August 20, 20188 yr when cannot accelerate more than 60 kmph , some time it accelerate well and some time never when fuel light on It will never accelerate more than 40kmph when earlier days it were accelerate any speed when fuel light indicate pls help me i ma new fore hear 1. is this air sensor ? 2. petrol pump - ? 3. or gear box -? Edited August 20, 20188 yr by mulpita nothing
August 21, 20188 yr Since it happens when the tank is close to empty, I suggest getting your fuel filter checked out and replaced if necessary. It might be clogged. If the problem persists after replacing the fuel filter, get a fuel pressure test done to make sure the rail has adequate fuel pressure.
August 21, 20188 yr Author thanks sir can u help find good place with low cost and good care maniacal around Colombo
August 21, 20188 yr If it's a Mazda, then surely Mazna Motors Attidiya. Their quality of work is excellent. Even better than the agent IMO. Search the forum for more info about them. You should be able to Google and find directions and contact information. Edited August 21, 20188 yr by Davy
