CIVIC FD3 IMA issue
A bit confusing why the battery pack was replaced to solve what looks to have been an EPS issue. But yeah, a diagnostic scan will reveal the error.
Allion 2002 model vs Tiida 2008
Sorry for going OT (already OT anyway, but still), but this has to be mentioned: Most forums have a restriction where members are not allowed to post new topics until their post count reaches a certain amount (50 seems to be the most common). Professional networks (like Stackoverflow) have it even more difficult where you have to earn badges before you can freely post in any thread or make comments. Compared to these, AutoLanka forums is lenient on new members. Unfortunately, members abuse this privilege (as seen above) and open many threads about the same car or to ask a trivial question which has been discussed before. So before complaining about AutoLanka forums and the senior/regular members, I suggest you new members read through previous posts without opening a new topic for every single question that comes to your mind. The forum has been active for over a decade now, so we have volumes of information about cars, technology, and even non-automotive related topics. I know the big "START NEW TOPIC" button is tempting, but if you spend a few minutes searching through the existing threads, you can save others' times trying to dig up old threads or typing information that's already shared. No one is paid to respond and help people here. We do it voluntarily. So before accusing members who are contributing more than others, learn to respect them first. Then they will respect you. You will notice that most of these members who say that seniors/regulars are "arrogant" are members who visit the forum to ask a question and leave. If you've found the forum to be a resource of information when you buy a car, the least you can do is come back to the forum and do a personal review of the car to help others. Unfortunately, that doesn't happen.
What Unregistered Toyota car that I can buy below 6.5mil.
Hi @GDTJ, welcome to the forum. Please stick to one thread to ask your questions. Thanks. Threads merged.
Drive seat moved a bit down after hit back
If it's a height adjustable seat, maybe the shock caused the mechanism to unwind itself and send the seat down. This is assuming that no chassis damage was sustained.
Changing Timing Belt
It has a timing chain. not a belt (assuming KR engine). Chains don't have the 100,000km replacement interval. So you don't need to worry about it.
Toyota CHR 2WD or 4WD
Congratulations! After seeing a few CH-R threads on the forum, I was on the lookout for them on the roads. It looks pretty damn good IMO.
Toyota vios oil bulb on and off
Sorry, didn't read that before posting. ?
Care to share why you think the ECT sensor is related to oil pressure?
Permit Car Price List
I hope you saw that the prices lists are from 2011 and 2014. They're not current.
The Mazda Demio Thread
Only taking a walk in the area and looking around in shops will tell. The Demio DE is a pretty popular car, so there could be a couple of shops that have the side skirts, spoiler and the bumper air dams.
Agreed. And the oil pressure switch itself. They're pretty cheap to replace.
- Vehicle registration
You should be able to find both in Delkanda spare parts shops. I found quite a few of them in the area when I was looking for a door mirror.
- Nissan Cefiro Uncovered
- Qashqai, CHR, Vezel, Peugeot 3008
"Honda Civic 2017 (Gen X) 1.5L Turbo"
Just FYI, this guy Scotty is a first world example of a makabass. I'd take his advice with a pinch of salt. I have to agree with @iRage. Although turbocharged engines run higher compression over their NA counterparts, the engines themselves are built to withstand the additional stresses. On top of that, some manufacturers even recommend a stricter maintenance schedule for turbocharged cars. The argument here is that wear can occur because the engine oil needs to keep lubricating the turbo in addition to the engine. If you carry out routine maintenance as per the manufacturer's recommendation, this shouldn't be an issue. For the new Honda Civic, it has an "engine oil monitor indicator" which illuminates not just by looking at the car's mileage, but by how the engine runs while cold and warm. So the car itself is already smart to notify the driver to change oil on time. So even if you drive your turbo car in a spirited fashion, I believe the indicator will light up sooner and tell you that you better change that oil. The other reason why I don't think small engines with turbo will fail is because all of the real life examples. European manufacturers like VW and Audi have already been using turbos on their small 1.2 and 1.4L engines for quite a long tome now. And I have seen some of these cars well past 200,000km with engines still running like brand new. I doubt Honda will be any different.
[Q] Toyota/Starlet radiator fan motor disassembly
Glad you got it sorted anyway. Keep that motor with you. I'll take a crack at it when I'm in Sri Lanka for the holidays.
A good place to start checking is your engine oil level when the engine is cold.
- Toyota Axio 2014 - Check Engine Light After Service
Can you maybe share a couple of photos? If you can find the right size bearing, I don't see why it shouldn't work. But I guess the bush is press fit into the motor housing and getting that out would be a bit of a struggle.
