Davy
Top Contributors
  1. You know, 600 seems to be a pretty normal idling speed for this car IMO. So if you're experiencing vibration, you should probably get your engine mounts checked out.
  2. Did you see the actual error code in the scan report? Because "Rough Idle Error" is not a thing. Since you say that the error is no longer present, I assume there are no error codes nor a Check Engine light. How many Kms have you put in the car after the clean-up at ASNU? If it's just a couple, then you may find that the ECU is still re-learning as the battery would have been disconnected during the repair. Put a bit more distance and see if it idles normal again. Also, you said you checked with a new throttle body, but did you actually drive the car so that the ECU re-learns? If you've already done that, when you start the car in while the engine is cold, does it rev up to about 1500 RPM and slowly settle down (in your case at 600) as the engine becomes warm?
  3. Good job on getting it scanned by the agent. This again proves that getting a second opinion can save you from a random makabass ripping you off on replacing a good ECU. I would trust A M W's result over AutoMiraj's one mainly because their scanners are brand specific, hence more accurate. I also trust that they would make informed recommendations about how to proceed. P1320 is an ignition signal issue, so it may or may not be the ignition coils themselves. Since the agent said that the coils need to be replaced, I assume they tested them to make sure the cools get power and resistance in the coils themselves. If not, I suggest checking power to each ignition coil before replacing. From memory, the QG15DE engine on the FB15 has 4 ignition coils, one over each spark plug. Each coil should have a 3 pin connector. Positive, Ground and the ignition signal pins. Turn on the ignition switch and measure the voltage between the Positive terminal of each connector and the chassis. It should indicate 12V. You can also check continuity in the coils by switching the multimeter to Ohms and measuring resistance between the Positive and Ground terminals of each coil. These are steps the agent should have done before recommending you to replace coils. In addition to all this, there are tools to even graph the ignition coil voltage to figure out if one of them are behaving abnormally. If the issue is in the coils, you should be able to find recon (used) ones in Delkanda, but you never know the mileage of these used coils, so be prepared to deal with faulty units if you are unlucky. I suggest just getting one coil first and plugging it to each cylinder and clearing the error code to see which cylinder has the faulty coil. It's very unlikely that all coils failed at once.
  4. Spanner indicator usually means that a service is due. How many Kms/months ago did you change engine oil and perform a general service? The oil indicator means that engine oil pressure has been detected to be low. This can be due to low engine oil level, a faulty oil pressure switch or a failing oil pump. Given that the car has done only 30K (assuming the mileage is genuine), it's unlikely that the oil pump is faulty. Did you check your engine oil level? As for the scanner freezing, it maybe due to an issue with the scanner itself. So go to a different garage (or better, the agent) and get it scanned again.
  5. What's the source and destination of your 122km trip?
  6. Go to a proper garage and get it scanned. There should be specific errors that are revealed by a diagnostic scan. Not just "ECM issue". Take it to the agent and get it scanned and they will use their proprietary NISSAN tools to scan and identify the issue. If the car runs and drives, it might just be a loose connection somewhere or a faulty sensor. It's just that you need to rule out all other possible causes to think about ECU repair or replacement as it's a significant repair. If your ABS warning light is also indicated, then obviously there is an issue with the ABS system which also should be revealed in the same diagnostic scan. It could be something as small as an open circuit in one of the wheel sensors to a faulty ABS module.
  7. The Insight as been discussed many times. Search the forum.
  8. I suggest getting it scanned from a different place just to get a second opinion before opening up the ECU. Do you know what exact message was displayed in the scanner? Did you get a printed report? Also, does the car start and run?
  9. Davy replied to Owen's topic in MITSUBISHI
    Before replacing anything, I think you should get the fuel pressure checked. Wouldn't hurt to replace the fuel filter if you haven't done it already though.
  10. Exedy is a good brand. Judging by the price, it should be a genuine Exedy. Beware there are imitations.
  11. No. It has a hydraulic clutch and cannot be adjusted. The only adjustment you can do is adjust the pedal to have some slack at the top before actually pushing the clutch master pump. I personally think this should be left a lone unless someone has previously messed up the adjustment. You can adjust only a couple of centimetres anyway, and depending on how far it's adjusted already, this can be even less. So get your clutch replaced. Usually when replacing the clutch, the pressure plate needs to be replaced if necessary and the clutch slave cylinder (release bearing + slave cylinder assembly. also called the clutch fork) needs to be replaced as well. This is done to avoid having to open up the gearbox again to replace them.
