what is this part in toyota vitz?
From the embossed lettering on the metal ring, it looks like it's from AERO which is a company that manufactures suspension components. So that has to be a suspension bush. If this had really fallen off your car, you would feel a difference in the way the car handles or the way it drives over rough roads. Check under your car and see if the rear struts are hanging. If you're in doubt, take your car to a garage and get your undercarriage and suspension checked out to make sure everything is OK.
Project A72V
Depends. Core cleaning is only required if there are blocks or if there is excessive rust in the radiator. A pressure test is needed to check for leaks. What OP has done here is just a simple flush and refill with coolant as it was using water before and there are no leaks.
- 189 replies
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
The four door cards are mounted using metal clips that are hooked into the rear side of the door cards. So the clips are not visible. Example below: As for the upholstery on the inner sides of the trunk and tailgate, they are secured with screws.
- 189 replies
- 1
- mitsubishi
- a72v
- 1400
- mmc
Honda accord wiring problem
@AmilaC, Please stop creating multiple threads for this issue. You've created three so far. This thread can still be used to discuss your problem. Threads merged. So what happened? If all of these issues started popping up after you replaced the engine compartment fuse box, then just swap back to the old one. The new fuse box you used might not be having the same internal wiring.
Project A72V
I think original carb manufacturer was a company named Mikuni. The A72 came with many different types of carbs including the "bottle type" one. The one on mine was different and had a small glass window to see the float chamber. As for carb experts, I'm sorry I have been completely out of touch about local mechs and garages since I'm away from the country for the most part of the year. LB. Let me know if you're unable to find. Pretty sure I can find one for you and post it. Good job on getting the emission test passed! The small joys of repairing a car properly. The car seems to be in better condition than the previous one. Like the black interior than the beige one. It needs the set of badges and emblems by the looks. As for the battery, the positive terminal needs to be away from the body of the car to prevent the risk of it coming into contact with the metal. Also, I don't see a battery retaining bracket. You should be able to get one from Panchi or a salvage yard. Lastly, fender mirrors AND door mirrors... Because two just don't cut it.
- 189 replies
- 2
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
That engine bay actually looks much better than the previous car. It even has the ducting for the air filter which is missing in most cars. Share more photos. We promise not to say anything that will hurt your feelings. Looks like significant improvement after the distributor contact breaker and high tension leads replaced. However as Rumesh has mentioned, the high CO indicates that the engine is running rich. So double check your air filter and PCV. My opinion is that if you must overhaul the carburettor, then just use a carburettor repair kit and get an expert to do it. I have had nightmares with makabases experimenting with my carb and I even had to swap it out because the first carb was messed up too badly to restore.
- 189 replies
- 1
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
I have only been able to find the engine workshop manual PDF and I updated the link on another thread for you. I've seen a couple of workshop manuals on eBay. Most of them from Australia where it was referred to as the Lancer LA (early model) or Lancer LB (later model) and Lancer LC (Celeste). LA, LB and LC are the model codes and the cars were actually made during the time Mitsubishi and Chrysler had a partnership going on, so they were all generally referred to as Chrysler Lancer or Colt Lancer. Just a few tips and keywords for you to share for workshop manuals. Local Australian classifieds sites have physical books for sale for around Rs 3000.
- 189 replies
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
Advise you to stick to one thread for your project. Otherwise by the time it's done, there will be 10 different threads. Threads merged. Renamed original thread. Everyone who has responded above including myself advised you with good intentions. At the end of the day, it's your personal choice though.
- 189 replies
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
That one is definitely not the one I meant when there are cars in better shape for a lower price. When I searched "Lancer Wagon" in the quick site yesterday, there were a couple for around 160,000 (a 12 Sri silver one and a 12 Sri white one) that looked okay in the photos. However, both of them no longer seem to be there. The ones currently on that site for around 2 lakhs are in pretty much the same condition as the one you've purchased by the looks.
- 189 replies
- mitsubishi
- a72v
- 1400
- mmc
- Project A72V
Project A72V
#4. You won't be able to find chrome bumpers. At least not ones in good condition. Your best bet would be to get your current bumpers chrome plated. Tried this option back in 2004 and I was quoted 8000 per bumper from a couple of places. #9 From the engine bay photo, it looks like the car still has the original copper radiator. Keep it as none of your aftermarket plastic/aluminium radiators will be as good as this one. If there are leaks, repair it. If it uses water, do a flush and fill with coolant. Also, your first priority should be bodywork IMO. Came with chrome fender mirrors. You might be able to find a couple of used ones in Panchikawatte salvage yards if you search a bit. Search the Facebook groups as well. I've seen some swap the original fender mirrors to these plastic ones because the originals mirrors have a spring loaded mount under the fender that corrodes over time and causes the mirror to wobble. Is this a temporary measure? I sure hope so because that is definitely not the way to repair rust. The moisture absorbed into the body filler will cause the metal to rust still. You should take the windscreens out, repair the rust and then seal it if you plan to drive the car until the rest of the work is complete. Also, be careful when you are working around chrome trims and rubber beadings. You have smeared body filler over the windscreen beading and that stuff will not come off easily. Those beadings must be really hard to find nowadays. Back in 2004, the front beading cost 12,000. The rear one cost 4000 or something and the rear quarterpanel glass beadings cost 8000 each. The worst part is that none of them fit like the originals did. So try your very best to protect what is already good on the car as this is not your Toyota Corolla 141 for which you can find parts everywhere. EDIT: I just noticed that this car is still advertised for 2 lakhs in the quick site. Is that ad yours or is it the seller's ad from whom you got it? I still see that Pajero in the background so assuming it's yours? If you bought the car for this price, I'm afraid you could have found an example in much MUCH better condition. I see several other A72 Lancers for sale for around 1.5 and some of them are in better shape.