No worries! Yes, what I did was take the metal mounting plate the brushes are on to an auto electrician's shop and ask them to solder new brushes onto it (since I don't have a high power soldering iron. regular 30 - 50w soldering irons won't do). If you fail to find brushes that are of the correct size, you can buy sightly bigger ones and grind them down to fit.
I've attempted to repair a couple of radiator fan motors when several garages said they need to be replaced. In all but one case, I was able to repair the motors successfully because they had failed due to worn out or stuck brushes.The failed attempt was because the coil was burnt, but even that I could have got it wound, but didn't bother because I found a recon motor for cheap. One of the motors actually belonged to @trinity. They're pretty straight forward motors, so with the right tools and with a bit of perseverance, you should be able to do a good DIY reconditioning job on them. If you can take off the racers, you could use them as samples and get compatible ones from a spare parts shop and use them.
Lancer A72 Purchase / Restoration / Daily Use
I'm not sure about now, but back when I was restoring, I found all engine parts from Panchi, the rubber bits and mouldings from Darley Road. Wiring, disc brakes, steering box and some of the hard to find engine parts (timing belt cover for example which was cracked on my car) was sourced from the "watte" area in Panchi (the watte next to the BMC building and runs along the canal). This area had several A72 Lancers that were stripped for parts. Some had really good body panels and even chrome trim bits. I found brand new brake cylinders, a brake servo, tail light lenses from various spare parts shops in Colombo, Ja Ela and Gampaha areas. Some of the mechanical bits are same as the parts that come on the L200, T120 Delica and the Lancer Box, so you just need to know what to ask for. I remember I had a cracked leaf spring once and I was surprised to see that the first leaf spring shop (somewhere in Ja Ela) I went to had over a dozen of springs labelled "LANCER WAGON". Another time, the chrome ring around one of the headlights was damaged and I could find a brand new one in Nugegoda area. Another interesting thing I found out at the time is that lenses for lights for older cars were apparently being manufactured in Sri Lanka (somewhere in Panadura if I remember correctly). In fact, the tail light lenses I had on the car after the restoration were locally made according to the guy who sold it to me. They looked pretty good, but the colours faded away within a couple of years. Few of the things I couldn't find were a new or recon carburettor. While a lot of mechs advised me to swap it for a carb from a newer car (some said TownAce Noah carb), I decided to overhaul it and use it. The choke was a bit off in my carb, so cold starts were a bit rough. The handbrake adjuster mecnianism that comes inside the rear drums was the other thing. Couldn't find one for the life of me. They just wore off (bad design). I found out that a lot of people swapped the entire rear dial plate with parts from the Lancer Box to fix it.
Service Except Pres**
BMWs registered at the RMV before 1st May 2016 - Rs. 85,000BMWs registered at the RMV after 1st May 2016 - Rs. 950,000 Source: Local BMW agent's Facebook page
Thanks. As for the stickers, it was when I was in my younger years where movies and the wrong kind of influence had gotten to me. ? But as the years went by and the kid inside of me subsided, I got rid of the stickers and attended to what really matters like the engine, suspension, steering and brakes. Sorry I thought the costs were in that thread. From memory, the paint job in 2003 (involved stripping the car down, tinkering and painting) cost roughly around 60K. The bodywork took a few months to complete and I was in the garage every single day, sometimes helping out with the bodywork. I stripped the car on my own and put it back together also on my own because I didn't trust the garage guys to mess up trims, wiring and other delicate bits. During the bodywork. I replaced all rubber beadings, tail light lenses, missing trims, and restored the chrome bumpers as well. The rubber beadings alone at LP Gunaratne was about 20K, I swapped the 12" steel rims with 13" alloys as well so the final number would have been somewhere around 100 - 120K. The engine restoration (2010) included a port and polish as well as all those brand new parts you see photos of in that thread. The engine was meticulously restored with a lot of love and care by a good friend of mine, a retired MINI race driver who is passionate about cars. I let him take his own time on it and every time I went to his workshop, it was as if though that worn out 4G33 is slowly turning into an engine that looked like it just rolled out of the assembly line. I think this cost me the most - probably around 80K due to porting, polishing and all the parts that went to it. I don't even remember how much the brakes cost, but the front discs were recon ones from a A72 sedan. Sourced them from Panchikawatte and I think they were around 8000. I had to buy the main wiring harness of the car that goes from the dash to the engine, because I had a problem after rats have chewed through the wires when the car was unused for about 6 months. I had the car re-wired and all electrics overhauled and that cost 36K (I remember this distinctly because this took a really long time). Again, these are prices from 2003 and 2010, so not really accurate for today.