  12. From memory, there is no bracing for a power steering rack to be installed and the T-120 never came with factory power steering. So you will have to do a lot of work to get a compatible rack installed. This will involve welding brackets into the front axle and cross-members. Unlike the 1400cc Lancer A72 of the same era that came with a 4G33 (Saturn) engine, the T-120 came with a 4G41(Neptune) engine which doesn't have space for a compressor or a power steering pump to be installed, so installing the power steering pump will also not be easy. I remember that countries like Indonesia and Philipines got a Colt T-120 which is the same as the Delica T-120 with a totally different rear end. Still I think they too didn't come with power steering. So no luck with finding parts there either I think. My advise for you is to stick to regular steering. Maybe you can run a few extra PSI in your front tyres to compensate for the extra width. This should lighten up the steering a bit. I've upsized tyres of cars without power steering and if you choose the right rim+tyre combo, you wouldn't run into significant increases in stiffness of the steering wheel. What's the size of the tyres you're running?
  13. It's been a bit quiet on this thread since last year. Nothing much to update about on the car as I have taken up some other personal projects and the past couple of months (and the upcoming months) will probably be spent on that. I've done a few long trips though. Went camping towards the end of last year and it was a great drive. Did a couple of cruises with friends and one of the local Lancer clubs here in Melbourne. Did a snow trip again last weekend. Here's a (very rough) video of the drive. I made the mistake of speeding up the dashcam footage, and it certainly doesn't like that. Should have had my actual camera running, but I was too busy enjoying the drive. Again, sorry it's blurry.
  14. Davy replied to Owen's topic in MITSUBISHI
    The pump is inside the filter assembly which can be cleaned, but the filter element will have to be replaced. I don't think the filter element alone is available. It usually comes with the filter housing.
  15. Davy replied to Owen's topic in MITSUBISHI
    That's the one.
  16. As mentioned above, just use the VIN/Chassis number and use an online VIN decoder.
  17. You mean blower motor? If yes, then it could be due to a leaf or twig that's made it's way into the motor chamber. Take the motor out and inspect the motor chamber. While the motor is out, you can switch it on and see if it's actually the motor itself that's making the noise.
  18. If it's a Mazda, then surely Mazna Motors Attidiya. Their quality of work is excellent. Even better than the agent IMO. Search the forum for more info about them. You should be able to Google and find directions and contact information.
  19. That's the first time I saw someone ask how to LMGTFY. @Crosswind, now you'll have to show how to use LMGTFY using LMGTFY.
  20. Since it happens when the tank is close to empty, I suggest getting your fuel filter checked out and replaced if necessary. It might be clogged. If the problem persists after replacing the fuel filter, get a fuel pressure test done to make sure the rail has adequate fuel pressure.
  21. Davy replied to Owen's topic in MITSUBISHI
    Mitsubishi GDI pumps are very sensitive to bad fuel. If you've attempted servicing the pump multiple times, it's likely that the pump is no longer able to maintain high fuel pressure. There's a lot of discussion on the forum about GDI fuel pumps and servicing them, but end up replacing the unit. Even Mitsubishi doesn't service them according to my knowledge. Before moving on, get a diagnostic scan done and find out the error codes the engine is throwing. Did you replace the fuel filter?
  22. Haha, yeah that's Sri Lankan terminology for you. By the way, you still have this? Wow, how many years has it been?
  23. Welcome to the forum. Answers to your questions can be found on the forum if you do a simple search. As for the windshield washer tube, the easiest would be to just cut the tube where the leak is, and use a connector to join them. If you need to replace the entire tube, just take a sample to a spare parts shop/hardware and get a new one and replace.
  24. Hi Sanuka, Welcome to the forum! My father used to have a T120 many years ago and I remember that it was registered as "Light Motor Lorry" (C1) class. He had a C, C1 licence, but I didn't. So he wasn't that happy about me driving the van. But I drove it for quite a few years without being pulled over. So yes, according to my knowledge you need to have C1 as an allowed class in your driver's licence to be able to drive it. Note that this is based on experience that is a few decades old. Things might be different now and maybe another member can elaborate. Hope this helps. EDIT: Also find the below link on the RMV website that lists all vehicle classes. Note the C1 class: http://www.motortraffic.gov.lk/web/index.php?option=com_content&view=article&id=165&Itemid=165&lang=en
