Davy
Top Contributors
  1. Thanks! Appreciate it. As for the roof wrap, the Evo X Final Edition comes with a black roof and looks pretty sick IMO, especially on white. Photo below for reference. This is the sort of look I want. Haven't really thought about it to be honest. It doesn't hit the ground on speed bumps or even when leaving or entering the driveway, so it's not a huge problem for the moment. I will keep this in mind though. Thanks! I guess the solution would be an Aluminium skid plate. Thanks and will do when I get a bit of time mate. Probably next weekend! This thread has some interior photos, but not that great I think.
  2. Sounds like a continuously running ABS pump? Do you have a check engine light? When the noise is heard, does stepping on the brake pedal firmly change or make the sound go away?
  3. Thanks bro. Appreciate it! Would have taken longer if not for the hoist, power tools and four hands. It was literally: - Take the wheels off, raise the car - The front struts are held by 3 bolts up top (as seen in one of the photos in my post) and 2 in the bottom. There's also a 10mm bolt that secures the brake line and ABS sensor wire to the strut. So those need to be removed. The BC Racing coilover has all of that exactly like the OEM strut, so just take out like 7 bolts, pull out the old strut and put the new one in. Repeat for the other side. - The rears are held by two bolts up top and just one at the bottom. But the lower control arm bolt needs to be removed from one side (leaving the lower arm hanging from the middle of the car). To access the top two bolts, part of the trunk lining needs to be taken out. This is probably what took most of the time as those plastic clips are a b!tch to remove. The hardest thing as I said, was routing that damping force adjuster extension through the shock tower in the rear. - Adjust damping force as required. And that's it! I hear you. I'm not much of a sticker fan myself (I was when I was in my teens ). I actually held the sticker against various places and it did look pretty good. Oh and the RalliArt didn't come with Recaros nor Brembos. Only the big brother Evo came with them (Recaros were not standard even on the Evo). So the only stickers I can put are BBS, BC Racing, K&N as I have a drop in filter. That's it. I was actually thinking about doing this tomorrow. If you look at the last picture in my previous post, the front wheel sits really nice in the arch because the gap between the wheel arch and tyre is consistent all round. The rears however almost touch the wheel arch at the top and the gap widens towards the bottom. I like the former. So yes, I will try raising the rear about 1 inch and see how it goes. Changing the height is really easy. Can do it at home. Even with it raised, I fear that it will still rub if there are 2 passengers in the rear and a trunk full of stuff. It just needs about 5mm of clearance! Thanks for the suggestion.
  4. Happy Saturday gentlemen! Two hours, two bleeding fingers and one burnt hand later, I have managed to get the coilovers installed at a garage of a friend. Would have taken longer if not for the hoist, air tools etc. Let's take a look at how she looked before: The top photo actually looks like the car is on a jack or something. But that's how bad the wheel gap was. And as seen from the two photos below, I can *clears throat* put my fist in the front wheel gap and and three fingers in the... um.... rear. ? I was too busy bleeding from my fingers trying to get the rear damper extensions installed, so no pics of the install. But here's a shot of the front and rear coilovers installed: And here's the top view of the front. My friend mistakenly installed the camber plate diagonally and had to remove them again to install them properly! This is the damper adjustment extension routed into the trunk through an opening in the strut tower. Had to use a screwdriver and a hook to pull it into the trunk. Those metal edges are really sharp. Should have worn a pair of gloves. BC racing has really thought about this tbh. If not for this extension, it's impossible to adjust damper force as the top of the strut isn't visible from the trunk due to the chassis design. And voila... here she is after the install. Couldn't be more happier. This is not the final height. I'm still playing around with it. The rear tyre rubs on the wheel arch when going over bumps and uneven road surfaces, so I will have to roll the rear arches a tiny bit. Fronts are perfect. I think I like the front height more than the rear, but I might change my mind. Enough of the chit chat. Here you go... Close-up of the wheels with the centre caps on finally! No room for fists or fingers now. I can't even park the car in my parking bay the way I used to anymore because the front is low. It hits the stopper on the floor of the parking bay (see first image). So I park the car the other way. I used to park like this because it's easier to take the car out, but now I need to do a three point turn to take the car out. The million dollar question - does it handle better? The difference in handling is pretty significant. The RalliArt handles pretty well out of the factory, but the new coilovers has transformed the car's handling to a whole new level! I can now confidently throw a tight bend at the car at much higher speeds and expect it to effortlessly take it. And the car stays planted on the road. Such a massive reduction in body roll. Out of the box, the factory damper setting is set to about 75% (8 notches down from 30) hard. I cranked it down two notches so now it's a bit more soft and surprisingly comfortable as well! I'm still playing around with that as well though. Overall, it has certainly been a worthwhile upgrade. I wish I had done it sooner. The car sits so nicely now and I'm really happy with the outcome. Stared at the car for about half an hour before driving off. Next up, I want to wrap the roof in black. Not looking for anything fancy, just cheap vinyl stickers from eBay. Cut to size and paste. Will probably DIY that as well. Also, after the BBS rims were installed, the brake calipers are really visible. So I want to paint them (red) and give a general clean up under the wheel wells. Stay tuned for those. Lastly, I have the BC Racing stickers that are still in the packaging. I'm in two minds if I want them on the car or not. If I were to install them, they will be going on glass (rear windscreen - one sticker, small glass on rear doors - one per side) unless it's under the bonnet. Thoughts? Thanks for reading! Comments are always welcome.
