sira Posted August 20, 2018 Posted August 20, 2018 Dear Honda FIT GP 1 Users. Please note FIT GP1 AC evaporator coil can be removed without dismantling the dash board. you need to remove blower unit by separating the air intake door assembly and motor assembly then can access the cooler coil side. remove 2 door motors ,then remove all the screws of the evaporator cover. just one screw is hardest part which is hidden on the firewall side. I went to 2 places and both then said need to dismantle the dash board. but i did it with my self with advice from Honda expert. sira 1 Quote
chathuranga.s Posted August 21, 2018 Posted August 21, 2018 Has anyone done a A/C service on the gp1. My temp control motor makes a ticking noise continuously when it's set above 21 Quote
Davy Posted August 21, 2018 Posted August 21, 2018 16 minutes ago, chathuranga.s said: Has anyone done a A/C service on the gp1. My temp control motor makes a ticking noise continuously when it's set above 21 You mean blower motor? If yes, then it could be due to a leaf or twig that's made it's way into the motor chamber. Take the motor out and inspect the motor chamber. While the motor is out, you can switch it on and see if it's actually the motor itself that's making the noise. Quote
chathuranga.s Posted August 21, 2018 Posted August 21, 2018 2 hours ago, Davy said: You mean blower motor? If yes, then it could be due to a leaf or twig that's made it's way into the motor chamber. Take the motor out and inspect the motor chamber. While the motor is out, you can switch it on and see if it's actually the motor itself that's making the noise. Not the blower machan the temp control unit of the climate control. There is a motor operated unit that moves when you change the cabin temperature Quote
matroska Posted August 21, 2018 Posted August 21, 2018 On 8/20/2018 at 12:24 PM, sira said: Dear Honda FIT GP 1 Users. Please note FIT GP1 AC evaporator coil can be removed without dismantling the dash board. you need to remove blower unit by separating the air intake door assembly and motor assembly then can access the cooler coil side. remove 2 door motors ,then remove all the screws of the evaporator cover. just one screw is hardest part which is hidden on the firewall side. I went to 2 places and both then said need to dismantle the dash board. but i did it with my self with advice from Honda expert. sira thanks for the update sira - saw you had posted in the FB group as well. Quote