- 189 replies
- 1
- mitsubishi
- a72v
- 1400
- mmc
Project A72V
Good to see a thread like this after all the hybrid and permit threads that seem to have taken over the forum. The car looks to be in rough shape, but hey... I've seen ones in worse condition. The first thing I can see from the photos is that it's a GL which is the highest trim level and comes with a clock on the dashboard and so on. So that's good. The other thing is that this is one of the later models which came with the Mitsubishi "Three Diamond" logo and "MMC" badges on the bonnet and with black bumpers instead of chrome ones. I personally like the chrome bumpers better, but the this one has a higher demand in Sri Lanka because it's the later variant. When people advertise it, they use the term "kalu buffer" to market it as well. Although the only visible rust you see is under the rear windscreen, once you take apart the car, you will discover plenty more. The A72 is known to rust inside the "gutter" area under the front winscreen. Basically under the two vents below the winscreen. That entire section needs to be cut out to repair it. Mine was corroded and water was leaking into the car when it rained and the passenger side floor board had a massive hole from prolonged water seepage. Lift up the carpet and check. Have you looked at other examples as well before selecting this? There are a few good local Facebook groups and I have seen some really good A72 Lancers in them. You might want to PM some of the owners and ask. The ones in good condition are quite expensive. I saw one in Badulla or somewhere recently (a 5 speed sedan SL. Blue colour with gold Watanabe rims) go for 7 lakhs. Car was one of the best I've seen. Good luck with your project!
- 189 replies
- mitsubishi
- a72v
- 1400
- mmc
Lancer A72 Saturn Engine
Try this link. Original post updated.
Lancer A72 Purchase / Restoration / Daily Use
Thank you and good luck with your purchase!
- Honda Vezel Hybrid DCT Tranmission Oil Change
Clueless on where to get repairs done
If you're actually thinking about DIY, then search the DIY section on the forum. Also, you should be able to find countless amounts of videos on YouTube about simple DIY jobs like changing spark plugs, cleaning up the throttle body and so on. Get a good tool kit that has a socket set, spanners and screwdrivers. For the removal and installation of spark plugs, you would need either a long socket or a spark plug removal tool. Some contact cleaner, carb cleaner for cleaning and WD-40 for those stubborn nuts and bolts. These should be enough to start.
- Maintaining an Axio Luxel
What's your car? Check out this thread:
Fake auction sheet (photos attached)
This is one of the reasons why crooks like this still do these things. At least report that ad on the website so that they take it down. And post your findings on the Consumer Affairs Authority Facebook group so that they will look into it. That's the least you can do.
Did you confront the seller and take action?
Vehicle Service Stations & How They Cheat Their Customers.
Yes, my thoughts exactly. Just because a customer requested, a service centre shouldn't perform anything on a vehicle that could cause damage or in this case even a fire hazard! I highly doubt they would have done that. In fact, if you look closely, you can see the step light on that door still working as the worker washes it.
I remember seeing this a couple of months ago. Apparently the customer requested. They had responded on Facebook. See below post: https://m.facebook.com/story.php?story_fbid=1752993338149268&id=559300354185245 Edit: Looks like they have responded to this recent video as well https://m.facebook.com/story.php?story_fbid=1827154610733140&id=559300354185245
The "risk of failure" is near zero if a competent mechanic/garage does the repair. Also, what are "the basics"? Not doing a fuel system clean up ever (especially if symptoms of rough idle, high CO or general poor performance is present) is basically letting all those carbon deposits sit in your intake and throttle body and letting it choke the engine from performing as it should. When I was back home in February, I felt that the Demio was a bit sluggish than the year before. So I took out the spark plugs, throttle body and cleaned them up and reset the ECU. My God the difference in performance was noticeable and during my second trip to Kurunegala after this, I had more fuel left in the tank than the previous drive before the clean up. Based on my experience, I am convinced cars in Sri Lanka need more frequent fuel system clean ups mainly because: 1. The fuel in Sri Lanka is horrible 2. The driving conditions in Sri Lanka are far from ideal Even in Australia, I had to take my car to Mitsubishi to get a clean up done (they call it "upper cylinder de-carbonising") because of a rough idle when cold. Had to do only one up to now (touch wood) at 120,000km.
4dr6
Sounds like low oil pressure. Does the oil pressure gauge indicate normal pressure?
Seat belt warning beep
A quick Google search gave me these: https://mutantblack.wordpress.com/2013/06/30/prius-disable-seat-belt-reverse-beep-warning/ https://www.meetup.com/en-AU/PortlandHSD/pages/867589/How_to_turn_off_BEEPS_in_a_Prius/ This is to disable the beep. but you can toggle the "b-off" to "b-on" in the last step to turn it on I guess?