  5. Davy replied to Watchman's topic in The Lounge
    VW Golf MK2 by the looks. The US market one?
  6. If this was observed after replacing the power steering rack, then obviously it's an issue with the steering and/or suspension geometry after the repair. Did you try to bleed air out of the power steering system? If not, start the car and let it idle for about a minute. Then turn the steering wheel to one side fully. Turn fully to the other side. Do this lock to lock motion a few times. This is best done while the front wheels are off the ground so that there is less strain on the suspension system. If that doesn't solve it, get another wheel alignment done from a good place. Caster angle might be off.
  7. That's not my engine bay. It's a photo off the Internet I linked to show yellowing of the coolant and windshield washer reservoirs.
  8. Yellowing due to UV happens regardless of whether it is directly under the sun or not. It is just a matter of time until the coolant reservoir and windshield reservoirs start to go yellow. It happens on all cars. Not just the EX. I guess it has to do with the construction of the plastic as well. On the EX, maybe the power steering reservoir is more susceptible for UV damage than the other two. In fact, the power steering reservoir used on the EX is a really old design/construction used on the CS and even on the CK Lancer. It maybe even be due to the darker colour of the power steering fluid. The reservoirs on my CS3 were sparkling bright when I bought the car and slightly more yellow after my 7 years of ownership. I had never washed the engine bay or used any harsh chemicals/degreasers on it, and the car was mostly a weekender. Here's an engine bay in relatively good condition 1996 Toyota Corolla:
  9. The main reason for those parts turning yellow is due to UV exposure. Apparently the plastic polymers in those parts are highly susceptible to UV. I'm not sure how to prevent it from turning yellow. Maybe our resident expert on plastic materials @Sampath Gunasekera might know. If they're yellow, you can use bleach or something to whiten them again I guess. There are even commercially available products like Retr0bright that help you restore plastic that is gone yellow. They're meant to be used to restore retro game consoles and stuff, but should work on any white plastic that has gone yellow due to UV damage.
  10. Kerosene degrades rubber. A big no no.
  11. 4x4 vehicles have a much higher tolerance for water damage than regular road cars, so this example is probably not the best. Another thing is that this is a diesel engine. Petrol engines have high tension leads and ignition coils that are more susceptible to damage. The other thing is that when you wash the engine while it's hot or running, condensation can build up inside the electronic components. We all know what that means. Contacts can eventually corrode and circuitry can get damaged. Some cars nowadays have the ECU in the engine bay, so even the smallest amount of water can cause water damage. If you must clean the engine bay, just use high pressure air to remove all dust first. Then spray degreaser carefully, making sure you try to avoid electrics. Use a rag to wipe off the dirt and excess degreaser. You can use a brush to scrub off stubborn grease marks or dirt.
  12. Davy replied to Le Sabre's topic in NISSAN
    Seems to be in rough shape. At least on the outside. But hey, that's what a project car is right? Good luck!
  13. 2488cc is not referred to as 2.4L. It's 2.5L. The "25" in QR25DE stands for "2.5". The convention is to round to the nearest (100cc from memory) value.
  14. If members here see bullshitting, it's called out. Regardless of whether it was made by a newbie of senior member. There are plenty of newbies here who are welcomed because they knew how to blend into the community. In the same way, there have been seniors who have been called out on bullshit as well. From this post I've quoted, let me just pick ONE example and call out bullshit. There is no 2.4L Nissan X-Trail. Just 2.0L or 2.5L. Let'a assume that was a typo that you actually meant 2.5L. One and only 2.5L X-Trail? I just did a quick search in AutoLanka classifieds and found 9 of them! So yeah, bullshit. Just stop embarrassing yourself. Also, you have continued to insult members despite my previous post. More of this from you and the moderator team will be compelled to give you a warning. @MADZ, if you think this thread should be locked, please go ahead.
