based on experience with both of them.
  13. Hi Dinushka, welcome to the forum! The forum is not a place where automotive repair services are carried out. Members can only recommend you garages and workshops based on their past experience. Also, I'd highly advise against sharing your phone number on a public forum.
  14. This is my go-to site for Dashcams: https://dashboardcamerareviews.com According to this site, the Viafo 1119 (now has a V2) seems to be the best value for money. It seems to be a copy of the Street Guardian cameras which are highly popular in Australia. I'm using a Mini0806 atm and been using it for 3.5 years now. I think they've addressed most of the issues in the 0806, but the battery issue is still a problem. I bought two of them and the battery failed within a year or so and both of them are now running on the second battery that I've purchased on eBay and replaced with. That too has issues sometimes (sounds the "low battery" alarm but keeps recording). So I've disconnected the speaker. They now have a Mini0906 which is a dual camera and is the cheapest dual dashcam out there (see link above). I believe this has caps instead of a battery. If you want a dual cam set up, this is worth looking into as well IMO. Agree. Totally worth it in warm climates like Sri Lanka. Especially if you have the car parked in the sun during the day. The SanDisk card I had would just crap out when the sun comes up and then I replaced it with a Samsung Evo card which was much better. That too gave issues on warm days and the camera forces to format the card before proceeding (I guess file system corrupt due to heat). It has been a smooth sail with the Transcend High Endurance card.
  15. According to your other thread, you mentioned that you followed up a fuel consumption issue by getting a tune up done. So if your cold start issue came up after the tune, it could be because they cleaned the throttle body incorrectly, causing carbon deposits to get lodged inside the idle air control valve mechanism and thereby causing it to stick. If this is the issue, properly cleaning the idle control mechanism will fix it. In your other thread, you mentioned that the Check Engine indicator doesn't work. This is something you need to address as soon as possible. When the diagnostic scan was done, were any error codes retrieved?
  16. Hi Sanjeewa, welcome to the forum. It you want members to help, you're going to have to provide more details than that.
  17. A blown head gasket is no reason to replace the engine. Just buy the gasket overhaul kit, repair it and you're done. With a reconditioned engine, you never know what you are going to get. It might be worse than the engine on the car. How many kilometres on the car? Does it show signs of wear like smoke from the exhaust or burning oil?
  18. Hi MaheshK2, Welcome to the forum! That's just the way it is. The evaporator is inside the dashboard. Some mechanics make it seem like a job that will put their life at risk to make it look complicated and expensive. In reality, it's just removing dash trims, console, sometimes a bit of AC plumbing and motor chamber to access it - not the entire dashboard. Take it to another AC repair shop and get it leak tested again properly to make sure it isn't the plumbing in the engine bay that's leaking. Good luck!
  19. Oh this is @E L N I N O's EX. Maybe he can shed some light. The engine cover appears to be a different, larger version. Makes the engine look much bigger.
  20. Please search the forum.
  21. Just read this! Great writeup mate! And nice colour choice! ?
  22. That is no reason to replace the ECU. Don't waste your money. Run away from that mechanic as fast as you can. The first thing you need to do is get a diagnostic scan done to make sure there are no error codes. The ignition signal in OBD2 systems works by sensing the Crank Position Sensor signal. So get your Crank Position Sensor checked out. It maybe as simple as a bad Crank Position Sensor. Don't blindly replace the ECU without checking simple things first.
  23. The white ring that caps the grommet into the headlight housing might be a bit difficult to find IMO as it's specific to the headlight design. If you're unable to find it and you have the other side, try 3D printing? Finding a matching grommet should be easy like tiv said.
  24. From what I can tell, It doesn't touch the cylinder head when the cover is installed. There's a very slight gap. I'll check to make sure. Correct, the Evo and the RA share the same lightweight Aluminium bonnet. From memory, the Evo (if no sunroof is opted for) also has an Aluminium roof. The RA doesn't.