  15. Three pages? Really?? Okay I think we need to call it quits now. This thread isn't going anywhere. @kaveeshatbd, The forum operates on a strict "no bullshit" motto, so a newbie making questionable comments about a Cefiro isn't the best way to make an entrance here. Don't think members here will respect you just because you did 240 km/h in a car. Respect is earned here by making contributions, respecting senior and long-time members, and by being factual. So if you want to stay here, let's start doing by that OK? Also, long time and trusted members here who have made worthwhile contributions have a higher credibility than some random stranger, so I'm sure everyone here who responded will believe @PreseaLover's word more than yours any day. So just stop trying to justify. What it looks like is that you are trying to do some guerilla marketing here by rambling about how good the Cefiro is and how easily you can find spares for it. The argument @matroska is trying to make is that a modern F1 car has a tiny 1.6L turbocharged engine which is significantly more powerful than a 2L engine say on a Cefiro. So you simply can't say things like "I don't like cars that have smaller engines than 2L because they are less powerful". That's just an ignorant comment to make. Shows you that you don't have even the basic knowledge in how force induction works or even on engines. So OP, let's cut the bullshit now shall we? To all other members who have responded, appreciate if you can be respectful. Not denying that I almost fell off the chair laughing while reading some of the posts. Try to keep things civilised. We've all seen this kind of newbie before.
  16. Not sure where you searched, but I found the following threads: You might want to read this thread about how to search the forum:
  17. Davy replied to varotone's topic in MITSUBISHI
    No worries at all. Glad I could help. The door open light is standard I'm pretty sure. Yours should be having it as well. High speed warning chime as well (mine was activated at 110 km/h. Sounded like a Xylophone. Just two notes that sounded sort of like a doorbell ) I think the shock absorbing bumper is a safety feature that was mandatory at the time in some markets like the US and Australia. I have seen this attachment in some A72 Lancers in Sri Lanka as well. It makes the bumpers stick out than normal, so ruins the look of the car a little.
  18. Last time I checked, MADZ said it is okay to type in Sinhala if you find it difficult to get an idea across in English. I agree and I'm even happy to translate questions to English for those who are unable to read Sinhala. I can add the translation just below the original question itself, given that the original question is clear and concise. This particular thread however, is not solely due to the fact that OP finds it hard to type in English. It's that + assuming that members here have the ability to read their mind and find out what car they're taking about. Judging by the username, I assume it's a Toyota Aqua. How hard is it to type that?
  19. Wow that's great! It's unbelievable! I think the CEFIRO A33 won "Car of the year" 18 consecutive years since 2000, so you're absolutely right. Also, wow!!! 240 km/h, that is really great on a CEFIRO! Good on you mate. Aim for 260 km/h next time. I'm sure the CEFIRO can do it. I also used a friend's CEFIRO A33 for a few weeks back in 2011 or so I know exactly what you're talking about. I only drove around Colombo at slow speeds, so didn't get to enjoy it at 240 km/h like you. @PreseaLover, care to share your "positive" experience with yours?
  20. Haha! Comparing to how my father used to work on cars, this is nothing. It's literally plug and play. I'll try to capture some photos when they're going in. Still trying to get some time organised to install them. Until then, here are some photos of the unboxing. Oh and these are street/tarmac coilovers. More info about them here. Decals, installation manual, warranty info etc. Tools for height and preload adjustment together with the damper adjustment extensions for the rear shocks since after the rear shocks are installed and trunk upholstery is installed, there is no access to the damper adjustment knobs. These extensions are to be plugged onto the damper adjustment knobs and routed outside the trunk upholstery so that they can be adjusted easily. Camber plate visible for the front struts with 30 level damping force adjustment knob on all four struts. Stay tuned for the install and after photos.
  21. No. The cables just need to be re-routed to the new location.
  22. I only have the scissor jack from the car, which makes it a bit difficult and time consuming to install these, so I'm taking it to a friend's place and getting it installed myself. It's just 5 bolts per shock, so shouldn't be that difficult.
  23. I'll leave this here for now... A little teaser. ?
  24. You can. Wouldn't hurt to try. Did they check your electronic throttle as well? From your description, it seems to me like there might be a "dead spot" in the throttle position sensor (which I believe is built into the electronic throttle). I like to think that the agent knows how to check it.
  25. Euro 3 is regular petrol, treated with additives to meet the Euro 3 emission standard which is pretty old. 95 is better than Euro 3. Also, the issue is not really with the sensitivity of the engines but with the substandard fuel quality in Sri Lanka. Modern cars have knock sensors that detect engine knock and retard timing to deal with low octane fuels (in case of emergencies), but there are tolerances. @Civic las, your best bet is to do a diagnostic scan to find out if the engine is really knocking on load. If it stops knocking after the turbo kicks in, it is likely to be retarded ignition timing which can be due to bad fuel among other things.
